Question about ASUS A7N8XE Deluxe Socket A Motherboard (MOTAS19)
Sata port is not working properly - ASUS A7N8XE Deluxe Socket A Motherboard (MOTAS19)
    Sergeant:
  • 223 Answers
Hi sup, i am happy to assist you , you have more then sata port in your motherboard usually use any of that sata port , if none of them work properly mean buy USB sata port available in market.
Good luck ! if you think your problem solved don't forget to rate
Posted on Jan 01, 2011
Dell Optiplex 755 - 2 sata ports (2&3) not working on motherboard. They have been switched to "on" in the bios, but will not recognize sata HDD or sata DVD. Only ports 1 & 2 are working, so I now have a...
hi There.
this is all i could find out from the internet so not sure if this will help you out.
(I went into BIOs again after I looked the SATA port over on the motherboard. The SATA ports on the motherboard are listed as 0,1,4,&5. In BIOS the SATA ports are 0.1.2.3.4. & 5. I have been trying to turn on 2 or 3 as they are the next ports and never tried 4 or 5.
When I turned on 4 and 5 everything is working fine.
Why do they list SATA ports 2 and 3 when they are not present on the motherboard)
or see if this link helps you.
Dell Optiplex 755 2 sata ports 2 3 not working on motherboard Google Search
Dec 15, 2017 | Computers & Internet
I wish to upgrade my Maxtor 32049H2 HDD (20gb) to a Maxtor DiamondMax 10 6B300S0 (300gb) HDD, The KM400-M2-3.0 Motherbourd specs indicate that the HDD is compatable other than the cabling to the Newer...
The new HDD uses a SATA data interface as well as a SATA power interface. You will need a SATA cable as well as a power supply that supports the SATA power connectors. Since this is an older machine you will probably need to buy a SATA cable and a Molex to SATA power connector. This should cover any cabling issues that you are having.
May 05, 2011 | EliteGroup KM400-M2 Motherboard
Intel 865GSA
Looking at the vendors I buy parts from, all the cards I saw offer both SATA and IDE ports. Here's one as an example. You definitely want SATA capability as most newer drives are only being offered as SATA, so you'll have a wider selection to choose from.
Another possibility: start fresh with a new system board. If the onboard IDE controller isn't working properly, this may be a warning sign that other problems follow. You might be better off spending your money on a new mobo that already supports IDE and SATA.
Hope this helps you make up your mind. Thanks for using Fixya!
Feb 20, 2010 | Intel 865G Motherboard
I have transcend 2.5 usb store jet sata 120 gb hard drive which is not working , it only glows up the blue light on it
You need to plug it up to a USB 2.0 port not on a USB 1.1. There are many instructions to tell whether your USB is a 1 or 2 version but USB ports on the back usually are USB2 versions than the USB port on the front of your CPU.
The difference between both USB 1 and 2 for your Portable HDD is that USB 1 only uses 5volts power rather than the USB 2 which uses 8volts to properly revolce your SATA HDD.
Hope this helps. Thank you for using Fixya.
Jan 13, 2010 | Transcend USA 120GB Storejet 2.5" SATA -...
Connection of DVD writer having SATA cable
The blue ports on this motherboard are SATA ports.
This is a SATA cable:
Mar 30, 2009 | Intel Motherboard
Sata hard drive
Check to see if your motherboard has a sata controller on it. The user manual will tell you. You can get a new on on asus.com. If it does support it, you will need sata drivers for it which you can download from the website as well.
If it doesn't work you can add one external by picking up and external drive case for sata controllers. Then all you need is a spare USB 2.0 port. Make sure you get one with a power supply for it because at that size getting 500 gig to work will require extra power to perform properly.
Aug 05, 2008 | ASUS P5LD2-VM Motherboard
Hard drive..
Using SATA, there is no Primary/Secondary Master/Slave connection. Each HDD is connected to One port straight. As for partitioning, you can either use Fdisk or you can boot straight from the Windows CD and create Partitions and load Windows.
Sep 11, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
44 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
