Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Poulan wild thing, new chain and bar (now burnt up) oiler not putting out oil. Chain and bar oil bought at tractor supply same as saw. Where do I begin to find the problem or is it just shot?
Check and see if oiler is plugged with wood dust no its not shot lol
Posted on Mar 26, 2011
Poulan Wild Thing bar oiler adjustment
there is no adjustment for the oil flow i find the screws that hold the pump on loosen up and then leak oil
Jun 09, 2012 | Poulan Wild Thing 2375 18" Gas Chain Saw...
The oiler will not work i took the bar and chain off cleaned everything but it will not oil the chain
Most machined will have an oil filter in the tank, drain the chain oil out and fill the oil tank with a suitable cleaning fluid, rinse the tank out a few times, this will help to clean the filter if it is blocked.
Feb 04, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
When cutting wood saw will not oil chain whats the problem
make sure oiler jet under the chain tightener plate is clean even take bar and chain off and start saw
Dec 12, 2010 | Poulan 18" Wild Thing Chainsaw
Brand new poulan pro 4620avx--bar oil is coming out of oiler but not getting onto chain
Hello. Thin your bar oil just a wee bit with some kerosene. If you have a gallon of bar oil add 1/4 cup of kerosene, stir it up and you will be fine. For starters also, directly apply some bar oil to the chain so that you are always using a well lubed chain. Joe
Oct 03, 2010 | Poulan Pro Chain Saw 46cc 20"
Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin: I own a Wild Thing 18". I don't believe the auto o...
Remove the bar and chain. Start the engine and observe the side of the engine where the bar fits to it. The oil port there should ooze oil out when the engine runs fairly fast. If nothing, then investigate the filter within the oil tank for plugging, the oil line from the tank to the pump for any damage or decay, and the oil pump itself. The pump should discharge directly to the port that the bar receives. If oil did ooze out of the port on the first test, then clean the oil passages in the bar end--two small channels that run from each large hole out to the chain groove on each side. Clean the entire chain groove. Check the sprocket on the other end for fairly free turning--oil it's bearing. Examine the chain carefully--if it got so hot that it turned the teeth blue--replace the chain, it has lost it's tempering. Assemble bar and chain--adjust the chain so that the lower side doesn't droop from the bar, and you can turn the chain by hand. The teeth cut toward you on the bottom run. If the old chain is being reused, sharpen the chain carefully so that it cuts quickly without undue effort on your or the engine's part. Hope this helps!
May 17, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Bar oil leaking constantly. How do I fix it?
These saws are of the self oiling type there is no tip or bottle it consists of a tank and a channel the oil flows thru and on to the bar by gravity. There is a type of bar oil system on some saws that come with a button you push which In turn pumps oil onto the bar. But the poulan is not one of them. I have a 15 year old farm hand 20" bar and a two year old poulan wild thing 18" and both leave there oil in the case when sitting I beleive the fix would be drain it after use and clean up.
Mar 21, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Automatic chain oil leaks oil?
possible crack in the reservoir, or line has come loose
Feb 05, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Chain oiler does not seem sufficient
The chain oiler injects oil into the rear of the bar where the cover mounts over the sprocket. Take the bar off and clean out the oiler hole. There is usually some buildup of sawdust in the hole. Clean out the grove that the chain guide runs in all the way around the bar. You can see the injector nozzle under where that bar was when you removed it. Sometimes there is an ajusting screw there to increase oil flow.
Sep 12, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Leaks oil in case from chain oiler
hi
check the oil line,the oil hose has to be at the right place.
regards savumihai71
Dec 02, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Chain oiler
take off cover to the bar, remove chain and bar. spray degreaser or hot soapy water in and around the interior housing. look carefully and you should see a small hole that is where the chain lube comes from. typically all you need is a good cleaning in this area. hope this helps.
Nov 04, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
265 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
