Question about Garden
I cannot get the automatic watering program1 to work on my Philmac 6 station Dundee irrigation controller Stewart
  • 927 Answers
Remove the backup battery.
Unplug the timer for 10 seconds, this will do a full electronic reset.
Try to reprogram "program 1".
If this doesn't work, "program 1" may be damaged internally in the controller.
If it is adequate, use "program 2".
Reinstall backup battery.
Gary
Posted on Jan 01, 2011
Testimonial: "Following the instructions posted, the irrigation controller is working as normal. Really appreciated."
Where can I get a manual for 6 station irrigation timer?
Hi Colleen, The 1st link is a 2 page manual for a 4 & 6 station indoor controller and the 2nd link is a youtube video showing how to program an orbit timer, I hope this helps because you don't give a brand or model number.........CHEERS..
https://www.hunterindustries.com/sites/default/files/IC_EcoLogic_EM.pdf
How to Program an Orbit Easy Set Logic Timer
Apr 27, 2016 | Orbit Hardware & Accessories
Shows station 2 and 3 on screen but watering does not commence. Have reset numerous times same result.
bad solenoids or valves. also check and bleed air out of sysyem. bleed screws are on top of valve
Dec 12, 2015 | Orbit Irrigation 57856 6 Station Easy Dial...
How to wire
First check the solenoids by performing a continuity test on all of them. For all the solenoids that test good, power each one with 24 volts to make sure that the plunger moves. Then go to the timer and initiate an ON cycle for, say, zone one. Go to the zone 1 connector on timer and check for presence of 24 volts ac. If not present try zone 2 for output. If nada then there is something wrong with the electronics of the timer.
Mar 28, 2015 | Orbit 6 Zone Automatic Irrigation Watering...
Unable to get stations 3-5 to work on my irrigation controller
Include product model and brand when asking question so we can access manual and review possible causes
Aug 16, 2014 | Hardware & Accessories
Need operating instructions
Go to Orbits web site and download instructions. Or since you have the least expensive timer known to man simply buy another one for $20.00 then you will have instructions and a spare timer. You will need it trust me.
Jan 23, 2014 | Orbit 6 Zone Automatic Irrigation Watering...
"my orbit easy dial 6 station quit working in auto
Does it work manually? If so, which is rare and almost unheard of I would replace the timer. You can't buy a less expensive timer $20 for a 4 station. Which explains why it is not working. If it doesn't work make sure it is plugged in and outlet has power.
Aug 11, 2013 | Orbit Irrigation 57856 6 Station Easy Dial...
Model 57882 9 station timer I did set up station 1 where do I begin in order to set up station 3
Question is not clear.
Do you have programming problem with the timer?
Or problem locating sprinkler heads?
Or a sprinkler valve problem?
Add a comment with detailed information.
Sprinkler timer turns ON-and-OFF.
Timer does not advance the sprinkler to next station. The sprinkler valve advances to next station when timer turns OFF.
For example, when timer turns ON, then station 1 starts watering.
Timer turns off, and then sprinkler valve automatically advances to station 2.
Timer turns on again, and station 2 starts watering.
Orbit resources:
http://www.orbitonline.com/support/
http://www.orbitonline.com/lib/media/InstallationGuide.pdf
http://www.irrigationdirect.com/media/manuals/owners-manuals/orbit/Orbit-WaterMaster-57880-Controller-Owners-Manual.pdf
Aug 02, 2011 | Orbit 57882 9 Station Super Dial...
Lost instruction manual to set timer on oasis dundee 6 station sprinkler system
I can't locate any info on that timer. There is no timer that I can't figure out, I'm an irrigation contractor. Tell me what the face looks like or what buttons or dials are on it and I'll see if I can help.
Gary
Mar 11, 2011 | Garden
Some sections of RainBird irrigation system not working.
The next step is to go to the control valves, can you turn on the remaining 4 via manual lever?
If so, the next step is to test the valve itself. disconnect the wires from one valve that IS working, and connect to one that is not. If that one works, then the issue moves upstream to any other connections, and the unit's programming...
Typically, you just turn off the water source, and not the controller... as you can still have water flow....
Sep 18, 2009 | Hardware & Accessories
Garden Logo
334 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
