Question about LG Heating & Cooling
4 hp. lg ducted air starts then stops and screen shows 03 with check flashing can i find the problem please.
  • 2,133 Answers
E-3.Outdoor unit temp high. Due to condenser block, less rpm of fan motor/ over charged gas/non condnesable gas.
Remedy: Clean condenser /replace capacitor/remove over charged gas/remove all gas and flush out the system and vamise and do gas charging.
Posted on Jan 01, 2011
Lg r405 do not start when press on ac adapter works with 18.5V
Check AC Adapter for voltage output using multi-meter. If Adapter is GOOD, remove battery and try again. Does fan run? Does screen show Flash Screen? Please advise in detail.
Aug 21, 2013 | LG R405 LAPTOP LCD SCREEN 14.1" WXGA CCFL...
Flashing black and white squares instead of picture on screen.
This might require attention by a qualified service technician.
Jul 13, 2012 | LG 50PC3D 50 in. Plasma Television
On my Bosch Nexxt 500 Series Electric Dryer keeps shutting off and gives the E-01 error we have check the exhaust air duct on back of the dryer and we have vacuumed the inside bearing shield what else...
Motor won't work
Lint screen hi-limit (thermal cutout) tripped.
Clean lint screen and clean lint and other debris from front shield, then replace hi-limit. Also check exhaust duct length & # of elbows.
Wire harness failed.
Run resistance or continuity checks to track down broken wire or connector. Replace failed wire harness.
Display shows "E:01" during drying.
Lint filter, air duct or air damper is blocked.
Air leaking past felt drum seal.
Air duct is too long, too small or has too many bends. Inadequate ventilation around dryer (i.e. in a closet).
Clean out filter, air duct and air damper.
Replace felt drum seal. If seal doesn't fit snugly onto drum, wet felt and dry it by running a timed dry cycle for 20 minutes (felt will shrink and fit drum snugly).
Shorten, enlarge, reroute and reduce # of bends in air duct. Move dryer to an area
Jan 09, 2011 | Bosch Nexxt 500 Dryer
I have an LG dryer Model # ddle7177rm/dlg7188rm.when we start the dryer it starts to heat then stops and it blows cool air. the ducts are all clean.
Hello
As everything in your dryer is working fine apart from it heating properly so the recommended repair will be thermal fuse/thermostat replacement. However, you can also test its continuity before replacement. Please get back to me if you have any other questions.
Kevin
Dec 02, 2010 | LG Dryers
Dryer won't start and the check lint screen light keeps flashing. Cleaned screen and still won't start
It may not be your lint filter but instead be a clogged duct. I would suggest removing the duct and check for clogs or a kink in the duct itself. Then check the interior and exterior vent and remove any visible lint. If you exterior vent is a louvered type, check to see that its opening properly.
Jun 08, 2009 | Dryers
Hi I have a Weathermaker ducted air con model WMHO 0487 and it is flashing HP or LO I have no manual to guide me
this means either its got gas leak or outside unit fan not working.try off and on circuit breaker and if it shows ho or lo again then definitely there is a problem.when after resetting power see outside unit if fan is running if yes and if it stop again then it's gas leak
May 09, 2009 | Heating & Cooling
LG Inverter A/C Unit LSJ092V-3
I would first check the condensate drain pipe. This can be done by blowing back into the drainpipe from outside. Not to worry it is not dirty or dangerous. Also make sure that your air filters are clean.
Feb 19, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Dryer won't work, Check Filter light is on
I had exactly the same problem with my newish LG dryer. I deduced that the dryer's computer essentially needed to be rebooted. I pulled the plug for a minute or so, then plugged it back in. It works perfectly now.
Mar 11, 2007 | LG DLE2514 Electric Dryer
Heating & Cooling Logo
44 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
