Question about NovaLogic F-22 Lightning 2 for Windows
I'm trying to run my F-22 CD on my Vista Home OS. I have a DOSBox which runs downloaded DOS programs, but doesn't like to work with CDs. I mount my E Drive the way I'm supposed to: Mount e e:/ -t cdrom e:/ install "But then I am told: Insufficient extended memory to run program Could not continue: File not found: setup.exe" So I'm a little lost. Any help would be appreciated.
    Problem Solver:
  • 7 Answers
Try with the config file. See if you have enough memory there. Also, some games "don't like" having a cdrom unit other than D, try mounting E as "mount e d:\"
Posted on Jul 30, 2011
Also you need to do mount for drive c:
so that error message: "insufficient extended memory..." will never raise again
Posted on Aug 18, 2012
Will 1944 across the rhine run on Windows Vista Ultimate?
i can run 1944 atr fine now on windows 7
- it does just involve using Dosbox - which is an awesome program that can run most ms dos games and allows for alot of tweaking so the game runs perfectly.
get dosbox, its free - and then read up on how use it
you can then just mount the cd drive or cd image in dosbox and install the game from there. - you can then even just make a shortcut with added commands that will run the game by just clicking on the short cut
make a conf file for the game - i found that switching cpu to normal and having cpu type as a 'pentium_slow' works well
Jan 14, 2012 | MicroProse 1944: Across the Rhine for DOS
I have lighthouse/darkbeing 1996 and it will not install on my computer I have windows7 on mty laptop
This is an old program (DOS/Windows 3). It will not be compatible with a Windows 7 computer. (If you have the 64-bit version, you probably will have even more compatibility issues.)
Try using the program DOSbox, a DOS emulator: http://www.dosbox.com/download.php?main=1 . Download the Windows version (it will work under Win7 x64 and 32-bit). Install the program then see if you can install the game. If that doesn't work, you will need a program that can make a .iso (image) of the CD. A possible option is MagicISO Maker: http://www.magiciso.com/download.htm . Save the iso to your hard disc and then mount the image in DOSbox . This is a two-step process much like in UNIX. You will need to mount the hard drive and then mount the image. The commands would look like: mount c "c:\images"
imgmount d "C:\Lighthouse.iso" -t iso
Then go to the D drive and run the game as you did when you played on your previous computer.
I hope this helps.
Sep 14, 2011 | Computers & Internet
I have an old print master gold 16 program. Can I some how download it and make it work on my Windows 7 program
you can buy virtual machine program and use older stuff with windows 7. it will require u to install that os also to run it. please vote
Dec 21, 2010 | Computers & Internet
DEAR SIR I HAVE COMPAUTER HP COMAQ DC 7900 I WORK WITH SOME PROGRAM WORKING IN DOS .. THAN I NEED INSTALL DOS OPERATING SYSYTEM THE COMPUTER DON'T RESPON ... ALSO THE COMPUTER DON'T HAVE LPT I BRING CARD...
the best way to do this is probably use windows and run dosbox for windows. What it does is it emulates DOS and lets you run any program that requires dos. Because your computer doesnt have a LPT port. and nowadays only drivers for dos or newer operating systems come with the card. installing the driver in windows then running dosbox, it will see the LPT port.
you can get it here
http://prdownloads.sourceforge.net/dosbox/DOSBox0.73-win32-installer.exe?download
May 04, 2010 | Computers & Internet
Hi, I bought Lemmings many years ago and could not get it to work on my old computer. I now have a new computer running vista. But I still can't see how to run the software. The copy I have is Lemmings for...
In order to run old DOS games on Vista, you will need to use a DOS emulator. One of the best DOS emulators that you can download and use for free is DOSBox.
Here is the link for online instructions for setting up DOSBox:
http://www.dosbox.com/wiki/Basic_Setup_and_Installation_of_DosBox
Apr 05, 2010 | Psygnosis Lemmings 3D for Windows, DOS
How do u find the ms dos drive
That's because ms dos isn't supported in windows xp
Check out this site for dosbox, a dos emulator
This program should allow you to run all your old dos games
even has support for windows Vista
Nov 02, 2009 | HP Compaq 6510b Notebook PC
How to run turboc in full screen in windows vista ultimate
Windows Vista And above doest not support full screen command window.. In order to run dos programs in full screen mode u can you use dosbox emulator which will be more convenient. Note that if you use pointers in your program it may not wok under vista directly.. If u run under the dosbox emulation it will work fine.. You can download dosbox from http://www.softpedia.com/get/Programming/Other-Programming-Files/DOSBox.shtml
Sep 22, 2009 | Microsoft Windows Vista Ultimate Edition
How to run turbo c++in vista 64 bit os
You can run Turbo C++ 3.0 on Windows XP 64 bit , Vista 32 bit and 64 bit OS (in full screen)
Install the software DOSBox ver 0.72 (Freeware) from the link below (Direct Link)
http://prdownloads.so urcef orge.net/dosbox/DOSBox0.72-win 32-in staller.exe?download
Before going to the details u have to create a folder (any name will do).
Here we name it as Turbo
Copy the TC into the Turbo folder
Run the DOSBox 0.72 from the icon located on the desktop or from the location of the installation folder
Then u are presented with two screens which look like the command prompt in Windows
Now u are presented with two screens. One with a Z prompt. U can ignore the other screen.
There type the following commands at the command prompt [Z]:
Mount [Type in any alphabet that u wish except z] [Type the source of the turbo C] press enter
For example (Type in the following commands after the Z prompt):
Z: mount d c:\Turbo\ [The folder TC is present inside the folder Turbo]
* Now u should get a message which says: Drive D is mounted as a local directory c:\Turbo\ ***
C:\> cd TC [The contents inside the folder Turbo gets mounted as a virtual drive (Here D drive)
source site :
http://mycomputer.freefor ums.o rg/running-turbo-c-in-full-scr een-m ode-help-t1241.html .
Sep 03, 2009 | Microsoft Windows Vista Ultimate Edition
Where in the USA is carmen sandiego doesn't seem to load under vista properly? resolution and quicktime not functioning at all.
Where in the USA is Carmen Sandiego I believe is an old DOS game. It won't run properly in Vista but if you use a DOS emulator then you can properly run the game in vista cause your fooling the program into thinking that its running in the old DOS environment.
Try DOSBOX, its a dos emulator that runs in windows and it allows you to run those old DOS games. Go to www.dosbox.com its a free program and it comes with instructions on how to use it.
May 05, 2009 | Computers & Internet
Software
You could try using DOSBox.
DOSBox is located on the Web at : http://www.dosbox.com/
You can download DOSBox at: http://www.dosbox.com/download.php?main=1
Hope this helps. Thanks!
Sincere-One
Jul 21, 2008 | Microsoft Windows Vista Ultimate Edition
NovaLogic F-22 Lightning 2 for Windows Logo
1,122 people viewed this question
Top NovaLogic Video Game Consoles & Games Experts
James Wishart
TheTopMostDog
TheTopMostDog
Are you a NovaLogic Video Game Console and Game Expert? Answer questions, earn points and help others
