Question about Electrolux Refrigerators
Model ENB 3851X Fridge / freezer top and bottom. Freezer alarm going off. No manual in English.
  • 125 Answers
SOURCE: Admiral Side by Side Fridge is warm at top, cold at bottom
CHECK TO SEE IF THE EVAPORATOR FAN MOTOR IS RUNNING, ITS IN THE BACK OF THE FREEZER SIDE, MOTOR MAY BE BAD OR SOMETHING COULD BE BLOCKING IT...
Posted on Feb 07, 2008
SOURCE: Fisher & Paykel Model number 402B S.Steel. Bottom frezer top Fridge.
My Fisher & Paykel Model E402B Stainless Steel Fridge/Freezer has a problem. Bottom Freezer is OK but Refrigerator will not work properly, somtimes it will freeze everything now it just warm inside i have checked the the fan and the rubber holding it up has broken also the ice is frozen in the vents can you help i got someone in to fix it but he said it will cost around $600 as there might be more wrong with it, what do you suggest thanks Clare
Posted on Sep 29, 2008
SOURCE: Amana ARB2117BW - Bottom Freezer Door Won't Stay Sealed
This problem was posted in the wrong section. My model didn't have it's own, so its in ABB1927DE Bottom Freezer Refrigerator - perhaps you could create a section for it.
As it turns out, I looked more closely at the baskets inside. We had noticed that if the top basket was slid all the way forward when we closed the door that it would close better. So I looked to see if they or the slides were out of alignment. They seemed ok, but then I saw that the way the bottom basket was hanging didn't seem right - it was not quite nestled into it's retainer slot. I took the baskets out and turned the bottom one around. It fit perfectly into it's retainer slot. I then replaced the top one (it was already in correctly) and closed the door. It sealed correctly the first time. I tested it several times after that and it sealed tightly. Closing the top door did not make it unseal as it had done before.
Posted on Jan 23, 2009
  • 5 Answers
SOURCE: Fridge has become freezer and freezer become fridge
sounds like the control board i had same problem along with no light i had to have control board replaced working fine now
dmb
Posted on Feb 09, 2009
  • 686 Answers
SOURCE: fridge is warm even when i adjust temp. control.freezer is good.
if your fridge has 2 set of dials one numbers and the other letters than you need to adjust the dial that has letters on it. If the fan in your freezer is not blowing, then it won't force the cold air from the freezer to the fridge. Make sure fan blows then adjust the letter knob.
Posted on Feb 17, 2009
Water leaking bottom of crisper.
You may just have to manually defrost it.
Dec 16, 2014 | Fisher Refrigerators
The fridge alarm will not stop. The fridge compartment is not cold and the freezer is just freezing. Since the problem started, have the fridge turned off for 3 days. Defrosted the freezer, turned it...
this alarm is activate if the temp. of the fridge rises and because the freezer section is full of ice form thats why affect the circulation of cold air. try to check the defrost timer if yuor unit have or heater if working if dont have defrost timer or heater try to lessen the setting of your themostat to cut of unit after reaching desired temp. or conduct weekly defrost manually.
Feb 12, 2011 | Fisher and Paykel Active Smart E522B...
Zanussi fridge freezer alarm keeps sounding
If the refrigerator and freezer are both working properly. Then the only problem would be the alarm, It's either the placement of the alarm thermometer or the alarm thermometer is stuck closed.
Mar 15, 2010 | Freezers
I have a kenmore top freezer refrigerator model 253 about 1 1/2 years old. The fridge door sticks at the bottom of the door and the bottom of the fridge inside. There are scratches on the fridge bottom...
i had the problem my self :)
you need to take the freezer door out then the fridg door and add small ring like 1mm to the hinges of the fridg door poot all back and see if it rais the door a bit....
what i did is on the top of the freezer there is option to move the door from side to side ...the plastic that go into the freezer body its a ring with long tube.. i cut the tube and use that plastic :) good luck
Jan 03, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Both Lights flashing and fridge not getting cold
I turned the fridge and freezer off using the circular dials, I then turned the unit off at the mains. Left it for a few minutes and then turned the power back on. I then turned the circular dials to "max" and then depressed the super cool and super freeze buttons to turn this facility on. This time they came on normally (not flashing) and no alarm sounded. The fridge and freezer then started to get cold. Once the unit had been running for several hours I then turned the dials to the 3/4 mark and depressed the super cool and super freeze buttons again to turn them off. Over night the fridge and the freezer appear to be working properly so I hope that my problem is solved. Maybe the unit just needed to "settle" before being switched on?
Sep 03, 2009 | Freezers
Uneven cooling in fridge and annooying alarm every 10 hours!
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Mar 28, 2009 | Fisher and Paykel Active SmartĀ® E522BR...
MIELE KFN8762SDED (SS/fridge/freezer)
No problem just use the + and - buttons when you have chosen the temp. you want just let go and that is the temp the fridge or freezer will set at.
Aug 19, 2008 | Miele KFN8762SDED Bottom Freezer...
Cannot reverse door on Electrolux fridge freezer
Basically they needed to supply an additional door mount for the left hand side of the door as well as the right hand side. Problem now sorted. Poor instructions in the manual didn't help here!
May 26, 2008 | Freezers
Viking Refrigerator problem
Try this my Mother had a similar problem, make sure the vents are not covered inside the fridgerator between the bottom and top so the cold air is able to circulate between them.
Oct 21, 2007 | Viking DDBB363 Bottom Freezer Refrigerator
Refrigerators Logo
138 people viewed this question
Top Electrolux Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
