Question about Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
Bosch 24 in SHU66C05UC/14
Dishwasher not cleaning - stuff on plates.  Power scrub seems to be the only cycle that works sometimes.  Opti miser not at all.  Detergent dispenser not opening.  One repairman ran some tests - said needs new dispenser, control module & heater according to error codes - said it is shorting out but didn't say what caused it - dishwasher or other.  Other repairman said he would get a new dispenser and a water pump because he doesn't know what could be wrong.  Unit is 3 years old.  Help!  Can you tell me how to run diagnostic tests so I can see for myself.
  • 2 more comments
  • prutter Jul 08, 2008
    Help! Can you tell me how to run diagnostic tests so I can see for myself. If one guy can punch in error codes and tell me what is wrong then I should be able to. He did not dismantle anything. I am equipped to do so. Dishwasher not cleaning - stuff on plates. Power scrub seems to be the only cycle that works sometimes. Opti miser not at all. Detergent dispenser not opening. One repairman ran some tests - said needs new dispenser, control module & heater according to error codes - said it is shorting out but didn't say what caused it - dishwasher or other. Other repairman said he would get a new dispenser and a water pump because he doesn't know what could be wrong. Unit is 3 years old.
    I want to add I am not equipped to dismantle dishwasher - that is why I pay a repair person.  I just don't want to be duped and I don't want to call another person because I don't know who to trust.
  • prutter Jul 15, 2008
    Still needing the codes to punch in for my particular model.
  • Anonymous Jul 22, 2008
    soap dispenser is not opening
  • 2,071 Answers
WHAT IS WRONG WITH YOUR DISHWASHER?
Bosch 24 in SHU66C05UC/14 - small_9_26.jpg For a detailed Dishwasher illustration, click below.
redarrow.gif Built in
Warning!To avoid personal injury or even death, always disconnect yourappliance from its power source--that is, unplug it or break theconnection at the circuit breaker or fuse box--before you do anytroubleshooting or repair work on your appliance. Also, because somecomponents may have sharp edges, use caution while working on yourappliance.
There's an error code on the digital display
It doesn't work at all
It cleans poorly
There's no water entering the machine
The water doesn't drain from the machine
It's noisy
It leaks
The dry cycle has problems
The door has problems
The cycle doesn't complete
I see an error code
The detergent cup doesn't open
The cycle times are too long
Posted on Jul 15, 2008
  • 6,487 Answers
Some diagnostics....
The combination of LED lights to be found on this example can be found here.
Led 1 Intensive, Led 2 Normal, Led 3 Eco, Led 4 Fast, Led 4 Prewash, Led 6 Delicate
Led lights 3 - Eco Overflow or overfilling
Led lights 4 - Solenoid Valve. This is the valve at the rear of the appliance that allows water into the dishwasher. Inline filter blocked or solenoid sticking.
Led lights 5 - Thermistor. Heat protection circuit for upper and lower heat settings.
Led lights 6 - Heating timeout. Element not heating or not getting to temperature.
Led lights 3 + 4 - Draining Timeout. Drain pump taking to long to drain down.
Led lights 4 + 5 - Filling Timeout. No water. Have you isolated the water or maybe the inline water filter is blocked. Take the hose connection off from the dishwasher end and look in the inlet to the solenoid valve.
Led lights 3 + 5 Recirculating pump not working. Check the filters.
Led lights 4 + 6 Heating Circuit. Program stops mid cycle and waits for the element to heat up
Hope that helps....
Posted on Jul 08, 2008
    Master:
  • 497 Answers
Http://www.applianceaid.com/boschDW.html
i hope this link helps you diagnose your problem
Thank you for using Fixya
  • 818 Answers
My bosch dishwasher is stuck on a cycle, it keeps on flashing and won't start
try shutting off the power at the breaker panel and wait a minute sometimes rebooting will clear up a problem
Oct 27, 2014 | Bosch SHE6AP15UC Ascenta Evolution Series...
How to run self test on bosche dishwasher
Here is an excerpt from "Bosch Dishwasher Troublesoooting".
Running a Test Cycle
Bosch dishwashers have a test cycle which can be run as a troubleshooting measure. The method to run this test cycle is similar across the Bosch dishwasher range so if your dishwasher features seems different from those described below then try experimenting, as the process is fairly straight forward and will be very similar. Bosch dishwasher model numbers are usually found around the top or lip of the door. One of the most common differences between dishwasher models is simply the names of the buttons. For example in the first example below, POWER SCRUB PLUS and REGULAR WASH may be called WASH and ECO depending on your dishwasher model and the country you are in. The other key difference is whether your dishwasher has a display panel (which can display error codes) or not (in which case a program light will illuminate to tell you the fault.
To run the test cycle hold down the POWER SCRUB PLUS and REGULAR WASH buttons. Whilst held down press the ON/OFF button. The lights above them should flash. Now you can check the status of each dishwasher program by pressing its button. Now you can run the full test cycle = Press the POWER SCRUB PLUS and REGULAR WASH buttons again. The dishwasher will start up and when the cycle has ended one, if you have no display panel on your dishwasher model the indicator lights will illuminate if a malfunction was detected as follows -
CLEAN - A temperature sensor fault. If this is the case then the test cycle will be very short as the dishwasher will terminate the test once it's been detected.
RINSE/DRY - A water sensor/filling fault. If this is the problem then the test cycle will not complete as the dishwasher cannot detect the right level of water, the dishwasher will just keep filling and draining again.
WASH - A heating fault. Check your heating element.
If you do have a display panel on your Bosch dishwasher then after the cycle is complete an error code will be shown if a fault has been detected. The error codes are as follows -
0 - No errors have been detected.
1 - A water sensor/filling fault.
2 - A heating fault.
4 - A water filling fault. This can also appear as F on the display during a normal cycle.
8 - A temperature sensor fault.
When troubleshooting your Bosch dishwasher, running the above test cycle is a good start in diagnosing the problem and should give you an idea of where the problem lies with your Bosch dishwasher and what fixes and repair are in order. Our general troubleshooting page will give you some ideas on other things to check on your dishwasher. Good luck!
Mar 29, 2013 | Bosch 24 in. SHU5305UC Built-in Dishwasher
There is a motor sound on my Bosch SHU66C05UC/14 dishwasher but it does nothing. The display seems ok and I have done the
Your dishwasher is in flood safe mode. There is water in the pan beneath the wash tub. Remove the lower access panel and dry all of the water out to restore operation, at which time you will need to address the leak.
Mar 02, 2012 | Dishwashers
Bosch dishwasher model SHX46A why does the on/off switch and lights stay on while the dw stopped running?
The dw was not quite running. It does pause between cycles. The power scrub cycle means that you had the machine on the longest of all cycle choices. There's almost always a light and a normal cycle. The pots and pans cycle is a power scrub option. Yes all the lights would be on until they switched to a different part of the cycle. Do you have a DRYING light? That would be the one to look for as far as the dw being finished. :)
Nov 20, 2011 | Bosch 24 in. SHX46A05 Stainless Steel...
I have a bosch dishwasher, SHU535E05UC/14. The
the spray arms are not rotating check they spin freely if they do remove them and clean any residue food deposits blocking holes for water spray.
Jan 15, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Our shu66c05uc Bosch dishwasher does not dispense the detergent.
Most likely the solenoid that operates the lever on the detergent door is faulty. Only solution is to replace the whole dispenser, unfortunately. It is possible that the controller is not activating the dispenser but less likely.
Jul 21, 2009 | Dishwashers
THe dishwasher will not start.
what cycles does your dishwasher offer? there is a cancel reset. its usually holding scrub and econo wash at the same time while the power is on will activate the cancel drain mode then reset the dishwasher next time you power it. if that doesnt help then let me know your full model number and i will tell you exactly which buttons to press.
your model should read:
SHU66C05UC/??
what numbers are ??
Mar 03, 2009 | Bosch 24 in. SHU66C05 Stainless Steel...
Bosch Dishwasher stuck in "Scrub Cycle"
The Control module on our SHU43 blew this morning and when I took it apart to get the module out, I discovered why two of the Cycle selections no longer worked..... the little plastic lever that pushed the switch behind the fascia button - had broken off. You may have the same issue. It's not a cheap fix though as a new module is gonna cost me $175.
Mar 25, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher Logo
985 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
prem mathew
bosch5
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
