Question about Dometic Rooftop RV Air Conditioner
I turn my air conditioner on off, and it still comes on
  • 2,133 Answers
Press blow switch.
Posted on Jan 01, 2011
Air conditioner has loud hollow sound
After mine set up, I turned it on and it made a steady clanking sound, turns out there is black foam that is supposed to be glued behind the cooling fan and it had come undone and was hitting the fan. Slide the unit out of its shell and reach your hand in there and see if anything has come loose. (the fan towards the rear of the unit) good luck.
Mar 29, 2012 | Frigidaire FRA256ST2 WallWindow Air...
Airconditioner turns on and off automatically.
It is normal for an air conditioner to turn off and on automatically. This keeps it from making the room too cold. If it has a digital thermostat, set the thermostat to what temperature you want it to be in the room. If the air conditioner has a knob that says "colder", you let the air conditioner run until the room is comfortable to you and then you turn the knob very slowly toward warmer until the air conditioner turns off, and then very slowly turn it back to colder until the compressor comes back on. It's normal for a non-central air conditioner to run the entire time you have the power turned on but the compressor, which provides the cooling, will turn on and off when only when cooling is needed.
Sep 20, 2009 | Samsung AW0603B Air Conditioner
How do I make my air conditioner come on?
fan either collapsed on bracket or there is something stopping the blades from turning... other than that fan capacitor stuffed
Jun 15, 2009 | Star 8000 BTU Electonic Window Air...
Air conditioner is set on cool & furnace is turning on
probably your compressor not running or the air con is out of Refrigerant.
Jun 06, 2009 | Intertherm P3RA-048K Air Conditioner
Honewell air conditioner wont turn on
Sounds like with the limited infomation that you lost a capacitor inside the condenser. need more info. Does the fan inside the furnace come on?
Sep 21, 2008 | Honeywell ER150B Air Conditioner
Air conditioner fan will not come on and unit will run for 1 minute and stop
You hear the compressor kick in (Hum) but no fan comes on? Will the fan come on when just in fan mode, not cool, or do you have that set-up?
Aug 13, 2008 | Dometic Rooftop RV Air Conditioner
Air conditioner and heater come on by itself
Has anything been changed since it last worked well or normal? Thermostat ?
Aug 04, 2008 | Coleman Mach III Air Conditioner
Air conditioner not working
the outside condesor unit is not coming on for a number of possible reasons. First check your breakers for a tripped breaker, even if they appear on, turn the ac breakers off and then turn them back on. if after this, turn on the thermostat, outside you should here the contact switch on the condensor unit humming. if still no power, check for any breaks on your wires going in from the house, still nothing give a call back
Jun 24, 2008 | Ruud UAKA030 Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
19 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
