Question about Emerson EM227 Bluetooth Headset
Bluetooth headset wont pair with laptop. seaching for driver? inappropriate parameters
    President:
  • 1,118 Answers
You must put you headset in pairing mode, prior to trying to pair it with your phone. In order to do it, starting with it turned off, press and hold the power button for some 10 seconds, until the indicator light is alternately flashing in red and blue. It is in pairing mode now. Then, bring your heaset close to your computer, and make the latter's bluetooth application search for new devices. After a little while, your headset should appear on-screen. Select it and make it connect. If a pairing code (or passkey, or PIN) is requested, enter '0000' (four zeros). If the pairing process is successful, your headset should enter the stand-by mode (blue light flashing every few seconds). By the way, If its user guide happens to be missing, or, rather, you need further informations on how to pair it with your phone, feel free to download it from this location.
Regards,
Carlos
Posted on Jan 24, 2011
Windows driver for delton x9
You don't need drivers for a bluetooth headset. You need a working bluetooth adapter in your computer (most laptops have it as standard, some desktops need an external one (USB dongle, and this comes with it's own drivers).
When you are sure that you have working bluetooth, you need to pair the headset with your computer.
You need to find the Bluetooth icon, looking like this:
in your system tray (near the clock on the taskbar, may need to click the << icon to expand the hidden icons). Right-click it and choose Add/Pair device and proceed to pair your headset per it's manual.
Nov 20, 2014 | Delton X9 Thunder Behind-the-Head Stereo...
My ps3 bluetooth headset wont pair with my ps3
go into accessory settings and connect the bluetooth device via USB so the drivers can be installed to your PS3. This is how i connected mine.
Feb 22, 2010 | Ubi Soft Entertainment Tom Clancy''s...
How to connect lg hbm-730 bluetooth to dv4 laptop
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above.
Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
Feb 12, 2010 | LG HBM 730 Bluetooth Headset Wireless...
Backbeat 903 headphones won't pair with Windows 7 64-bit laptop
I had the same problem as you although I was able to find a solution. If your bluetooth adapter on your computer doesn't support A2DP then you can purchase this adapter from IO Gear: http://www.iogear.com/product/GBU421/ or another adapter that supports this feature. Windows will try to install it as a generic bluetooth adapter (which wont allow you to pair the headset) but if you install the disk that comes with this, it will also install the additional drivers needed for the headset.
Walmart carries it for $20 at most stores or $13 online. I got mine at the store.
http://www.walmart.com/ip/IoGear-Bluetooth-2.0-USB-Micro-Adapter/10299060
If you need help installing it let me know I can provide the steps I did.
TJB
Jan 28, 2010 | Altec Lansing BackBeat Plus Mobile ...
My nokia E63 wont find bluetooth headset
I had a similar problem with my headset.. but found the solution.. I am using Jabra 2010.. ok.. so just switch "off" the headset...go to the pair menu on e63.. then switch on the headset.. and then look for new pair devices option.. voila it came up. hv been trying for almost 3 weeks before i got the sequence right.. somehow if u had switched the headset on beforehand.. it wouldnt recognise it only.. the solution is here at jabra website .. although.. they dont hv e63 listed .. but the same procedure for e71 worked fine for my handset..
Jul 13, 2009 | Genius BT-03A Bluetooth Headset
Bluetooth headset presario c700
yes...if you already install the driver and software for bluetooth..all you have to do is pair it.
default password for pairing is 0000 (4 zero)
Mar 16, 2009 | HP Presario C700T Notebook
Pairing H710 to a computer
Well. This is probably not a solution you guys want to hear, but it just worked. I left it for months, maybe it was just the time, or a recharge needed to wipe out one of the paired devices in memory, but it just paired with my laptop like that. Used it for while too with Skype.
I am also using the new Windows Seven RC this time around, maybe it was a Beta issue, that got fixed with the RC.
Feb 11, 2009 | Motorola Mobility H710 Bluetooth Headset
Cannot pair wireless headset to pc
What kind of bluetooth adapter does your computer have installed? Is it a USB bluetooth adapter? Is it a card inside the computer? Is it a laptop PC with bluetooth?
I had just the drivers installed on my Dell computer when I got it, but there was no bluetooth device in the laptop to receive/send the signals. Do you have other bluetooth devices that connect to your PC? Are they working fine?
Jun 12, 2008 | Radio Communications
Headset wont pair with new ps3
is this bluetooth
if it is blue tooth you have to hold blue tooth power on while the pairing mode is searching for headset
if its a cabled headset threw usb you gotta put in your disk for say example= logitech since these are common
the playstation has memmory card that stores the settings but requires you at least set up usb head set parameters either to ps3 or your memmory cards properties
your headset is fine you just require a new hardware setting with the disk that came with your head set
May 28, 2008 | Sony Playstation 3 (PS3) Console
Emerson EM227 Bluetooth Headset Logo
470 people viewed this question
Top Emerson Radio Communications Experts
J.D. Browning
J.D. Browning
Are you an Emerson Radio Communication Expert? Answer questions, earn points and help others
