Question about Olympus FE-4000 Digital Camera
Every time i plug my fe4000 into the computer to download images, the screen comes up with battery flat, but when i unplug it the battery is full
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Olympus Master
  • 102,366 Answers
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Posted on Jul 04, 2011
Black screen when turned onno display
There are several reasons that your Toshiba laptop screen may not come on, even if the laptop appears to be running, and several options you may try to get your screen back up and running without an expensive service call.
Common causes for a blank screen include a backlight that is turned off, a display toggled to an external monitor and improper shutdown errors.
To avoid blank screen errors after your current error is fixed, make sure to follow all instructions in your user's guide to care for your Toshiba computer.
Shine a flashlight directly at your screen and look for an image.
If you see one, this means the backlight on your laptop is off but the screen is still working. This backlight normally turns off only when your screen is closed.
Look for a small metal or plastic pin near one of the screen hinges.
The screen pushes this pin in when it is closed, so if the pin is stuck in the screen closed position, the backlight will remain off.
Tap the pin several times to release it.
You may need to use a small object, such as a pencil tip or straightened paper clip, to reach it on some models.
Monitor Toggle
Press and hold down the "Fn" key if you do not see an image when you use the flashlight.
Tap the "F5" key several times while the "Fn" key is pressed.
This will cycle your screen through the various options that toggle the display to an external monitor.
Attach an external monitor, restart the computer and try this method again if no image appears on the laptop screen.
Click "Start," "Control panel," "Hardware and sound," then "Device manager "using the external monitor if you get an image there but cannot toggle the image back to your LCD.
Select the "Monitor" option to expand your selection and select your LCD monitor from the device list.
Click the "Driver" tab and select "Update" to update the driver, as this error is likely caused by a software driver error.
Force Restart
Press and hold the power button until the computer shuts down completely.
Check the indicator lights at the edge of your laptop to see if the computer is truly off or if it has simply gone into hibernation mode.
If it is off, all lights will be off except the battery-related lights if you have a charger plugged in. In hibernation mode, the power light will blink slowly.
Press the power button to restart the computer again after leaving it off for 15 to 20 seconds. This may fix the problem.
If the blank screen returns or you get a flash of images and then a blank screen, move on to the next step.
Force Power Down
Unplug your laptop from the power source.
Remove the battery by pressing outward on the battery latch and pulling the battery unit completely out of the computer.
Press the power button several times to completely discharge the computer.
Replace the battery and plug the computer back in after about 30 seconds.
Press the power button to turn on the computer.
If you get an error screen upon startup, choose to restart Windows normally.
This error is caused by improper shutdown procedures.
Hope this helps
Nov 14, 2012 | Toshiba Computers & Internet
Why won't the screen turn on after we were using it earler in the day
1. Unplug your computer and remove the battery.
2. Press the power button several times.
3. Reattach the battery, plug in the computer, and press the power button.
4. If the problem persists, look closely at the screen. If you can make out faint, dim images, the backlighting components must be replaced or repaired. If not, it is likely another issue with the physical hardware of the machine such as the screen or the motherboard.
Mar 05, 2011 | Computers & Internet
Turn power on ( plugged into mains) blue power light comes on fans whirr slightly but no screen comes on then fans start quietly but still nothing
unplug the battery and only hook up the ac adapter. If you don't get video then take out the memory and reseat it one memory stick at a time in each slot one at a time and make sure you try turning on the laptop after each stick reinsertion.
If that doesn't work, take out the hard drive and dvd drive and see if you get video.
If your not getting video after all of that then the motherboard is bad and would need to be replaced.
Aug 27, 2009 | Dell Inspiron 1721 Notebook
Full battery, doesn't start up
Mine is doing the same thing, and I've tried the same solutions as well as trying different computers and cables to recharge.
The one other possibility for mine is that I damaged it using a generic charger in the car that was supposed to work for "most" MP3 players. It did seem to - I mean, the player didn't blow up, catch on fire, or stop working! - but a day later, it collapsed. Maybe a coincidence, maybe damage from the car charger.
I'm guessing that it's time for both of us to send the units in for battery replacement.
Good luck with yours.
Jul 30, 2009 | Sony NWZ-E438F Digital Media Player
Toshiba satellite A210 11-P crashes when i disconnect the power lead
From Toshiba, try step-charging the battery or Battery conditioning procedures:
Batteries don't last forever. All types of batteries gradually lose their ability to hold an electrical charge as they age. Eventually, the computer's battery charge indicator may show that the battery contains less than a full charge, even though the battery has just been fully charged. The computer will then not run for as long a time from the battery as when the battery was brand new.
You may prefer to simply replace the battery if this happens, but you may also wish to try 'step-charging' the existing battery per the following instructions.
This procedure should work for the battery in any Toshiba notebook. Follow it only when you find that the computer will run from the battery for just a short while.
Check the User's Guide for more specific information about charging the battery in your computer .
Procedure
Step-charging the computer's battery
  1. Unplug the AC adapter from the computer, and turn ithe computer on. Let the computer run from battery power until the computer turns off, indicating that the battery is fully discharged. Time this interval, but not with a software clock running on the same computer.
  2. Remove the battery pack from the computer.
  3. Unplug the AC adapter from the computer.
  4. Wait at least 30 seconds. The first time through this procedure, use a soft cloth to wipe the battery pack's contacts and the AC adapter's plug.
  5. Re-insert the battery pack.
  6. Plug into the AC adapter into the computer again and check the fit of its plug in the wall outlet, making sure the connection is secure.
  7. With the computer turned off, let the battery charge until the battery status light or icon glows green, or otherwise indicates a full charge.
  8. Unplug the AC adapter from the computer.
  9. Remove the battery.
  10. Wait at least 30 seconds, then re-insert the battery.
  11. Plug the AC adapter back into the computer.
  12. Let the battery charge again until the battery status light turns green or otherwise indicates a full charge, again.
Repeat this procedure, starting from step 1, at least three times. Each time, check to see if the computer runs longer from its battery than the previous time.
Battery Conditioning:
IMPORTANT!!
Interruptions in the charging cycle can be responsible for an issue called "memory effect" which may reduce the battery's charging capacity. Whenever you suspect the battery performance is not at it's optimum you should try using the following "Battery Conditioning" procedure.
Before you start: Turn off your battery saving features temporarily.
***IMPORTANT*** Repeat the following steps 2-3 times!
  1. Unplug the power cord from the computer
  2. Turn the computer on and let it run until it shuts itself off.
    Note: Using the CD-ROM to play an Audio CD will speed the discharge.
  3. Plug in the power cord (While the system is off) charge the battery until the battery light changes from flashing green to solid green
  4. Remove the battery for 30 seconds and then replace it.
    Note: If the battery light isn't lit, wait a few moments, if it still does not light check your power connections.
  5. Continue charging the battery until the battery light turns solid green once again.
    **REPEAT THIS PROCEDURE 3 TIMES**
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 04, 2008 | Computers & Internet
My camera stopped working after downloading pictures
Do you think since the camera was plugged in so long that your battery may have died.
May 18, 2017 | Cameras
Dell AS501 flat screen monitor
The front panel switches seem to be the culprit.
If you are technically sound you maybe able to solve problem by opening monitor and clean front panel switches or replace them.
Samir.
Feb 28, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
Canon IXUS 70 Downloading to computer.
I've Canon IXUS 70.
My camera is full with images.
I can't download images to my computer.
Pls help me that:
How can i download the images from my camera into my computer.
Thanks in advance.
srinu
Dec 07, 2007 | Canon PowerShot SD500 / IXUS 700 Digital...
Olympus FE-4000 Digital Camera Logo
42 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
