Tomtom GO 700 GPS Receiver Logo
Posted on Jan 01, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I replaced the battery and now when I turn it on all I get is a x flashing. How do I get all the functions back?
Computer Links
Level 3:
  • Master 2,386 Answers
  • Posted on Jan 01, 2011
Computer Links
Master
Level 3:
Answers
2386
Questions
Helped
718477
Points
7718
Hello
U need just one original file from your tomtom and that is ttgo.bif so keep that file safe and copy everything from working unit (even better with patched system) to your unit, !!!!! dont use TomTom Home !!!! just through drive (if its not there cant help), just possible that u need now maps activated for your unit.
Good Luck
Why doesn't my battery charge? Why doesn't the charger's light come on?
Hi Suzanne! Follow these steps to check that your charger and battery are working properly.
1. Unplug the charger for at least 30 seconds.
2. Plug the charger back in. The blue light on the charger should flash once.
If the blue light flashes once this is an indication that the charger is still functioning properly. If the blue light does not flash, the charger will need to be replaced. Follow this link to order a replacement charger. LiNX Battery Charger
3. Place the battery in the vacuum and turn it on for 30 seconds. (even if it does not turn on or powers off)
4. Turn the vacuum off.
5. Remove the battery and place it in the charger.
If the light on the charger is solid blue this is an indication that the battery has been reset. Allow 3-4 hours for the battery to fully charge. The blue light will start to blink slowly to indicate the battery is fully charged.
If the light on the charger is flashing blue or there is no light at all this can mean that your battery needs to be replaced. Follow the link to order a replacement battery. LiNX Lithium Ion Battery
Hope this helps!
3answers
Sony Cybershot DSC-W55 Flash Error Code
1. Turn OFF cam
2. Remove the battery or the power supply
3. Turn the switch to CAMERA for about 30 sec
4. Turn the switch to OFF
5. Install the battery or power supply
6. Turn the switch to MEMORY
7. Open the LCD cover and press the RESET button ( small inner button )
8. You will be prompt to adjust date/time. Do it
9. Take some pictures
Mar 24, 2008 • Cameras
tip
Flashlight Battery and Bulb Installation and...
FLASHLIGHT
BATTERY INSTALLATION FOR TORCH:
Open the Torch Battery Door located on the bottom of the Torch.
Insert 4 “A A” (1 .5V UM-3) (not included) batteries (alkaline
batteries are recommended) into the torch compartment. Be sure
the polarity (+ and
-) matches, as marked inside the battery
compartment.
FLASHLIGHT:
Slide the Torch Function Switch to the “FLASH” position, the Torch will light. To turn off, slide the Torch Function Switch to the “OFF’ position.
FLASH/BLINK FUNCTION:
Slide the Torch Function Switch to “FLASH/BLINK” position, tha Torch will light and thc bulbs on both sides of Torch will blink.
BULB REPLACEMENT:
Rotate the Torch Cover anticlockwise to hear “click”
then p
ull out the cover, remove the old bulb. Then pull
out the torch cup, remove the blinker’s
old bulbs and
reinstall new bulbs. Replace the torch cup, then reinstall
Low battery showing replacing batteries does not solve problem
The flashing low battery symbol is the way Canon film cameras showed that the camera has had an error and has stopped functioning. It can have multiple causes - but for a quick check remove the lens, turn off the camera and then turn it back on - see if the symbol stops flashing. A problem with the lens can also cause this problem (usually a failure of the aperture unit)
My Polaroid Impulse camera will turn on, but it will not flash. Theres no film in it. It used to flash when I would press the button but I fiddled with it and now the flash doesnt work.
These cameras require a battery, which is integrated into the film pack, to function. Without this battery, the shutter, flash, and motor will not function. If there is an old pack in the camera some functions may work, but there is probably not enough power for the flash to function.
Dec 13, 2010 • Photography
How do you turn the flash on? (with the vivitar vivicam 8018)
Your camera has a built in flash function which enables you to take photos when the light condition is not good.
1. Press the Up button. (for reference of buttons, please see the below figure mentioned)
2. Press the Up button once until you see the icon appear on the LCD screen. This indicates that the flash is forced on.
3. Press the Up button again to change to the auto flash function.
4. The icon will appear at the top of the LCD indicating that the auto flash is turned on and ready to use.
5. Press the Up button again to change from the auto flash to the red eye function.
6. The icon will appear on the LCD indicating that the red eye reduction function has been activated.
7. To turn off the flash function, press the Up button again until the icon is displayed on the LCD.
Note: A “Low Power” message will appear on the LCD screen, if you select the flash function when the battery power is insufficient. To continue using the camera with the flash, please change new batteries
4answers
I replaced the battery to honeywell RTH230B. Heat won't turn on.
I followed a comment from a previous source and reversed the polarity of the batteries. I then flipped them back to the correct position and the flashing battery indicator went away and the thermostat functions correctly.
1helpful
Phone wont turn on
replace the battery it will no longer take a charge. it has enough power in battery to turn on but not to function. a new battery will solve your problem.
Flash use "kills battery dead"
The most likely culprit is a several year old battery that is not accepting or holding a sufficient charge. Turning the camera on, and taking a non-flash photo may not tax the battery too much. However, when the flash is called for, the power demand may exceed the battery's ability to deliver enough juice. A new(er) battery is probably your best bet to resolve the problem.
My Flash stopped working, but I don't understand the manual instructions.
To ensure the flash is functioning study the manual and check the LCD menu to such a feature as a flash on/off control.
Top Tomtom GPS Experts
k24674
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
