It shows a protect message and shuts down - Audio Players & Recorders
    Scholar:
  • 155 Answers
This usually means some speaker wires are touching. remove all first (meaning all cables except the power one) power it on if you get the message again it is a faulty device inside the unit. if not you can isolate the problem by plugging one in at a time. once you find out the problem wire you chase the wires to see if they are not cut or touching somewhere. thank you and please rate.
Posted on Jan 01, 2011
Hii I have sony shake 6D system and whenever I turn the volume up it reaches upto 40 and shows the error of 'protect E01' while the maximum volume is 50. Please help
Most likely, your unit is shutting down due to overheating. You cannot run an amp at that kind of volume very long. It is shutting down to protect itself. Try running the amp at 1/3 your normal level. Most likely, it will not shut down.
Aug 05, 2015 | Sony Audio Players & Recorders
Whistle in computer
Bogus unit - return it for another.
Aug 21, 2017 | E-Machines eMachines Desktop PC
PROTECT MESSAGE
It senses an error or problem and shuts down. Try disconnecting all the cables and wires attached to it. Try it again. If it still shows protect message, it is an internal fault and requires a repair shop. If it clears up, then the problem may be a shorted speaker wire. Correct the short when reconnecting the speakers.
Mar 08, 2010 | Sony STR-DE545 Receiver
Samsung ht-x30 sutting down protection error
My samsung shuts down with "PROTECTION".Help me to solve the problem.David ilomo.
Dec 05, 2009 | Samsung Audio Players & Recorders
Everytime i turn on the stereo it shuts off an says protect
When sound system shows Protect that means it got problem in amplifier section and protection circuit is activated that shuts down system in safety. Qualified tech will fix it.
Jul 31, 2009 | JVC HX-C6 Shelf System
Protection and shut down.ht-tx35
protection error message means that your unit's fan is not working
it is a feature to keep your unit from overheating
check if there is anything blocking the fan of your unit from rotation
Jun 09, 2009 | Samsung HT-X40 System
Samsung ht-q80 won't open tray
check if there is anything blocking the fan of your unit from rotating
if problem still persist replace the fan
May 24, 2009 | Samsung HT-Q80 System
Power turns off
Protect mode will kick in whenever a fault is detected.
You get the unit not powering up, and sometimes you hear a clicking noise, that is the protection switch that keeps shutting down the unit.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Jan 31, 2009 | Samsung HT-X50 System
Protect flashing on screen
That is the system telling you it jhas shut down the amplifier circuit to protect itself from damage.
Check the speaker wires both at the back of the unit and at each of the speakers to see if any of them have come out or are touching anything they shouldn't be.
You may also have a blown speaker sending a short back down the line. So if you find no wires out of place, then disconnect each speaker and turn the unit off and on as you go until the message is not showing and sound is restored.
Apr 30, 2008 | Sony DAV-SA30 System
"PROTECT" message
I've got a jvc hx-d7 i am working on for a friend, he had it repaired once at a shop with this same problem, they replaced two 42v 2200mf caps. and one A1273 this solved the problem for 8months now its doing it again. I am trying to locate the A1273 to repair it again. Hope this helps.
Dec 25, 2007 | JVC HX-D7 DVD Compact Stereo Audio / Video...
 Grubhead
Grubhead
