If you have the red light at start up here is how you can tell what is wrong with the system:
1 red light: This is the scaler or display chip you will need to get this repaired - see below.
Sometimes you will get an "E" Error message as well.
2 red lights - Pure and simple overheating, you will need to stop the heat build up in order to play your games again.
3 red lights - Most common error and happens when the GPU and the CPU overheat and the soldering snaps off you will need to repair this.
4 red lights - Good news you just need to plug your AV cable into the back of the Xbox 360 and it will work for you.
To fix the 1 and 3 red light you will need to send it in and they will fix it for you.
Or you can fix it yourself using a good Xbox 360 Repair guide, I hope this has helped you and if so place rate this so it can help others.
