IPhone will not play over speakers. As soon as plugged in it says no volume available on iPhone. I'm pushing play/pause button and is on iPhone source
    President:
  • 2,047 Answers
Usually the iPhone only supports certain headphone jacks into its system. When some devices are connected to the iPhone the iPhone does not produce sound because it does not support the device on the other end. The iPhone unlike the iTouch is sensitive to the kind of device which it is connected to most of the time.
Hope this explains the problem?
Posted on Jan 01, 2011
Turn off demo mode
try pressing and holding the play/pause button on the remote. This should reset the unit and turn off demo mode.
Aug 24, 2015 | Samsung HW H550 Channel Wireless Soundbar
The volume on my iphone 5 is not working
I can safely say you connected your iPhone to a speaker dock sometime in the past.
When connecting an iPhone to a speaker dock, the volume control is set through the speaker and not through the iPhone.
Sometimes after unplugging the iPhone, the iPhone keeps thinking that it's connected and won't let you change the volume through the iPhone.
To fix this - simply plug your iPhone to a speaker dock again and unplug it until you can manage the volume with the iPhone.
Apr 08, 2014 | Apple iPhone 5
Set time on clock radio CS238-5G
This is the way I worked it out, as soon as you've plugged in the unit, push the MEM button for a couple of seconds then push the PLAY/PAUSE button and hour will start to flash then use the arrow buttons to change hour, then push PLAY to change minutes. Once you've finished minutes push PLAY again. Not sure about setting alarms though and if you get stuck, unplug it and start again.
Mar 26, 2014 | GPX CRCD6306DT Clock Radio
Adjust volume on bluetooth mini speaker PSNANO PS-38
Quoted from the instruction manual:
"+/>>'" In TF/Bluetooth mode when short press this button: next song; long press: Volume up. Don't work in AUX mode.
"'<<\-" In TF/Bluetooth mode when short press this button: previous song; long press: Volume down. Don't work in AUX mode.
">''" In TF mode, short press this button: Play/Pause; In Bluetooth mode, short press this button: Play/Pause/Answer/End/Cancel dial/Pair. In Bluetooth mode, double click: Last number redial; long press for 2 seconds: reject calls. In TF/AUX mode, press it will be TF card and AUX exchange.
Aug 04, 2013 | Lands Phones
Operating manual for Plain Lazy Alarm Clock iPhone/iPod Speaker Dock
No instruction manuals for the 'Plain Lazy' ipod docking station/alarm clock found on line :-( So after tinkering with the buttons for quite a while, II have worked out how to set the clock. Press & hold the play/pause button & at the same time press the skip back button once....let go of both buttons. Then immediately press the play/pause button again once & the clock numbers will start flashing. Press the skip back button to adjust the hours & skip forward button to adjust the minutes. Press the play/pause button to set!
Aug 04, 2012 | Audio Players & Recorders
Iphone volume when disconnected from bluetooth
The iPhone detects when earphones are plugged in, and deals with volume differently as your speaker volume may be inappropriate for the use with earphones. Bluetooth is managed with the same volume level as earphones. Once it is disconnected manually adjust the volume with the volume buttons or check if your silencer button is not activated. Hope this helps!
Jun 01, 2012 | Apple iPhone 4S
I have a cda-9883 alpine that is in demo how can i take it off demo and have it play normal?
hold down the function button until the display changes. you can then toggle things like dimmer ,aux, and demo by turning volume control. when you see demo push the play/pause button which will then allow you to turn it off by again turning the volume button. once its off press play/pause button which will allow you to toggle other functions. then hold function key down again to get back to main display(main display will eventually return on its own)
Dec 10, 2010 | Car Audio & Video
Compatibility issues iPhone 3G - JBL On Stage IIIp
hi there, believe it or not, apple has put a authentication chip into newer devices. It won't allow you to play music or display video on devices that are old. Apple wants you to go out and buy new accessories for the new stuff to make more money. My suggestion is to sell it on eBay and use the money to get a newer compatible dock with your iPhone.
Feb 17, 2010 | On Stage Stands JBL On Stage IIIP Portable...
How do you turn the volumbe up and down on my camnex mp3 player [t850 4g]
push the play button (V on the top of the unit - other end is pause II) until the volume level (number in the lower left corner beside the speaker icon) turns green (2 or 3 seconds), then push the FF button >>I to raise the level or the REWIND I<< to lower the level
Oct 20, 2009 | Mach Speed TRIO Onyx MP3 Player
88 people viewed this question
 Grubhead
Grubhead
