Question about Mitsubishi WD-65833 65" HDTV
How do I update the firmware on my Mitsubishi HDTV WD 65833 to support HDCP video?
SOURCE: Mitsubishi HDTV model wd-62525 has
It has been renamed.
Posted on Mar 22, 2009
  • 58 Answers
SOURCE: Mitsubishi WD-52525 52-inch DLP HDTV ywllow warning lamp light
that means your lamp it is getting to the end of its life.
sometimes even if the lamp still good the TV will send you that message because that timer is closed to 5000 hours
What you can do is open the lamp door, closed again and the tv will ask you if you replaced it the lamp, and just say yes and that sign will go away
or just simple replace the lamp. 915P020010
Posted on Apr 18, 2009
  • 668 Answers
SOURCE: No DM Board on WD-65833
The Main Board contains the DM circuitry. And you are right, this board does not fail in the way of its predecessors. What is the unit doing?
Posted on Jul 17, 2009
  • 63 Answers
SOURCE: how much would to pay
Between 100-500 check ebay
Posted on Feb 22, 2011
Slinteriors
  • 8617 Answers
SOURCE: mitsubishi wd-52627 dlp hdtv doesn't appaer as
I have seen alot of the Mitsubishi DLPs to get very dim and the colors appear dull and the cause was almost always caused by the small front mirror needing to be cleaned due to a dust build up. If you need assistance with how to access the mirror on that model send me a email and I will send you info on how to access the mirror. The file is too large to post here. slinteriors@yahoo.com
Posted on Jun 08, 2011
How do i change the picture to fit the tv screen
Mitsubishi usually has a button on their remotes labeled 'format' and can stretch the pic to fill the screen more, but sometimes a funky picture is the result
Mar 21, 2013 | Mitsubishi WD-65833 65" HDTV
How to change the dlp chip
Go to YOUTUBE type how to change the dlp chip and your tv model and there will be a few videos.
Oct 24, 2012 | Mitsubishi WD-65833 65" HDTV
White vertical lines after changing dlp chip and lamp on Mitsubishi WD-65833. good picture in background.
had white dots on mine as well i changed the dlp chip and put it back together and got the white vertical lines i decided to check all connections and make sure the chip was locked in correctly
it was not locked in securely i reassembled and now problem solved picture looks brand new so always check connections before assuming its the dmd board
Aug 25, 2012 | Mitsubishi WD-65833 65" HDTV
Wd-65833 has black spots
This is the DLP chip failing. Contact Mitsubishi and they will provide the part but you have to pay $200 for the service call.
Apr 17, 2012 | Mitsubishi WD-65833 65" HDTV
Mitsubishi WD-65833: Reset system on my WD65833 after replacing the DMD chip. Now get a flashing code of 1-2. Any suggestions?
You are not the first person I have seen who replaced the display chip and had fubar after--1,2 is no error found.
You might want to do a little more research: Mitsubishi when changing the optical engine has a procedure so the engine can communicate with the digital circuit in the set--opps!
By the way the reset on the front is only a boot up for the set--set also has a hidden option menu for a hard reset of the entire set to factory defaults.
tried that one?
Mar 31, 2012 | Mitsubishi WD-65833 65" HDTV
I have a mitsubishi wd 65 837 and it has white and black spots on the left side of the tv , can it befixed ?
I just had this happen to my wd-65833. It is a faulty dlp chip (they call it dmd board). I called Mitsubishi and they covered the cost of the part but there is a $200 service fee for the technician, no they will not send it to you. Support Service Mitsubishi TV
Sep 06, 2011 | Mitsubishi WD-65833 65" HDTV
White Spots Streaks on DLP Screen
If you bought the set new you might just want to contact the manufacturer - if they are decent, they might just try to help you out with your dilemma.
Apr 02, 2017 | Mitsubishi WD-65833 65" HDTV
Apr 30, 2008 | Mitsubishi WD-65833 65" HDTV
WD-65833
The Main Board contains the DM circuitry and does not fail in the same way as it's predecessors. What is the unit doig?
Apr 29, 2008 | Mitsubishi WD-65833 65" HDTV
Mitsubishi WD-65833 65" HDTV Logo
502 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
