Question about ASUS P5GC-MX/1333 Motherboard
CAN'T CONNECT TO INTERNET no driver lan no driver ethernet
  • ASUS Master
  • 32,281 Answers
You can download the drivers from ASUS WEB site. Selectyour model motherboard/computer/laptop, and make sure you select the Windows XPor Vista version of the drivers that matches your Windows operating system.Please click on this link to their WEB support site : - http://support.asus.com/download/download.aspx?SLanguage=en-us
Posted on Jan 01, 2011
Ethernet controller
That yellow exclamation mark means you don't have the correct driver for your ethernet card.
You didn't say if your operating system was 32-bit or 64-bit so I'll give you links to both versions of the driver.
Here is the 32-bit LAN driver:
http://img.dfi.com/Upload/Driver/CM/Marvell_LAN_729.zip
Here is the 64-bit LAN driver:
http://img.dfi.com/Upload/Driver/CM/Marvell_LAN_731_x64.zip
If you need any other drivers for your motherboard you can get them here:
http://www.dfi.com.tw/DFI-Lanparty/support/MBDriverDownload.jsp?selectedDriveritemId=349
May 24, 2012 | DFI LanParty UT 915P-T12 Motherboard
I;ve reformatted my drive ,and i can't connect to the internet because i dont have a ethernet controller....................! How can i find a solution so that i may reconnect to the internet?
You need to install the drivers on your computer Goto your computer manufacturer website and select your Model num ber to download the Chipset drivers, Ethernet controller, LAN drivers etc...
Jul 07, 2011 | Computers & Internet
I have two ParkerVision WR1500 4-port Wireless DSL/Cable Routers. The first one I have connected my Ethernet Cable from my modem to the WAN port. This is where I get my Internet Signal. My understanding...
You won't get internet connection that way because there is no connection between the first parkervision and the 2nd one.
Best way is use only one parkervision router. Connect WAN port to modem for internet, 1st lan port connect to your pc and 2nd lan port connect to 2nd pc in other room. 2nd way is, use only one parkervision. Connect WAN port to modem for internet, 1st lan port connect to your pc, setup wireless SSID and connect your 2nd pc to this router for internet wirelessly. Assuming your 2nd pc has wireless capability.
Apr 13, 2011 | ParkerVision SIGNALMAX WR1500...
How do I connect internet to satellite cdt4030
Hi, Can You please more details in regard to this problem... I am assuming that you reformat you Pc and you might not have lan Ethernet driver. Or the Lan is disable... To chek click start,click control panel network and internet connection if your OS is windows vista / windows 7 click connect to network .Xp network connection and find out if have lan connection if the page is blank you need a ethernet driver. Hope this info might help you to solve your problem. Have a Happy New Year... HRH
Dec 30, 2010 | Computers & Internet
My dell lan card is not working,i cannot connect to internet.
Either the LAN card is faulty or the LAN driver is not installed and/or not configured properly or the LAN cable is faulty.
Check Device Manager to see if the LAN driver is installed, working and enabled. If not then re-install the LAN card driver.
If the LAN driver won't install or detect the LAN card then it maybe faulty and needs to be replaced.
Try a different LAN cable.
Is all the LEDs on in the modem?
Try rebooting the modem (power it off for 30 secs and power it up again).
Nov 14, 2009 | Dell Ethernet Card Network Adapter
Ethernet/lan missing so i can not connect to the internet
Download and install the driver from the manufacturers website. Use an external hard drive or flash drive to download from internet (working computer) and install from there.
Oct 03, 2009 | Foxconn 915P7AC-8KS Motherboard
How can i connect a toshiba runniung windows me. to the internet via ethernet cable? is it possible with just the cable and no card? is there a programe i can download to help my laptop? what can i do?
It should have a LAN (network card) built in to the laptop.
First of all make sure you have the LAN (network drivers) installed. You can do this by checking in device manager.
To open device manager click Start, point to Settings, and then click Control Panel.
Double-click the System icon. Click the Device Manager tab and look in the list for network adapters/controllers.
If the driver is installed you should be able to directly connect the ethernet cable to your laptop.
I'm not quite sure where the ethernet port is on that particular laptop but it will be on the back or sides of the unit and it will be the only port the ethernet cable fits into.
From there you should be good to go, if you can't get a connection reset the modem by removing power from it for 2 minutes, connect the power again, wait another 2 minutes for the device to settle and try the internet connection again.
Regards.
Oct 01, 2009 | Toshiba Satellite 1715XCDS...
D-link dsl 320b lan light
Maybe it is ethernet driver
Apr 23, 2017 | D-Link DSL-2320B
T3256 needs ethernet driver
Dear Cedrich,
I found an "unofficial" e-machines website for you: http://www.e4allupgraders.info/
And the following is a link to your Ethernet driver:
http://www.e4allupgraders.info/dir3/files/drivers/lan/AU31_Ethernet_xp2k.zip
Here is the page for your particular model:
http://www.e4allupgraders.info/dir1/motherboards/socketa/au31_downloads.shtml
If you need any further assistance, please request it,
Jem
Jan 04, 2009 | E-Machines T3256 PC Desktop
ASUS P5GC-MX/1333 Motherboard Logo
130 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
