Question about Canon EOS 400D / Rebel XTi Digital Camera
Flash Error Hi there, bought this camera about 6 months ago. I'm intermittently getting a problem with the pop-up flash. It pops up fine, but the screen gives me an error telling me it hasn't and won't take any shots. Have to keep switching it off and on and hoping it will work again. Sometimes it's a couple of days before it works again. It will take shots when I switch the camera to the 'no flash' setting, so it does seem to be just the flash. The error says that the flash release is jamming, but it's working fine! Help! Thanks.
  • Karen Phelps Jul 16, 2008
    I keep getting an error 5 - contacted canon and they gave me a couple of suggestions that didn't work. Went to a Best Buy to try and get help and the service was terrible. Guess I will have to send it in.
  • luislopes Jul 21, 2008
    I have exaclty the same problem.
    If anyone knows the solution for it of if have as adivce to consult the Canon Warranty, please send me a mail to : luis_s_lopes@yahoo.com
    Thanks
  • 3 Answers
The error 5 can mean that there is something blocking the flash from popping up. If it is up but still get the message then you need to check to see if the little black pin/stick that lets the camera know that the flash is up, is not stuck. With the flash up and pointed at you ( like you are going to take a picture of yourself) the pin is located on the right side close to the where the flash attaches to the camera. Yo should see a little pin sticking up. make sure that area is free of dust and /or debris. if it is not up then that is the problem. try to free it with out braking it or get it professionally repaired.
Posted on Sep 11, 2008
Nikon d3100 flash wont pop up
If camera shows no sign of abuse, play st-pid and take it back to where you bought it and tell them unit is defective and you want to exchange it for a working model.
Jun 19, 2017 | Nikon D3000 Digital Camera
My flash won't flash on my 7d
Had the same problems several months ago. I will try a search the forum to find the nice labeled directions to solve the problem. This is not a major problem and can be fixed yourself.
http://photography-on-the.net/forum/...d+pop+up+flash
HID KITS.
Jun 01, 2012 | Canon EOS 7D Digital Camera
I bought my new canon eos 60D..i put on external flsah to use..then after i take off the external flash, my camera's built in flash cannot pop up to take flash even i had press the flash button. How?
Hi, What external flash did you use on your Canon 60D? The internal flash will not automatically pop up if in the "Creative Zone" it will pop up with the button in the creative zones (M, AV, TV and P) it will not pop up with the button if you are in the the full auto mode (that's the little green box mode) but, should pop up automatically if required. The flash should pop up automatically in the basic zone for Portrait, close up and night photography, the button won't activate (pop up) the flash. Also the internal flash will not pop up if there is an accessory in the hot shoe. Again what external flash was it you used and did it flash?
Jan 27, 2011 | Canon EOS 60D Digital Camera
Canon EOS Rebel XSi pop up flash won't "pop down"
Do not Tape it down, If the flash is pooping up all the time take it to a good Camera repair shop to have the catch replaced. At the same Time you may consider getting a full service done.
Dec 26, 2009 | Canon EOS Rebel XSi Digital Camera
Canon rebel xt eos
Error 99 means lens communication error.
Try to clean the contacts on both sides.
and re-install lens
Jun 25, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Error "Err05" keeps initiating preventing flash operating
There are two versions of this problem: 1. The flash does not pop-up. 2. The flash does pop-up.
Here’s the fix to the err05 msg when the flash does pop-up. This will work on the XTi and perhaps on similar Canon cameras:
The pop-up flash has two legs. Look at the pivot point of the right leg (”right” when looking into the lens). Just in front of the pivot is a very small spring-load pin on the “roof” of the camera body.
This pin is the sensor that tells the camera the state of the flash. The pin is pushed down when the pop-up flash is closed and is suppose to quickly spring up when the flash is opened. Problem is, the pin sometimes gets dirty and drags. When it is slow to spring up … you get the err05 message.
Fix: Take a small jeweler’s screwdriver and dip the tip in isopropyl alcohol. (Don’t use any other solvent unless it’s designed for cleaning electronic parts!) Then touch the screwdriver tip to the pin. Do this several times until the pin area is nicely wet. Then push the pin up and down until it is able to spring up quickly.
Enjoy.
Jan 20, 2008 | Canon EOS Elan 7ne 35mm SLR Camera
Built-in flash auto pop-up problem
Does the 'pop up' pop up? If it does and still says obstructed- closes it and pop it again If it still persists Canon customer support will advise the next move. If a repair price seems high you could perhaps get a separate flash if the camera accepts them.
May 09, 2007 | Canon Rebel XT / EOS 350D Digital Camera
My Flash suddenly will not pop up.
Hi Randy, It seems like the problem could be the settings. Try to set the flash manually, and then try to pop it up. If this doesn't work, and since the pop up flash release is electronic, have the camera cleaned at a camera shop. This would be a small price to pay if it works, and would be worth it for such a great camera. Please let me know if this works for you. Best regards, nightdiver
May 29, 2006 | Olympus Camedia C-770 Digital Camera
Canon EOS 400D / Rebel XTi Digital Camera Logo
140 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
