Question about D-Link DIR-600 Router
Hi dlink dir 600 wireless working as access point disconnects every one minute while the wired output works normally. what's the reason and the solution? regards
  • Yashar Jan 01, 2011
    i manages updating firmware using ftp://ftp.dlink.cz/dir/dir-600/driver_software/DIR-600_fw_revB_2-05B01_all_en_20101213.zip but problem persists. also i have to mention the connection is secured, signal strength is high while wireless working, there is no interference from electrical sources .
  • Yashar Jan 03, 2011
    i tried d'link official ftp to get the update. i tried all possible ways, checking everything. i just packed and sent it to d'link support. thanks by the way.
  • D-Link Master
  • 32,281 Answers
A disconnecting wireless connection can be cause by any number of things. Please click on this link and follow my instructions to determine the fault and fix :-
http://www.fixya.com/support/r3559120-wireless_router_disconnecting
Posted on Jan 01, 2011
    sorry but none of them were applicable
  • 6,826 Answers
Try to get the latest firmware and install it for the dlink dir 600 wireless router.
  • 2 more comments
    i checked for update:
    Current Firmware Version : 2.02
    Current Firmware Date : Mon 21 Dec 2009
    Check Online Now for Latest Firmware Version :
    This firmware is the latest version.
    also i tried dir600b-revb-ddwrt-webflash.bin but i get this message: The chosen file is not a valid firmware image file.
    what's the problem?
    regards
  • Duane Wong
    Duane Wong Jan 01, 2011
    http://www.dlink.com/products/?pid=DIR-6...
  • Duane Wong
    Notes about firmware update dated 7/22/2009:
    Firmware: 1.01NA
    Date: 07/22/09
    1. In Internet Connection Setup Wizard: Step 3, change Telus behavior to default to dynamic.
    - Add DNS Setting in PPPoE wizard
    2. Fixed that setting virtual server rule with UDP.
    3. Fixed when changing the LAN IP, the DHCP range does automatically change to match new subnet/network.
    4. Fixed Error message would pop-up after setting NTP server.
    5. Fixed MAC filtering feature to allow MAC address that start with numbers other then 00.
    6. Corrected WPS LED so that it will blink when using the WPS PIN method in side the WPS wizard.
    7. Fixed WAN setup DHCP, QoS Engine WEB UI failed.
    8. For login issue, in Vista OS, click DIR-600 icon and still show warning message.
    - In support page, “Routing” is missing.
    9. Fixed Wireless settings WEP key 1 – 4 will disappear.
    10. Corrected issue with schedules. All week and All day schedules now work properly.
    11. BiTorrent certification.
    12. Fixed DNS portion of Quick Router Setup that would allow an empty field to retain previous settings.
    13. Default wireless mode changed from 11G/N to 11B/G/N
    14. Add Advance DNS Feature.
    15. Add B mode in wireless WEP description.
    16. When a schedule is used to disable the wireless, the disabled status is reflected in the status page.
    - Fixed when wireless is disabling with schedule, on status information still show wireless is enable.
    17. Advanced DNS will be disabled after setting to disabled in Quick Router Setup.
    18. Fixed ALG/UPnP issue.
    19. Fix PPTP/L2TP auto dial-up at "on demand" mode.
    20. Fixed DHCP MTU to "1490", 48
    21. Fixed DDNS server address field couldn´t be edited.
    22. Disabled CAPTCHA by default.
  • Duane Wong
    Where did you try to download the dlink firmware update for this product?
How do I enable multicast for chromecast with my DLink 600 - tried to log in but "page is not available". The router is wireless to my PC, ipad, android phone.
If your PC, iPad and smartphone work well with your router, the problem is with your chromecast. If can't set it up to work with the routes, I guess that it's "wireless adapter" or whatever makes it work, is defective. If it's new, you should return it to the shop where you bought it, should have warranty
Aug 02, 2015 | D-Link Dlink Dir-600 Wireless Router...
Direct access through LAN cable internet was working fine. whereas while connecting through DLink(Dir 600) pages were not loading correcly. I tried Netgear modem it was working fine. What is the probl
I would contact your ISP for help with this one. It should work but you would want to check the LAN and WAN settings to make sure they work on the network since there have been changes.
Aug 31, 2014 | D-Link Dlink Dir-600 Wireless Router...
Block downloading on my tp link router
Why? What sites?
Login to the router's internal web-server, and click the "Advanced" tab, and enter the IP-addresses of the sites you want to block.
Mar 02, 2014 | D-Link Dlink Dir-600 Wireless Router...
How to block downloading through using TP-Link router
Make the other person get their own Internet access, rather than sharing your access.
Dec 19, 2013 | D-Link Dlink Dir-600 Wireless Router...
Unable to connect my blackberry to wifi. it says unable to authenticate network.
Try a hard reset: With power ON, remove the back cover and pull out the battery. Wait about a minute then replace the battery and cover. Power up and wait patiently through the long reboot 5 minutes.
Also check the wifi encryption is compatible with your phone?
Maybe an option to goto a cafe with a wifi hotspot and try logging in there ... does that work?
cheers.
Oct 22, 2013 | D-Link Dlink Dir-600 Wireless Router...
Hi, my dlink dir 600 is funished as an access point and i cant connect to the pptp vpn server from my university. What do i have to do?
the problem is most likely that your university blocks the pptp ports so you cannot connect to the VPN. are you able to access it if you plug your computer directly into the wired connection?
Sep 27, 2013 | D-Link Computers & Internet
I Need Installer For My D-Link DIR-600 Wireless Router
There are ways to configure router:
1. Is by using Installer using a CD came with it or
2. Access routers Graphical User Interface (GUI) through Internet browser. Just type in on the address bar the IP address of your router. For dlink it has a default IP of 192.168.1.0.
Note:
Before accessing router configuration make sure that the yellow cord (ethernet cable) is connected directly from the router to your computer.
Sep 14, 2013 | D-Link Dlink Dir-600 Wireless Router...
D-Link Dir 600 Wireless disconnects
Sounds like you have a bad device. Can you return it? Is it under warranty? You have changed cables, check pins in the DLink connector for bent pins? etc. I use a little vaseline on the copper to prevent oxidation, sounds weird, I know, but it works. I live it a humid climate. Try a Contact Spray for electronics, it's a life saver.
Dec 15, 2012 | D-Link DIR-600 Router
D-Link DIR-600 Router Logo
2,063 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
