Question about Seagate FreeAgent GoFlex 750 GB USB 20 UltraPortable External Kit and USB 30 Adapter S Hard Drive
My external hard disk is not being detected on my computer and i think there is a problem in the disk....the spin is not there inside the disk
  • 2,386 Answers
Hello
These symptoms shows that the Hard Disk may gone damage, if it is in warranty period then avail it immediately.
Good Luck
Posted on Jan 01, 2011
My computer wont read my iomega external hard drive but read before now its just local disk c ...try to open but will freeze ...have a lot of stuff on hard drive so i cant just format it again...
This is quite a tough one, First does the external hard drive appear when on your computer at all? I would assume disk "c:" that you mention is your main drive or your internal harddrive. If you don't see your external on the computer when you have it plugged in and turned on. Then there is a promblem. 1) Make sure driver is installed, usually when you turn on the external harddrive or plug it in to the computer, the windows sound (found device) usually pops up. 2) Check all connections if all is properly made, and if you have another computer, test it on that computer if you get another different result. If same result is made, and all connection are properly secured. Then you external harddrive enclosure, or the harddrive disk inside it is bad. 3) Listen to your harddrive to see if you hear the drive inside it spins, or if it is making any noise. If spin you could be ok, if it is humming or clicking loudly like it's stuck, then you are kind of done for and could pretty much say goodby to all those files and stuff (with exception) 4) You can take the hard disk inside the external enclosure and hook it up to a computer (if you need help how to, let me know) and see if the computer is able to read it. If not, then definitly your drive is damaged. You can still recover the files, but can't gaurentee a full recovery. In that case, you can take it to bestbuy, office depot, and tell them about the promblem and have them do a data recovery. It is costly, I mean very costly. Anywhere from $250-$750+
Now, if your computer could detect it and give it a drive letter for exmaple D:, but unable to access the files, you can probraly do a error-checking when right click for propertie of the drive.
Feb 01, 2011 | Iomega 33089 250 GB Hard Drive
My Hard Disk is not being detected by my computer and i think there is a problem inside the hard disk as i cannot feel the normal spin inside the hard disk
Fix by an expert required such as www.SaveMyUSB.com
1. Faulty USB port on PC: Try a different computer or laptop
2. Faulty USB cable: Try a different Cable
3. Corrupt memory: Fix by an expert required such as www.SaveMyUSB.com
4. Faulty connections on main circuit inside the hard drive: Physical Fix by an expert required such as www.SaveMyUSB.com
5. Faulty controller chip (worst case scenario) : Direct flash memory read required by an expert required such as www.SaveMyUSB.com
Hope this helps and that it is 1 or 2 as 3, 4 and 5 will cost you money.
Good luck
Jan 01, 2011 | Seagate FreeAgent GoFlex 750 GB USB 20...
My 120 Hitachi hard drive is not detecting any more
All I can think of is to completely remove all ya USB layer, via Device manager, uninstall & remove drivers on everything USB, then reboot, and then after try to plug ya drive in again BUT after it finishes re-installing the USB layer give it 5 mins or so...then do so. GL
Jan 26, 2010 | Computers & Internet
My phillips external hard drive became disconnected and I can not get it to start up
Open the external hard drive cover, remove the hard disk inside, and fix it back. Try again and let's see what happens.
If it still does not work, insert the external drive into the computer, feel the hard drive if it spins/vibrate from inside or if it makes a cracking noise.
If it spins/vibrate, it means the hard disk is still working. In that case, you have to get another external drive case/cover.
But if it makes cracking noise, then it means the hard drive is damaged and you need to get another one.
I wish you all the best.
Jan 11, 2010 | Computers & Internet
My mac says that it cannot detect a hard drive but it is powered up and plugged into usb port. help!
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hello,
Jan 08, 2010 | Computers & Internet
Its not getting recognized...though it used it before
Best regards
Jan 08, 2010 | Western Digital Passport 320GB External...
My hard drive doesn't start. I was on vacation for a month, before leaving I unplugged it and now I returned, plugged, but it makes noises, but no lights or info...
is it an external hard drive? If its not an external hard drive, the same solution still applies because its still about hard disk.
Jan 07, 2010 | Computers & Internet
Dell latitude D610
This fault usually means the hard disk has failed or the disk controller, in most cases it is the hard disk that has failed.
Check the BIOS settings and see if the hard disk is detected, if not it is probably a faulty hard disk.
When you boot up the computer does the hard disk LED light flash and can you hear the hard disk spin up. If the hard disk is making a clicking noise then it is definitely faulty.
To test the hard disk another way, remove the hard disk and connect it to an USB hard disk adapter and connect it to a working computer's USB port. If this computer cannot detect this as an external hard drive and you can't open the folders and files, this confirms it as faulty.
To get the computer operational again, you need a new hard drive, Install Windows on the new hard drive with the computer's device drivers and your programs.
Sep 05, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
External Hardisk Maxtor 4 One Touch not detected
Have you tried different USB cables with the drive? If the drive is self powered (no ext power supply) which I think that one is, then it needs a really good cable to draw the 5 volts from the USB port. If you have tried a known working cable, then it could be the USB controller or the disk itself. You can buy the USB box on eBay really cheap and move the drive over.
Apr 13, 2009 | Computers & Internet
I cannot read my western digital external hard drive from my macintosh. Was there last week, but disapeared when I started my computer today. Any suggestions?
Unplug the power cord , have your computer boot completely then plug in your hard drive again.
This next bit is a bit unorthodox but as you plug in the power can you hear it spin up ?
if not i think that the power module inside the case is faulty
If it does spin up hopefully your macintosh can detect it now , im not to familiar with macintosh's but i think dirvers are apart of the windows world so either uninstall the drivers (if any) and reinstall if none check the usb or firewire cable is properly plugged in , if so check the usb or firewire cord works by trying it on another device or purchasing a new one and testing it on your hard drive.
If none of that works i suggest you get a replacement on warranty if the data on the disk is easily replaceable , if it isnt you can open the case, remove the hard drive and buy a external hard drive enclosure kit and use the hard drive in that.
Sorry i can't be of more assistance but the macworld is very foreign to me
Goodluck and please don't forget to rate :D
Aug 25, 2008 | Computers & Internet
Seagate FreeAgent GoFlex 750 GB USB 20 UltraPortable External Kit and USB 30 Adapter S Hard Drive Logo
104 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
