Is this a heat pump or solely a air conditioner?
  • 2,133 Answers
Model and brand/type of air conditioner plz?
Posted on Jan 01, 2011
What part number is for an
A crankcase heater is an electrical component in a compressor in an air-conditioning system, heat pump system, or chiller system. The crankcase heater is normally on all the time, even when the unit is not running, though temperature sensors and set points may turn it off when not needed. A crankcase heater's sole purpose is to prevent refrigerant migration and mixing with crankcase oil when the unit is off, and to prevent condensation of refrigerant in the crankcase of a compressor. The crankcase heater keeps refrigerant at a temperature higher than the coldest part of the system. A crankcase heater generally has the same electrical symbol as a resistor because it converts electricity directly into heat via electrical resistance. The resistance in the heater coil determines the heat it produces when voltage is applied
Apr 24, 2014 | American Standard Heating & Cooling
Duo therm heat pump blowing hot air only
relay module or communication cable from t-stat issue.
Apr 02, 2014 | Dometic 459186 Duo-Therm Brisk Air...
I am installing a heat pump, and i having 8 flashes at my green LED .
look at page 17 here is all the install instructions plus troubleshooting
x air conditioner/heat pump
operates at reduced
performance.
x Air conditioner/heat pump
operating at low stage when
expected to operate at high
stage.
x Integrated control module
diagnostic/status LED's display
the indicated code
http://www.alpinehomeair.com/related/IO-348K%208.2013.pdf
Oct 06, 2013 | Goodman Manufacturing Goodman DSZC160601...
How to tell if your unit is a heat pump or just air conditioner with electric heat strip
PTH is a heat pump. PTC is an air conditioner only. I don't believe Amana makes electric heat strip-only models based on what I see in their literature. You can just do a google search and look for yourself.
Nov 29, 2011 | Amana PTH123B25AJ Heat Pump Air...
Wife kicked on heat this morning, worked fine. turned off before leaving for work. now we have nothing. heat or air. thermostats runs a heat pump plus the air. thinking it`s got a bad swich. oh, it`s 21...
Here is a tip about troubleshooting your air conditioner or heat pump...
There are many things that can cause your air conditioner not to cool or heat...
Air Conditioner Trouble - Review the Possibilities
heatman101
Apr 22, 2011 | Heating & Cooling
Name of tablet that are put in air conditioner unit
They are called Humiditreat water purification tablets. What kind of a problem are you having with this Heat-Pump?
Shastalaker7
A/C, & Heating Contractor
Apr 13, 2011 | Friedrich YS13L33 12700 BTU Cooling, 11000...
How do I set my thermostat so that it doesn't keep going off and leaving me with no hot water .I have a Honeywell digital thermostat.
The problem is not your thermostat. It is the person who told you that your AC would be your sole source of hot water. The purpose of heat recovery is to ASSIST with hot water production and reduce the current used by your water heater. The only time your AC heats your water is when it is working to cool (or if it's a heat pump, cool and heat) your home. Turn your water heater back on and let your AC help keep the water hot. It's not supposed to do it alone.
Mar 19, 2011 | Honeywell Heating & Cooling
Is it normal operation for these units to EVER blow out cold air or "nonheated" air when unit is in heat mode?
Yes. Heat pumps have to go into defrost just like a freezer when the temp gets too cold outside. The heat pump will temper the indoor air electric heat.
Apr 12, 2010 | Amana PTH123B25AJ Heat Pump Air...
Heating & Cooling Logo
23 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
