Question about Watches
I have a LP 28117RO the 24 hour time setting is off by a couple hours I can't fix it unless I know exactly how to. ~adam
5 Suggested Answers
  • 19 Answers
SOURCE: 24 hour time setting to 12 hour
You can't! Trust me I have been dealing with watches for 2 years now and currently work in the industry as a watchmaker's assistant.
There are different settings for each different brand, Casio have there own configure and so does Seiko etc.
Best way I know is to push buttons to something happens. Please note DO NOT DEPRESSED ALL PUSHERS AT ONCE, this 99.99% of the time will reset the entire device!.
Usually there is a 'reset' pusher which will once depressed (either immediately or after a few seconds of pushing it) will flash, then you work out which one is the 'next' button until you get to the 12/24hr then press the Up or down pusher (usually but NOT always opposite side to the 2 previously menitioned pushers).
As for auto's or quartz that's another matter.
Hope this helps?
Posted on Jul 12, 2009
rokkitsci
SOURCE: athletic wrist watch stuck in 24 hour mode
Maddening, isn't it? Fortunately the solution is here:
http://www.ehow.com/how_5593310_set-athletic-works-watch.html
1 There should be four buttons: mode, reset, start and light. Find the mode button and press it three times until it is in the set time mode.
2 Find the reset button, which usually is located on the bottom right side of the watch face, and hold it until the time starts blinking.
3 Press the start button to change minutes.
4 Press the reset button again to switch to hours.You will know it worked when the hour starts blinking instead of the minutes.
5 Press the start button to change the hour. The watch can handle two modes: standard and military. As you press start, the hour will change from AM to PM, noted by an "A" or a "P" in the top right. When you get through 24 hours, the watch will change to military time and an "H" will be displayed instead of "A" or "P." Keep pressing start to go through another 24-hour cycle and it will revert back to standard time.
Posted on Jan 05, 2010
cmcduncand
  • 714 Answers
SOURCE: how to change from 24 hour to 12 hour on g shock
http://world.casio.com/wat/download/en/manual/
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Posted on Feb 19, 2010
  • 2501 Answers
SOURCE: How do I set my mudman to display 12-hour time
If you haven't got instructions on how to do this, you can get
instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Posted on Apr 19, 2010
How to set for 24 hrs.
Dec 29, 2015 | Watches
How do you set the day of the week and 24 hour on the watch?
You only have to pull the crown of your watch to its third position ( to set the time) so that if you turn it until it reaches 2am or 3 am the day moves and you have to continue it until you reach the exact day of the week. Then, you don't have to set the 24 hour on the watch because the time remains the same on with the time on your watch. observe it. I hope that i had solve your problem.
Jul 08, 2011 | Michael Kors Mk5039 Wrist Watch for Women
How do you set the day of the week?
Since you didnt tell me what KIND of watch it is I am giving you a general instructions.
  • Wait until the second hand is at zero (the top of the dial). Then pull the crown knob out as far as it will go to set the time on your watch. Turn the knob in either direction and look at the three additional hands on the time dials of your watch: the minute hand, the hour hand and the 24-hour hand.
  • Step 2 Stop turning the knob when all minute and hour hands are pointing to the correct time. Pay special attention to the 24-hour hand so that you have a.m. or p.m. correct.
  • Step 3 Push the knob back in exactly when a new minute is starting so that your second hand will be correct. Use another clock you know to be accurate as a reference, such as the government clock available online.
  • Step 4 Pull the knob out halfway so you can set the date. Turn it counterclockwise until you notice the date on the watch changing. Stop it and push the knob back in to its starting position once you reach the correct one. Try to set the date before 9 p.m. If you set it after that time, it may not register with your watch that it should switch the date at midnight. If this happens with your watch, just fix it the next day.
  • Step 5 Set the chronograph, or big dial, on your watch. It works like a stopwatch to let you time activities for up to one hour. Push the top button on the side of your watch to start it. Push it again to stop it. Push the bottom button on the side of your watch to reset it.
  • It would certainly help if next time you let us know what kind of watch it is you have, Best of luck.
    Aug 11, 2010 | Watches
    How do i set the the 24 hour hand in a rolex 16758
    Yours is the original GMT Master. The GMT Master II allows the GMT hand and the regular hour hand to be set differently but not on your older model. On yours, the regular hour hand the the GMT hand are fixed so that if the triangle on the rotating bezel is at the top, the GMT hand will indicate local time. To indicate time in a 2nd timezone, rotate the bezel to orient the time to the GMT hand. There's a copy of the original instructions posted at: http://www.rolexforums.com/showthread.php?t=45269
    Apr 30, 2010 | Bulova Watch
    Timex 1440 time from 24 hour clock to 12 hour
    Hi bowingman,
    To use 12- or 24-hour time for your watch, please follow the instructions below.
    1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
    2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
    3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
    4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
    5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
    6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
    Hope it helps.
    Thank you for using FixYa.
    Oct 09, 2009 | Timex 1440 Nylon watch
    Athletic wrist watch stuck in 24 hour mode
    Apr 30, 2009 | Watches
    Cannot change from 24 hour to 12 hour also did not change to daylight savings time
    To change from 24 hour to 12 hour, you hold down the "Mode" button until it switches from 24 hour to 12 hour or vice versa. To change the time zone, you hold down the "Set" button until the time zone that you set it in flashes (like "LAX" on my watch). Then you press the "Receive/Start/Stop" button to choose the specified time zone you want. To set for daylight savings time ("DST" on the watch), after holding the "Set" button and having the time zone flash, you could press the "Mode" button. It will give you a few options for the daylight savings time (Auto, On, or Off). I chose the "On" option, which immediately changed for daylight savings time. If you manually want to change the time, you could hold down the "Set" button and keep pressing the "Mode" button until the time starts flashing on your watch, then pressing the "Receive/Start/Stop" button until you change it to the time that you want. You could also set the watch to beep or chime after pressing the set button if you wanted to know that piece. You hold down the "Set" button when you are done to get it to stop flashing. These instructions worked for my Timex T5G341 Universal Radio Control Watch. I hope this helps.
    Mar 08, 2009 | Timex T5G341 Sports Radio Control Watch
    Acqua Indiglo water resistant watch with alarm 30m
    Press and hold the MODE button (bottom left) for approximately 3 seconds.
    When the Alarm set time starts flashing, press the MODE button once more. Now the seconds for the watch time should be flashing.
    Use the START/STOP button (top right) to move bewteen items and the SPL/RESET button (bottom right) to change the item.
    Moving between all items, it will take you through: seconds, minutes, hours, month, date, day of the week. Simply press MODE when your settings are complete.
    Jul 25, 2008 | Watches
    Aquatech watch
    press mode button 3 times untill you get into the time set mode - press lap/reset twice until the hours start to blink.
    press start/stop and cycle thru all the modes depending what time you want to set - it will go thru 1, 2, 3, etc thru 24 H then 1, 2, 3, etc thru 12 A then 1, 2, 3, etc thru 12 P - depending on thte time you want to set the A is for AM and the P is for PM
    hope this helps
    jeff
    Jul 23, 2008 | Watches
    Watches Logo
    32 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
