Question about DeLonghi PAC W130 Portable Air Conditioner
Error "pf" "Probe Fail" on Delonghi PAC W150
jfpogie
  • 104 Answers
SOURCE: DeLonghi Pinguio Pac 45
1. Clean air filer every 2 weeks.
2. clean ACCU and FCU every 3 months.
3. check and re-tight all electrical connection every 6 months.
Posted on Jan 20, 2008
  • 9 Answers
SOURCE: Error Message
It's actually "Ft", which means "Full Tank".  The instruction manual says to drain the internal safety tank through the drain hoses.
To drain the tank, open the cover on the rear of the appliance. Pull out the 2 drain hoses, take off the caps, and let all the residual water flow out.  When all the water has been drained, place the caps back on the hoses and put the hoses back inside.
It also says you need to clean the filters and let them dry thoroughly before putting them back.
This is also the procedure for "End of Season Operations."
Hope this helps!
Posted on Jun 08, 2008
huuum
  • 750 Answers
SOURCE: DeLonghi portable airconditioner leaking water
nbenz ,
Welcome to fixya.
I'm Huuum and happy to assist you,
Portable units are supposed to spray the water on to the hot compressor an evaporate the water!
If it is only 3 weeks old ,you have a 1 year warranty. call service and let them fix it for !
Please remember to leave a rating before you go!
Thank you
Posted on Sep 29, 2008
  • 10865 Answers
SOURCE: Exhaust Hose DeLonghi PAC-210U replacement
you can contact the company directly at
Contact Center
1-877-882-8604 Monday – Friday
8am – 8pm EST
good luck with this.
Posted on Feb 14, 2009
  • 134 Answers
Hi
You need to go here
://www.delonghi.co.uk/accessories.php
I have a Delonghi Pinguino PAC A12OE and it is showing an error code which is PF
This is the temperature probe.
Try to disconnect and measure the resistance: it should be 1100 Ohm at room temperature. If not try to get an replacement.
Nov 12, 2014 | Heating & Cooling
.DeLonghi pac A110 PF error code
Probe fault? Temperature sensing probe may have loose connection or water in the tip.
Apr 17, 2012 | DeLonghi DEC 180 E Dehumidifier
Sorry I do not speak English well. C120 pac my team. PF mark on the screen and turn on all lights. not working I have to do Thanks for your time
This unit stopped working and displayed the PF code for Probe Failure. I fixed it by removing 6 screws for the panal and 4 screws for the back panal and removing the 5 screws and 1 screw holding the ground wire off the silver box with the circuit board in it then I un plugged the little plug for the 2 probes with the black wires in it and replugged it in and wiggled it several times with the unit pluged in (be carefull not to get shocked I recomend someone with electrical experiance do this for you) the plug must get corroded but this fixed my unit.
Good luck.
Sep 13, 2011 | DeLonghi PAC C120 Portable Air Conditioner
I have a pf code flashong on my a/c unit. Could you tell me what it means. I have the PAC l90
Here is a tips that I wrote that will help to explain why you get the PF Error Code
PF Error Code for Appliances
heatman101
Sep 24, 2010 | DeLonghi PAC L90 Portable Air Conditioner
Pf code definition
it stands for probe failure not power failure. there are 2 temp probes in the unit and it has an issue with the plug on the circuit board
Apr 20, 2010 | DeLonghi Pinguino PACL90 Portable Air...
When turn on display reads PF and no AC???
PROBE FAILURE -check their website for the list of error codes here
http://www.delonghi.com/
It says to contact repair department.
Mar 29, 2010 | DeLonghi Pinguino PACL90 Portable Air...
Help On Your Fix Please
The instruction manual says that "PF" means "Probe Failure", that the probe is damaged.  The solution in the manual says to contact the service centre.
Customer Service:  800-322-3848  US Customer Service: 888-335-6644 Canada
May 13, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Pac L90
p f PROBE FAILURE
(The probe is damaged) Contact Service Center. From manual.
May 12, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Delonghi PAC L90
The probe is located on under the main board low inside the only silver metallic box on the bottom w circuit board under it.Remove cover and immediatly you see a 4 inch black wire connected to the main board tucked under and mounted.Unplug the white connector from board, power on, then carefully plug the white connector back on, turn unit off and back on, you should see all 3 mode lights now on steady , no pf error and it doesnt turn off,and you can change modes and temps.Took an hour to take it part and dig around, mine works fookin great now.
Jun 20, 2007 | DeLonghi Pinguino PACL90 Portable Air...
DeLonghi PAC W130 Portable Air Conditioner Logo
197 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
