Question about Sony Bravia KDL-46V4100 46 in. LCD HDTV
How do i get onto pc input mode becaus i cannot find it on my tv
    Problem Solver:
  • 4 Answers
Connect your PC with your HDMI cable to both your TV and Laptop.
Press the input button on your remote, then scroll down from TV Mode to your Laptop. It should show up on your menu box on TV screen when you press the Input button.
Hope this helps. I originally had the same problem before I figured it out.
Posted on Jan 09, 2011
Put a tv onto av mode without using the remote?
Some older tv's you need the remote to switch the input mode,
most tv's your can simply go threw the chanel up and down and av Will be in between channels? Hope this helps?
Mar 09, 2015 | Televison & Video
Won't channel up and down, stuck in input mode
Good morning Cheri
try restarting the tv, just disconnect all electricity for 30-60 sec.
connect again. If that does not work, Try set- up on the menu, if you get the apparatus to obey you and leave the input mode.
If that does not work I always restart the router and "exchange"box,
enjoy your day
kolbrub
Mar 25, 2014 | Sanyo DP50749 50 in. Plasma TV
I have a sony trinitron and trying to hook up to a dell laptop latitude to watch nexflick.I have a 7 pin s vedio cable to 3 rca.what is the problem that the picture not showing up?
Did you Press the FN (Function Key) + F8 keys on the laptop to display the video on the Sony? Press the FN Key and hold it while you press the F8 Key, this toggles the video into 3 different modes each time you press the keys. The modes are display on laptop only, display on laptop & TV or display on TV only. Also Make sure you have changed the TV's Input Source so that it can know to receive a signal from the laptop. On my setup I go S-Video to S-Video because my tv and laptop have S-video, therefore I tell the TV that the input is S-Video. I installed a VGA to VGA at an Event Center because both the TV and Laptop were using VGA, so I set the Input on the TV to PC since it did not have a VGA Option.
Mar 16, 2012 | Dell Computers & Internet
Sanyo TV 27 inch stuck on Video mode. It reached this mode by me pressing the input button on my (GE) Universal remote, not knowing it would put it in Video mode and then accidentally pressing enter to...
Universal remote alway work only the basic for the tv.Beyond that will have problems or stuck in some input or modes.Sorry i can't help u, because i don't know what is the reaction to ur tv by the universal remote,must use the universal remote again tries all the buttons like video modes or input botton.Or take the battery out like 20 mins of the universal remote to erase ur tv codes enter it again.Tries those buttons u pushes before,see if u can get out the video mode.All else fail.Try website like Remotes.com to buy the tv original remote to use.
Jan 20, 2011 | Sanyo DS31520 31" TV
Hi, I purchased a Toshiba M363 in China. I am trying to connect it to my TV which only has HDMI connection. Although I have a HDMI port on my laptop which is also connected, I can't get my monitor to...
Have you turned your TV via the Input or Source on your TV or remote to HDMI? Also look at your "F" keys to see which one switches the computer to TV mode. Generally on Toshiba's it's the F5 key. Try pressing "Fn + F5" simultaneously while you have the TV set in HDMI mode.
Mar 20, 2010 | Toshiba Satellite Pro L300 Notebook
I have a Samsung LCD TV, model # LN40A450 with a PC input. I connected my Dell Vostro 1310 laptap to the PC input and I consistently get a "Mode Not Supported" message on the TV screen. Why? I had a...
You TV will only accept specific signal formats (modes) through the PC input. Check you user manual for compatible modes. You then need to set screen 2 (your laptop VGA output) to 1 of the compatible formats (PC display settings). A common format/mode example would be 1024 x 768. Try it out and see if you get a picture. You can then increase the resolution 1 at a time to find the best format/mode for your purposes. I hope this was of some assistance.
Dec 29, 2009 | Samsung LN40A450 LCD TV
How do I record onto a DVD from a video camera
connect camera to dvd on the dvd were you connected into will have (e.g EXT or AV 1-2 or 3 printed on it) you should put dvd on to that input mode by pressing input/saurce on remote then put tv on the input mode you watch dvd on
to record press on remote
Dec 13, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
How to connect tv to comcast cable box
If you only have the comcast receiver and a TV, take the input (wire from outside the house or outlet on wall) and screw that onto the input of the comcast receiver. Take another wire (or RCA, component connecters or whatever means the box and TV provides) and go from the output of comcast receiver to the input of the TV. Set the TV input mode (on the TV itself or by the remote) to whatever mode you hooked up the cables to (video 1, aux, video 2, etc) and you should see a picture. From there use the comcast remote to change channel. If you use the round cable (rg56 or rg59) you will not need any other connections between the TV and the box. The video and audio are broadcast on the same line. If you use RCA (yellow red white) connectors, yellow is video, white and red are audio) you will need all three wires from comcast receiver to TV. I hope this helps and good luck!
Nov 18, 2009 | Audio Players & Recorders
Problems with Jwin JV-DTV30 30 in. HDTV-Ready LCD Television
This sounds like micro glitch try unpluging the tv and all controlable inputs (PC, iLinks, or other such devices) wait 5 min then plug the tv only in and see if you have returned functions. if you should read the manuals of those devices to see if the control functions can be turned off.
Jan 07, 2008 | Jwin JV-DTV30 30 in. HDTV-Ready LCD...
Video Mode - Orion 27" TV - Model stv2555A
VICTORY! Had the same problem with my Orion model FTDV2004. Lost the remote and couldn't program a universal remote to change the input to AV. After a day of reading posts, I just started pushing the channel up button. Somewhere past channel 115 the "Line1" and "Line 2" inputs showed up.
Sep 26, 2007 | Televison & Video
Sony Bravia KDL-46V4100 46 in. LCD HDTV Logo
195 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
