Question about Seagate FreeAgent GoFlex 750 GB USB 20 UltraPortable External Kit and USB 30 Adapter S Hard Drive
My Hard Disk is not being detected by my computer and i think there is a problem inside the hard disk as i cannot feel the normal spin inside the hard disk
  • 44 Answers
Fix by an expert required such as www.SaveMyUSB.com
1. Faulty USB port on PC: Try a different computer or laptop
2. Faulty USB cable: Try a different Cable
3. Corrupt memory: Fix by an expert required such as www.SaveMyUSB.com
4. Faulty connections on main circuit inside the hard drive: Physical Fix by an expert required such as www.SaveMyUSB.com
5. Faulty controller chip (worst case scenario) : Direct flash memory read required by an expert required such as www.SaveMyUSB.com
Hope this helps and that it is 1 or 2 as 3, 4 and 5 will cost you money.
Good luck
Posted on Jan 01, 2011
HARD DRIVE NOT EXIST ERROR!!!
If you installed Linux successfully on your hard disk then the hard disk is OK.
If you are installing Windows Xp and it does not detect the hard disk but the BIOS detects the hard disk then -
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
May 01, 2012 | HP Computers & Internet
Tip
How to detect if your hard-drive is working or not/hard disk maintenance.
Some times you don't know if your hard drive is working or not. Your external hard disk might drop on the ground, or your desktop/laptop hard drive might not be booting. Which ever the case maybe, here is how to find out the condition of your hard disk:
Put your ear close to your hard disk, if you hear your hard disk make a crackling noise, be prepared to buy another hard disk because such hard disk is damaged and cannot be fixed. Also note that it is difficult to recover files from such hard drive.
But if you don't hear a crackling sound, use your hand(s) to feel the drive, if it vibrates, it means the hard disk is in good condition.
What damages external hard drive most times is if you don't eject (safely remove) it from your computer, when it drops on the ground or hits any hard object etc
If your external hard disk stops working, firstly, check if the hard disk inside the case is in good condition by checking for crackling sounds and vibration. Once you observe that the hard disk is in good condition, this means the hard drive case is defective/the cause of the problem. Get another drive case and your drive will work again without loosing any file/data on it.
For desktop/laptop hard drive maintenance, make sure you always shut down your computer properly, don't remove the CPU's power cord while the computer is turned on. To be on a safer side, always use UPS (uninterrupted power supply) for your desktop computer.
Also, when using your laptop, makes sure its fixed at a position. Avoid any shake as the hard disk might shift from its normal position in the process.
Good luck.
on Oct 21, 2010 | Computers & Internet
My external hard disk is not being detected on my computer and i think there is a problem in the disk....the spin is not there inside the disk
Hello
These symptoms shows that the Hard Disk may gone damage, if it is in warranty period then avail it immediately.
Good Luck
Jan 01, 2011 | Seagate FreeAgent GoFlex 750 GB USB 20...
Its not getting recognized it doesnt show up in the desktop
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hello,
Open the external hard drive cover, remove the hard disk inside, and fix it back. Try again and let's see what happens.
If it still does not work, insert the external drive into the computer, feel the hard drive if it spins/vibrate from inside or if it makes a cracking noise.
If it spins/vibrate, it means the hard disk is still working. In that case, you have to get another external drive case/cover.
But if it makes cracking noise, then it means the hard drive is damaged and you need to get another one.
Take care
Jan 08, 2010 | Computers & Internet
My mac says that it cannot detect a hard drive but it is powered up and plugged into usb port. help!
I wish you all the best.
Its not getting recognized...though it used it before
Best regards
Jan 08, 2010 | Western Digital Passport 320GB External...
My hard drive doesn't start. I was on vacation for a month, before leaving I unplugged it and now I returned, plugged, but it makes noises, but no lights or info...
is it an external hard drive? If its not an external hard drive, the same solution still applies because its still about hard disk.
Jan 07, 2010 | Computers & Internet
My lacie rugged 500gb triple interface normally worked but now doesn't load anymore. It makes a strange soft sound for 2 seconds and then nothing. help!!!!
Jan 06, 2010 | LaCie Rugged All-Terrain (301175) 160 GB...
Dell latitude D610
This fault usually means the hard disk has failed or the disk controller, in most cases it is the hard disk that has failed.
Check the BIOS settings and see if the hard disk is detected, if not it is probably a faulty hard disk.
When you boot up the computer does the hard disk LED light flash and can you hear the hard disk spin up. If the hard disk is making a clicking noise then it is definitely faulty.
To test the hard disk another way, remove the hard disk and connect it to an USB hard disk adapter and connect it to a working computer's USB port. If this computer cannot detect this as an external hard drive and you can't open the folders and files, this confirms it as faulty.
To get the computer operational again, you need a new hard drive, Install Windows on the new hard drive with the computer's device drivers and your programs.
Sep 05, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Western digital not detected
Hi
Try COLD boot not RESTART, WD I think have produced updated driver to address this problem.
Aug 12, 2009 | Western Digital Passport® 160 GB USB 2.0...
Seagate FreeAgent GoFlex 750 GB USB 20 UltraPortable External Kit and USB 30 Adapter S Hard Drive Logo
103 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
Steve
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
