Question about Sport & Outdoor - Others
Need to take apart to move to another house and will not fit through the door.thanks mark
  • 784 Answers
What is it that you are trying to take apart and move ?
c...
Posted on Jan 01, 2011
I have a WESTINGHOUSE WSE7000SF side by side
Yes, they can and there will be a wayer line on the freezer door side that will also need to be disconnscted at the bottom.
Sep 21, 2014 | Refrigerators
Tip
How do you completely remove the freezer door? There is a waterline running...
Many people often stress over laying a refrigerator or freezer down in the back of a truck in order to move it. It has happened many, many, times that one of these appliances is laid down in order to move it, only to find that the compressor is ruined within a few hours after having plugged the unit back in.
By the same token, it is hard to just dead lift one of these appliances into the back of the truck without tipping the unit on it's side.
The purpose of this trick, or tip, is to avail anyone of what to look for should they need to move one of these unit's.
The reason the compressors fail is lack of oil in the compressor, caused when the compressor is oriented where the oil can go run into the disharge tube which is headed to the condensor coil. Most all modern domestic refrigeration compressors are built as where the enclosure is at the condensing pressure, which is why they get real hot when they run. The high pressure gas is easily pushed into the condensor as the compressor runs. But, if the appliance that the refrigerator is in is tipped over where that tube is on the bottom, then the oil runs in there as well. And when the appliance is stood back up, the piping usually does not allow all the oil to run back into the compressor. If the compressor is started before the oil has a chance to run back, then it get's pushed by the hot refrigerant further into the condensor coil, and on to the evaporator where it becomes cold and thick, to the point that it doesn't want to return to the compressor. This makes the compressor run on low oil, and after doing this for a few hours, it seizes up.
So, in order to lay the unit down, all you need to do is look at the compressor tubing. THere will be three pipes or tubes coming out of the compressor. On eis short, and crimped, then soldered closed. That is the service tubing where the unit is charged at the factory. One is the suction tubing that is the tube returning from inside the refrigerator. And the last is the hot gas discharge tubing, going to the condensor coil. In most all deomestic refrigerators, the suction and discharge tubes come off the same side of the compressor, which is the right hand side of the compressor as you stand at the back of the refrigerator looking at the compressor. That means if you lay the appliance on the left hand side, when standing in the same position, that oil will not have any place to run to, and will stay inside the compressor. You can lay or tilt the appliance on that side all you want, aadn never have any issues when starting the unit up after moving. And you can start tyhe unit up immediatley. You don't have to wait for 8 hours or anything.
Now, if you find you did an oops and laid the applicance the wrong way, then be concerned, there is a way to save the unit. Stand the unit up and wait for 6 hours or so before pluggin the unit in. Plug it in, and allow to run for 2-3 minutes. Unplug, and let it sit for 5-10 minutes. Repeat this for 8-10 times, then allow it to run for 30 minutes or so. DO this a couple of times, and you should be good to go.
on Feb 07, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
We have recently installed this lock, the key works to unlock and lock the door but the keypad function does not turn the cylinder , we hear the motor working, trying to unlock/lock, but the cylinder is...
As long as you can hear it trying to engage the lock I would say that you need to adjust the strike plate in the door frame for a more precise fit' You can use your key to lock the door and see if you feel any rough spots when it is engaging the strike plate.One easy way to tell where it is hitting if you can't see it is to use a magic marker and mark the strike plate. Try to close the lock with the keypad after the ink has dried. If it is hitting the strike plate it should leave a mark in the ink so you know which way you need to adjust the plate.. You can either move the entire strike plate or you can use a rat tail or round file to make it fit. If you have a dremel tool they work well with a metal circular file bit.Hope this helps you. Thanks.
Aug 17, 2011 | Weiser Lock Powerbolt 1000 Lock
My dishwasher will not close. It appears that the handle will not latch on the metal fitting of the washer. When I push on the handle it doesn't seem to show any resistance. On any other latch you...
the handle is in the closed possition even when door is open,. you need to sepperate the door front from the door back........ just undo the few philips screws.....the inside of the door will pull apart... just prise the catch back to the open position...... rescrew the door....job done........
cheers
Mar 24, 2011 | Whirlpool Dishwasher Handle Mount 67006113
Wma44 hotpoint washer. Did a wash as normal and
Sometimes a weak or broken spring in the door handle can be the cause of the problem, but you would have to take the door apart to check this.
If you have already fitted a new door lock, then chances are it is the control board, but I would check the door handle first.
Jan 30, 2010 | Hotpoint WMA44 Front Load Washer
Pulled of doorknob, all the peices fell out and now i cant put it back together
If this is an inside door from an old house, just take another one apart very slowly to see how the pieces fit. If this is an an outside door from a newer house, you might want to just buy a new lockset and follow the directions carefully. I assume you took it apart because it wasn't working anyway.
Jan 04, 2010 | Top Knobs M826 Door Pull
I am moving and my treadmill won't fit thru the door
Follow the steps from the user/assembly manual in reverse. Find the manual here:
http://us.home.lifefitness.com/resources/content/8/2/0/documents/T3%20Manual.pdf
Installation begins around page 9
Aug 29, 2009 | Life Fitness T3 Treadmill with Advanced...
Removing fridge door?
Try opening the doors and moving it through the doorway with the doors open? If you have the room twisting the fridge around the doorway with the doors open my work.
Jun 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Won't fit through door - taking it apart
remove the 3 screws in the arm trim cover and the harness unplugs there and the other wires are screwed to the frame right there. Philips head screws.
Mar 20, 2009 | Bowflex Treadmill Series 7
TOO BIG TO GET INTO MY FRONT DOOR
Take off rear cardboard back and then take off back cover-
BE CAREFUL--the mirror is inside! Then move into house.
Clean out before reassembly--Dust RGB lens caps with soft
cloth, Knock down any spider webs and clean mirror with glass
cleaner & paper towels.........T.
Oct 25, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Sport & Outdoor - Others Logo
97 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
