Question about Belkin (F5D5231-4) Router
Wireless router security
I have a wireless home network to run three laptops,and i have been given a
belkin router from a freind,all my computers have found the router to work
wirelessly,but i am now showing that this network is unsecure and i cant work out how to secure the home network to stop anyone else using it,please help as i have tried everything i know which is quite limited
many thanks
  • thbutts Jul 21, 2008
    How do I setup my wireless network to be a secured password network. It currently says unsecured and can be accessed by anyone in range.
  • 550 Answers
Http://192.168.2.1 from a connected pc (use a cable you dont want to change settings over wireless and not be able to change it back) will start the router web interface, where you can read the help screens on how to, then set the router to one of several secure modes that it supports
The wizards are pretty good
Posted on Jul 10, 2008
I have a Belkin N wireless router. It's all set up but it shows as not being secured. How do I secure it? Model F5D8233-4v3
Connect a LAN cable from Belkin to your laptop/computer's LAN port, open a browser on your laptop/computer and enter the Belkin's configuration URL. http://192.168.2.1
The default PW = blank (just press Enter) You can now change the default admin password.
You can now configure the wireless settings to protect your wireless network and Internet from unauthorized access. Now configure the wireless card in your computer/laptop with the router's wireless settings. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Jan 08, 2013 | Belkin Computers & Internet
Belkin N1 Wireless ADSL2 Model # F5D8631-4 Router router default address (192.168.2.1) is not opening, even i have reset the router
Dec 09, 2012 | Belkin Computers & Internet
I set up wireless network for my boss, using Belkin wireless n router, so the 3 computers can connect to the same wireless printer, and she can access this network with her home laptop. All is well except...
If possible, to rule out the modem as the cause, connect a computer directly to the internet(bypassing the router entirely). If it is the router, you could try flashing it back to factory defaults and reconfigure. Log into the router's firewall feature and see if port 443 is blocked to the outside--this could cause https connections to fail.
Mar 04, 2011 | Belkin F5D8236-4 Router
Hi I have just installed a brand new Belkin wireless router and it works great with all computers and laptops in the family (including Apple products) apart from my daughters laptop...she has a toshiba...
Check the main computer you set up the network router with...you may need to go to the network status and tasks in control panel...click on this...then you will see a map of all the network devices connected...find the belkin router and click on it...in this window there should be a tab called wireless properties..click this...the wireless properties first page should have the wireless SSID name listed here...and if you click the security tab then the security type and network key are displayed here..You need to write down the SSID, security type, and network key and make sdure the toshiba laptop setting for the wireless network are exactly the same. There may be a link on the first page of the wireless securities saying copy to usb drive..you can use this to copy all network settings to and then transfer these settings in to the toshiba by using the network setup wizard.
Jan 04, 2011 | Belkin (F5D8231-4) Wireless Router...
The Belkin wireless router was working for our home computer and one laptop, but the other laptop was not working. Later we figured out the laptop that was not working had other issues, but after calling...
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Oct 24, 2010 | Belkin (F5D7231-4) Wireless Router
I have a belkin router set up in my home and I just purchased a 2nd laptop but I am unsure how to add this new laptp to the connector
If you router is already set up and you want to add a new computer, you don't need to run the set up CD for the router again.
If you want to add a new wireless device ( laptop or any other wireless device) to the network, then you should know all the wireless settings of the router. What wireless settings do you need to know ?
You should know the wireless network name ( SSID ), wireless channel and the wireless security password
( network key ). Once you get all the wireless settings of the router , you will need to connect to the wireless network on the computer. when you try to connect to the network , you will see your wireless network in the list. You just need to select your network and connect to it. If it is secured then you will need to enter the network key and you will be able to go online.
To check the wireless settings of the router , you will need to access the router set up page. On the set up page you will find all the wireless settings of the router.
Click Here for step by step instructions
Dec 27, 2009 | Belkin (F5D7231-4) Wireless Router
Having problems connecting a lap top computer to the internet.
Connect the router directly via lan to your computer.
goto setup of the router: usuallly via the ip-adress of your router (see manual, usually: 192.168. ***.*)
Now look at the network security-settings .
May 11, 2009 | Belkin (F5D8231-4) Wireless Router...
Cannot connect new laptop to wireless network. Belkin Wireless N
The wireless settings on the laptop and the router should match. To check the settings on the router you need to access the setup page by typing 192.168.2.1 in a web browser's address bar.
By default the password is blank.
Click the Wireless tab. And take note of the SSID or wireless network name.
Go to Security, then Wireless. If the wireless security is enabled, copy the network key or security key.
On the wireless computer, you should detect SSID and if wireless security is enabled, connect to it with the correct security keys.
Hope this helps! Good luck!
Feb 22, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Connection problem
don't shout at me, but many of the older compaq laptops did not come with a wireless nic installed, and the ones that did sometimes did not support G let alone N.
If able you need to check that the Wireless NIC if installed/avaliable supports your wireless router or most likly the otherway round.
firstly I would try removing any USB wireless adapters that you may have in use from one of your other computers and try it in the compaq, if sucessful you know that it is not your setup of your home network at fault.
Sep 02, 2008 | Belkin (F5D5231-4) Router
Belkin (F5D5231-4) Router Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
