Question about LG WM1814CW Front Load Washer
The grey drain hose split, anyone know how to replace this? Is it attached to the drain pump in the front? Also discovered that black drain tube is clogged at the front filter. This tube seems to be breaking down, i.e. clogged, black stuff leaking. I want to replace with clear vinyl. Is it attached near the drain hose, how hard is it to get to? Looks like you have to full disassemble this washer? Is that correct? Thanks
  • 472 Answers
The drain hose is indeed attached to the pump area... sounds like you may be on well water if it is breaking the hose down that bad... if not that is unusual to have hoses break down like that... its not hard to replace the hose as they just have hose clamps on them ,but yes you do have to tear apart unit to get down to drain pump assembly... some of the units have a front kick plate you can remove to get to them and some you actually go into from the rear... i didn't look this model up but we work on all appliances and normally there is a way to access the drain pump.... some units front loaders you can actually tilt up and the bottom plate will remove to gain access to it also... just going to have to look around and make access the easiest way for you... once your in though it is a simple task to replace hose...
Posted on Jan 01, 2011
My whirlpool duet front load has been leaking. It leaks only when doing a load of laundry. Leak is coming out the back and on the right side. Took the front bottom off to see if I can see anything and...
First, make sure that the washing machine is not too close to the wall behind it. This could crimp the drain hose & force water out at the connection behind the machine. This could also crack/split the washer machine's port (to which the drain hose attaches). Second, check the hose clamp for a secure hold at the washer machine's port, & check the drain hose for leaks & for insertion in the drain tube at the wall.
Feb 22, 2015 | Whirlpool Washing Machines
How do u replace the drain hose on the inside that is connected to the pump
most washer are set up pretty much the same ill do this by number so you can follow
1 make sure you empty washing machine either by spin cycle or manual drain through kick flap at front make sure you have rags towels bowl 2 unplug the plug from electrics 3 turn water supply off at wall disconnect water inlet pipe 4 now all electrics and water are disconnected you need to disconnect the drain hose usually attach to drain pipe behind wash be careful these are usually full so drain off 5 if you can manage yourself carefully put washing machine on its side put some towels down to protect 6 underneath usually to the front right bottom is the sump pump with the sump hose black and the drain hose grey and the manual drain hose now either by clip or screw loosen the drain hose it is usually attached up the sides by clips they can just be pulled off one free from the sump motor just pull it through if refitting remember its just all reversed what you have done good luck
Mar 10, 2013 | Siemens WFXD5200UC Front Load Washer
Fridgidaire Affinity front load washer not draining
It is your pump it is probably clogged not the hose the actual pump mine was full of hair and a quarter. so it would not drain.
Aug 27, 2012 | Frigidaire Affinity ATF7000E Front Load...
Water leaking from bottom of my WFL2860 during draining
Check the hose clamp connection on the water pump.
Aug 03, 2011 | Bosch Washing Machines
Leak in front
It leaks Your washer can develop several types of leaks. You can track down a leak based on when it occurs: During fill only During drain and spin only All the time During fill only If the washer leaks only during the fill cycle, check these: Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it. The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak. Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak. During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details. All the time If the washer leaks all the time, check these: Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate. Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician. Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it. Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details
Jan 15, 2010 | Maytag Neptune MAH5500B Front Load Washer
Water leaking from washer
Jan 01, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Rip in the rubber seal on my Kenmore Elite Quite Pak4 HE3plus..
you can get new seal at  www.repairclinic.com Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
All the time
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
May 06, 2009 | Kenmore Elite 45986 Front Load Washer
Amana washer model LW6501W2 leaks in front during fill up
During fill only
All the time
Apr 01, 2009 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Water leaking from bottom of front lode washing machine
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
All the time
During fill only
All the time
Dec 01, 2008 | Frigidaire FTF530FS Front Load Washer
Model WM2277HW leaks
Leaks from the bottom of the machine are usually related to a sump issue.
You will have to remove the rear panel from your machine to see leak happening. Do not reach into the back of the machine while it is powered if possible. Be extremely careful.
The rear panel is held on by 4 screws, with these removed the panel will pull away from the back of the machine.
With great care you will need to start the machine to observe where the leak is coming from.
At the very bottom of the machine is a black rubber tube that attaches to the bottom of the tub. It splits and goes forward towards the drain pump & filter unit and it also goes towards the back of the machine and attaches to a white air chamber which connects to the fill switch via a long black rubber tube.
Leaks will usually occur in the rubber sump hose; at the air chamber; at the pump connection or pump; or in the drain hose. Careful inspection of these points should reveal its location.
Leaks coming from the tub area can either be a center tub seal or from the inlet water at the top of the machine traveling down along the tub.
Further clarification of the leak location is needed for further diagnosis
Jun 27, 2008 | LG WM-2277HW Front Load Washer
LG WM1814CW Front Load Washer Logo
314 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
