How do i remove the key pads? - Computers & Internet
    Scholar:
  • 155 Answers
Remove the strip where the power button is located. that will give you access to the screws holding the keyboard. then lift the keyboard slowly and remove the wire tape from main board. most laptops you need to remove a couple of screw from the back and move the screen so it is parallel with the keyboard. (flat so it bypass the hinges) the strip meaning a long piece as wide as the laptop. (located near the screen but on the keyboard side) hope this helps.
Posted on Jan 01, 2011
Key pad not working (does not light Up)
You must replace the key pad as a unit, the tiny light bulb is not replaceable. This involves removing the drivers door panel (about a 2 hour job at home)and the rear door glass run channel. I suggest if you can afford it you have a professional do this rather involved job. If you do want to attempt it let me know.
Jun 24, 2012 | 2004 Lincoln Navigator
The b key strikes to hard, so there is any touch resopnce on the middle B key, what can i do to fix if?
You will have to clean the keyboard touch pads. its a pain full job because one has to remove at least 50 screws before one gets access to the key pads. Remove the back cover and make a note of what screws goes ware.Then remove the screws that hold a long circuit board over the keyboard ( lots of small screws ) . Invert this board and clean the black carbon tracks as well as the rubber key pads with solutions like WD40. Install it back in the reverse order making sure you put all the right screws in the right place. Should work fine after that until dust again gets in between.
Sep 26, 2011 | Yamaha Mm6 Synthesizer Keyboard...
WHAT DOES E68 MEAN ON MY DRYER MODEL# AEQ7000EGO
You have a key stuck closed on the key pad. Remove the top 2 panel screws on the rear with a phillips screw driver and slide the top back to remove and look for the tech sheets they will tell you how to enter the function mode and test the key pad.
Sep 26, 2011 | Frigidaire Dryers
What tool is needed to remove the caliper, a hex key or something else?
For front brake pads replacement you need only usually wrench set, inclusive 7 mm allen key also. But for rear brake pads replacement you need obligatory a special caliper piston pressing tool, in order to press back rear caliper piston with parking brake automatic adjustment!!!
For front brake pads. First you must verify yours front brake disc diameter: 280 mm or 288 mm. After that you can buy the brake pads (with wear sensor). For change front brake pads you must raise vehicle, remove wheels, extract the retaining spring of the caliper, and remove the caliper as follow:
1. Do not disconnect the brake hose from the caliper, and do not allow the caliper to hang by the brake hose!
2. Remove top and bottom caps (on back side of the caliper) for access to guide pins, then unbolt and remove them from the brake carrier. Remove the caliper.
3. Now you must thoroughly clean the brake calipers (free of grease).
4. Remove outer brake pad from brake carrier.
5. Pull inner brake pad out of brake caliper piston.
6. Check up the brake fluid level on the reservoir, and emptying if neccessary!
7. Push piston back into brake caliper housing.
8. Install inner brake pad (with expanding spring) in brake caliper piston. (Arrow marked on pad - if exist, must point in direction of brake disc rotation when vehicle is moving forward).
9. Install outer brake pad into brake carrier.
10. Bolt brake caliper housing to brake carrier using two guide pins. Tightening torque is 25 Nm.
11. Install both caps.
12. Insert retaining spring into brake caliper housing. Important: Depress the brake pedal firmly several times while the car is stationary so that the brake pads adjust to their normal operating positions!!!
Check brake fluid level and top up if neccessary!!!
Jul 22, 2011 | 1996 Audi A6
Nokia 5320d-1 some keys not working pls help
Just Follow these steps
- Remove the cover(housing) and check keys by pressing the cells - If the problem is same as earlier, remove the mylar pad layer and clean it fully (Including malfunctioned keys) - get small flat screwdriver and short the keypad sensing points - and check whether that malfunctioned keys are working. - if working Clean the miler pad. - if not you need to change the keypad esd filter (Keypad IC)
Mar 11, 2011 | Nokia Cell Phones
My keypad is locked.please help me
ky keypad is locked by security code what can i do 4 unlock 2730c
Aug 12, 2010 | Nokia 2730 Cell Phone
Hello, I am unable to use the update service for p990i
very simple solution press the "c" key on the qwerty key pad - Which i tried it works
Apr 11, 2010 | Sony Ericsson P990i Cellular Phone
Key pad not working
First of all try this - - unplug Microwave and remove the back panel to gain access the the control panel. There is a ribbon connector that connects keypad to control. Remove the key pad from control and use a pencil eraser and clean the end of this ribbon connector wher it fits into control . Reconnect and see if that corrects the problem, If this will not works then You'll have to replace the control (key pad control).
Good Luck!!
Thanks
Aug 24, 2009 | Magic Chef Microwave Ovens
Deactivate the touch pad
Try holding down FN key and F( key. This activated and de-activates the touch pad
Apr 25, 2009 | Toshiba Satellite A20 Satellite A25 Series...
Sharp microwave model R-395F(S) bought in NZ. 1100W about 30litre. Problem from new, display weak but main problem as some buttons work some don't work and you have to push stop a few times before it...
Hi Lindsay
Sound like you need a new key pad if you have some handy man around you you can replace it, It require dismantle the front key pad remove electronic part and clean then reinstall properly the key pad itself about $40.00 Aus
Let me know if you need part number for that key pad
Cheers
Dec 02, 2008 | Microwave Ovens
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
