Question about GE Microwave Ovens
I have a new sensor microwave oven that will run and inside the oven will get warm bt the food stays cold.
  • GE Master
  • 9,086 Answers
Since it's new I would either take it back to the store (if it's within their return period) or contact GE for a free repair.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 08, 2008
Sparks inside cavity
This is caused by exposed bare metal, food partical buildup or the magnetron itself, clean interior with warm soapy water until spotless and inspect inside cavity, if okay! test run with a cup of water.
Apr 23, 2012 | KitchenAid KCMS185J Microwave Oven
Microwave runs and turn table turns but food stays cold.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Aug 27, 2011 | Whirlpool Microwave Ovens
Our new microwave heats the containers but not the food. Container is too hot to touch. Food "looks" hot, usually boiling - but food isn't even warm.
Check on the material the containers are made of. If they are not microwave friendly then they will cause problems.
Some materials are designed to "Roast" the contents by absorbing the energy.
Check with a Pyrex glass container and water. The glass should stay fairly cool.
Feb 01, 2011 | Whirlpool MH2175XS Microwave Oven
Daewoo koc-985t bi - Not heating food equally. ie. middle of food cold. Sometimes food takes double the time to warm.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Jan 18, 2011 | Daewoo KOC-925T Microwave Oven
Microwave oven: GE Spacemaker 1400 not heating. Model number JVM1430AB001. Need guidance on troubleshooting and repair of unit. Thanks!
If the oven is making a loud buzzing noise when you try to warm food and the food remains cold, it usually means that the magnetron has failed. Not usually worth fixing since the parts alone can cause as much as a new oven.
Oct 04, 2010 | GE Microwave Ovens
Our emerson microwave will not make anything hot.put in time for something to cook it runs fine but it will not make the food hot HELP!!!!! the sides and top and bottom of microwave are warm but food is...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 14, 2010 | Emerson Microwave Ovens
The turntable runs and finishes the programmed warming time but the food is still cold.
The microwave generator may be burnt out. If it's under warranty your in luck. Otherwise, your better off buying a new microwave. Prices have come down dramatically so a new unit won't cost much more than haveing yours repaired.
Sep 06, 2010 | GE JVM2070 Microwave Oven
GE microwave oven Spacemaker Moldel / will not warm food
the most likley problem is the magnetron has gone bad.but there are a couple of thermal sensor in the cabinet that need to be checked. one of those could be bad as well.
Feb 25, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Open Questions:
GE Microwave JVM1441BH04: Safe to reconnect replacement stirrer & turntable motors after accidentally burning out the turntable motor? GE JVM1441BH04 Over Stove Microwave: Tapping noise was coming from the 21v AC stirrer motor which sits atop the cooking chamber. I disconnected the two connecting leads, unfastened the single screw holding it on, placed in on my scanner glass to get a high rez photo of all the specifics listed on the motor label. Bad news: While waiting for the scan to finish, I warmed my coffee in the microwave on the highest heat for 30 seconds. I subsequently discovered the 21v AC turntable motor, which had been working just fine, was now no longer working, with infinite resistance across its terminals, and a burnt electrical smell. Both the stirrer and turntable motors are powered by a 24v tap off the magnetron fan. My theory: By running the microwave with the stirrer motor out of the circuit, I delivered excessive voltage to the turntable motor, which quickly fried. The 24v tap off the magnetron fan motor currently shows the correct 24v output. However, with both the stirrer motor and turntable motor disconnected, running the microwave for a few seconds shows approx 95v across the wire leads for both of the 21v motors. I have obtained replacement motors for both the noisy stirrer motor and the fried turntable motor. My question: Can I simply reconnect both motors in their proper locations, vow never again to run one without the other connected, and all will be well? Or will the newly installed motors simply be fried in a matter of seconds?
Jan 04, 2018 | GE Microwave Ovens
Microwave Ovens Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
