Question about Humminbird 755c GPS Receiver
Hi there . when i put my longs and lats in to record a mark as i get to the last degree the sreen flashes invalid longitude and i have to restart the unit to het out of the setting. can you help
  • 29 Answers
I have not heard of this problem before. I would suggest updating your software on the unit. I would also make sure that lat and long format is the same as what you are trying to input into the unit. You can change the format under the setup tab in the menu to match the number that your trying to input in the unit. To update the software in the unit you can go to Humminbird.com and register your unit and create an account. You will have to have the unit type and the serial number to do this. This is free of charge.
Posted on Jan 03, 2011
The GPS on my Cybershot DSC-HX9V doesn't provide the correct Latitude and Longitude.These details are recorded within the properties as 52; 34; 9.163000000000063 and 2; 19; 5.354999999999995634The position...
The positions are close, but they do appear to be in different units. 52 degrees 34 minutes 9 seconds is 52.569167 degrees, and 2 degrees 9 minutes 5 seconds is 2.318056 degrees.
Mar 03, 2014 | Cameras
I have a Garmin etrex legend, and when I enter the Lat and Long for geocaching on either the lat and long, I cannot enter the numbers 5 thru 9 into it. An example is, I can enter N 39-7.178. The blank...
Go to Main Menu > Setup > Units > Position Format > change to hddd.ddddd format. This is the decimal format which is widely used by geocaching forums.
Page 44 of your User Manual:
http://static.garmincdn.com/pumac/eTrexLegend_OwnersManual.pdf
If this solves your problem, please come back and rate our solution. Thank you.
Sep 19, 2010 | Garmin eTrex Legend GPS Receiver
Latitude & longitude
Here is the way to find the Lat/Lon Info on TomTom.
Tap on main screen. You will be taken to Main menu 1 of 2. Tap on the arrow. You will move to Main menu 2 of 2. Tap on Browse map. You will see the lat/Lon info on the bottom left hand corner (of a selected location) Tap on another location and you will see that the lat/Lon will change to that of the newly selected location. You can use the slider on the right hand side to zoom in or zoom out so that you can get the Lat/Lon info of far off locations. However, for this purpose, google maps would be a better option. But if you know the address, use the find button which will give you easier access to Lat/Lon info.
May 02, 2010 | Tomtom XL 330S GPS Receiver
Where do i find the satalite coordinates for bell expressvu in california
For Nimiq 91W- ExpressVu Standard based on Los Angeles coordinates are Longitude 91... 34 N Lat, 118.25 W Lon
For Nimq 82W-ExpressVu HDTV and international based on Los Angeles, Longitude is 82... 34 N Lat, 118.25 W Lon
http://www.kusat.com/install/calculator.php
Dec 08, 2009 | Toshiba Satellite R10-S802TD Tablet PC
Garmin Hand held GPS Operation
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} It’s hard to cover all the details in a forum like this but I’ll give you a quick primer. I can send you a powerpoint presentation that explains it in a little more detail. To really learn how to read latitude and longitude you should pick up a copy of “Chapman’s Piloting and Seamanship.”
The earth is divided into parallels of latitude and meridians of longitude, also known as lines of position.
Latitude is measured north and south of the equator, with the equator represented as 0 degrees, and the poles being represented as 90 degrees North or South. Latitude lines are paralel to the equator. For example, if I was at the equator I would be at 0 degrees. If I traveled exactly 60 nautical miles to the north, I would be at 1 degree North, and if I traveled another 60 miles I would be at 2 degrees north. Your GPS display will preface the Latitude measurement with an “N” for positions North of the equator and an “S” for positions south of the equator.
Longitude measures your position east or west from the Prime Meridian, which is a line represented as 0 degrees that bisects the earth from north to south and passes through Greenwich England. Halfway around the earth at the International Dateline Longitude is 180 degrees. Measuring Longitude is a little more complicated because the lines are not parallel and requires an accurate clock (your GPS) to compare time at your location relative to the time in Greenwich England. Your GPS display will preface the Longitude measurement with a “W” for positions west of Greenwich and an “E” for positions east of Greenwich.
To make more accurate measurements each degree is divided into 60 minutes. Because the lines are parallel, 1 minute of latitude is equal to 1 nautical mile. Each minute can be further divided into 60 seconds. Each second is roughly equivalent to a distance of 100’ Instead of seconds, the default setting on your Garmin breaks the minute down into tenths, hundredths, and thousandths for meven more precise measurements. Because they are not parallel, lines of Longitude are measured the same way, but the distances vary depending on how far north or south of the equator.
To find out where you are with a GPS, you need a map that shows lines of latitude and longitude on it. The lines will be labeled on the map or along the borders of the map. Most nautical charts show the latitude measurements along the right the left border of the map. Longitude measuremnts will be shown along the top and bottom edges.
Dec 16, 2008 | Garmin GPS 126 GPS Receiver
I do not know how to load latitude and londitude into my tomtom. I am going to Bad Liebenzell in Germany (with caravan) The Latitude is 48.87329 (I do not undestand that because lat/long is usually...
Latitude is N or S, longitude is E or W, correct.
When entering degrees, minutes and seconds, you dont have to type the double apostrophe at the end off seconds, the device will understand...
ALT and LONG can also be seen as decimal degrees,
as in your case N48.87329 E8.6923
The TT device understands them both, just type them in....
Sep 03, 2008 | Tomtom GPS
Changing Qiblah of Casio prayer compass CPW-310
I have the same watche you can find the manual here :
http://www.usersmanualguide.com/casio/watches/qw-1044
May 07, 2008 | Watches
Toggling between lat/long and grid references
I eventually solved the problem by firstly doing a restoration of default settings. This allowed me to toggle but it was between two different presentation styles of latitude and longitude. To restore the grid co-ordinates option I went to main menu, the Setup, then then toggled to location and re-selected UTM UPS as the location format.
Apr 27, 2008 | Garmin GPS 72 GPS Receiver
Latitude longitude
Create and save a waypoint for any location then update that waypoint with the lat/long you were given (just click on the lat/long and key in the new coordinates).
Apr 17, 2008 | Garmin eTrex Legend GPS Receiver
Humminbird 755c GPS Receiver Logo
67 people viewed this question
Top Humminbird GPS Experts
Mike Marcotte
Mike Marcotte
Steve
Steve
Jerry Greenberg
Jerry Greenberg
Are you a Humminbird GPS Expert? Answer questions, earn points and help others
