Question about GPS
My unit gets nice reception in my car, but I have yet to obtain a signal in my home. I have a southern exposure and have aimed the antenna due south, but have never gotten a signal. Can you suggest a remedy. Thank you, Larry L6IRON@aol.com
    President:
  • 1,378 Answers
GPS systems need unobstructed access to satellite signals. They will not work anytime there is enough interference with the signal. In some vehicles that can even mean if mounted on a dash board instead of being on or close to the windshield. Handhelds have the same issues. Unless you have an external antennae wired to the unit they will not work indoors.
John
Posted on Jan 01, 2011
I have a Samsung tv, model # LN32A550P3FXZA. I've been trying to hook up an antenna but so far can't get good reception. Could the problem possibly by my tv tuner? Too old or bad?
Sounds like you're in the fringe area of the antenna. Depending on how far you are from the broadcast antenna, You may have to increase the length of the pole that antenna is on or get an antenna that has a greater range in miles. Digital signals are real picky about antenna aim. If you have a long cable between the antenna and the TV, you might try an inline amplifier.
Oct 19, 2017 | Samsung Televison & Video
Hi, On a newer Kenworth truck has built in xm radio. Every thing was fine till , near as I can tell, I was waxed the top of the cab. Did not disturb the antenna in anyway, however now when I travel north I...
The signal comes from low in the Southern horizon, so if you have a trailer it is blocking the antenna. You would be best off to buy a special trucker antenna that mounts on your mirror and gets it a little bit higher and away from the trailer blocking the signal from the south when you're driving North. Okay? good Luck.
Mar 29, 2015 | Audio Players & Recorders
How do i upload the operational directions for my 500 satellite computer on my computer
Sony Satellite Dish Antenna Operating Instructions
Operating a Sony satellite dish is a process that first requires correct dish placement to ensure strong signal reception. Additionally, the satellite receiver must be installed, and only then can you use it to put the dish in operating order via the use of its signal meter screen. Fortunately, you do not need to be a professional to complete these operations properly.
  1. Initial Sony Satellite Mounting
    • Look around for a suitable mounting area for your satellite dish. This mounting area should be free of any debris and also allow for a flat mounting area. It's best to utilize a hand-held level to measure and make sure that your Sony satellite dish lies flush with the mounting surface beneath it. Also, look to the skies above before settling on a mounting area, as obstructions such as trees, power lines and tall buildings can block signal reception for your Sony satellite dish. Once a spot is chosen, go ahead and crudely aim your Sony satellite dish to the southern sector of the sky above. This will save you some time later when you return for further adjustments
Read more: Sony Satellite Dish Antenna Operating Instructions ' eHow.com http://www.ehow.com/way_6312070_sony-dish-antenna-operating-instructions.html#ixzz1NYml5eFe
May 26, 2011 | Toshiba Computers & Internet
Am/fm radio stations not clear... I have the AM antenna attached... but there is no attachment for FM
First of all check for any nearby source of interference.....Move your unit away from all computers, fluorescent lights, neon lights, microwaves, cell phones, and cell phonemag-glass_10x10.gif chargers. These devises tend to produce noise in the medium frequency band, where AM radio is broadcast.
If the unit plugs into the wall with a nonpolarized plug (where both prongs are the same size), try reversing the plug inmag-glass_10x10.gif the outlet. Moving the plug to another outlet might help, too.
check for fault in the antenna lead, (common) or bad earth on the antenna to body
If you don't have an antenna connected to your FM receiver,With a receiver or tuner, connect a wire-loop or T-shaped dipole FM antenna to the back of your unit. Move the antenna until you get the cleanest signal. Use a signal-strength meter or display to gauge signal strength if your unit has one.
  • Step 2 If you're still not getting a good signal, try an indoor amplified antenna, which you'll find at an electronics store. Don't buy one unless you get a guarantee that you can return it for full credit if it doesn't solve your reception problems.
  • Step 3 If your signal is weak because you live a long way from the transmitter, install an outside antenna and mount it as high as is practical. If you're primarily interested in getting signals from one station or from a group of stations in one direction, get a directional antenna and point it toward the transmitters.
  • Step 4 If you're using a portable FM radio where the only antenna is the power cord, stretch the cord as straight as possible and experiment with positioning again.
  • Step 5 Temporarily switch to monaural mode to improve a weak signal on an FM receiver.
  • Read more: How to Strengthen FM Radio Reception | eHow.com http://www.ehow.com/how_114024_strengthen-fm-radio.html#ixzz0u9nhGXAL
    If your signal is weak because you live a long way from the transmitter, install an outside antenna and mount it as high as is practical. If you're primarily interested in getting signals from one station or from a group of stations in one direction, get a directional antenna and point it toward the transmitters. Make sure to Switch from stereo to mono.
  • Step 4 With a receiver or tuner, connect a wire-loop or T-shaped dipole FM antenna to the back of your unit. Move the antenna until you get the cleanest signal. Use a signal-strength meter or display to gauge signal strength if your unit has one.
  • Step 5 Alternatively, upgrade to a third-party passive or powered antenna.
  • Step 6 Install a rotatable roof antenna for the best possible reception. Connect your unit to an existing televisionmag-glass_10x10.gif roof antenna for the next-best alternative.
  • Read more: How to Improve FM Reception | eHow.com http://www.ehow.com/how_5554_improve-fm-reception.html#ixzz0u9oTaz4Y
    Jul 19, 2010 | RCA RT2760 System
    No reception
    your antenna connection inside the unit is broken on the circuit board,i had one of these and repaired it numerous times by taking the unit apart and resoldering the connection at the board,also their antennas don't last long as far as the antenna plug end is concerned
    Apr 30, 2010 | Delphi MyFi SA10113 XM Radio Receiver with...
    I hooked an antenna up and can't get a picyure!
    I assume you have tried to retune the TV & angle the antenna in different positions. Very often, due to the location of your home & the strength of signal in that area, you usually find that , no matter what you try, an indoor antenna is just not strong enough to pick up in a weak reception area. The only alternative is to try & add a signal booster onto it or much better still ( and a lot less future reception problems) is to rig up an outdoor antenna.
    Sep 01, 2009 | JVC AV-32D305 32" TV
    Delphi SKYFi3 XM Radio Repeater
    You begin by setting up your existing (((XM))) antenna the one that came in your home kit (not included in repeater package) in a location that gets good reception of the (((XM))) signal. This may be outside, or on a south facing window sill. This antenna gets plugged into the rear of the Delphi (((XM))) Radio Signal Repeater Transmitter. A power jack is right next to the antenna connection, and should be plugged in and to the wall with the included power supply. There is also a "PWR OUT" selector switch on the rear of the unit which allows you to control the strength of the signal transmitted from the unit.
    Once the power and antenna are attached, both blue indicator lights will light up on the face of the unit. The blue antenna indicator will light up only to signify that the antenna is attached correctly. It does not let you know whether your antenna is in a location receiving a good (((XM))) signal or not. You will have to look at the signal strength indicator on your (((XM))) radio receiver do determine best location for the (((XM))) antenna.
    Once you have this setup, place the Repeater Antenna close to your existing (((XM))) Radio and plug it into your antenna jack on the (((XM))) radio cradle. This connector is identical to your (((XM))) Home Antenna provided with all Boom boxes and (((XM))) home receivers and kits so compatibility is guaranteed. The Repeater Receiver Antenna does not require any separate power connections. Hope this helps!
    SATELLITE RADIO WAREHOUSE
    Jul 10, 2009 | Delphi SKYFi3 XM Radio Receiver
    I get no stations on my tv
    Use an Antenna that Provides Good Reception of All Channels
    • Most existing antennas used by consumers will provide good reception of DTV signals. (Before making any changes, try your existing antenna first to see of it allows you to receive all the stations you normally watch.)
    • For watching DTV signals, you will need an antenna that provides good reception of both VHF signals (channels 2-13) and UHF signals (channels 14-51) to reliably receive all of the digital signals broadcast in your area.
    • Many antennas are designed only for reception of either VHF or UHF signals (but not both). For example, the commonly used “rabbit ears” indoor antenna is only suitable for receiving VHF signals. To receive UHF signals, an indoor antenna should also include a wire loop or other feature for reception in that band.
    • The reception capabilities of TV antennas also vary considerably, so be sure to talk to retail consultants and look at information on the packaging and/or the Internet to make sure that any new antenna you may choose provides good reception of both VHF and UHF channels. In addition, if you use an indoor antenna and receive signals on VHF channels, you may need to use an antenna with amplification.
    • Many antennas currently being sold as “HDTV Antennas,” perform best at receiving UHF signals; some of these models state that they provide reception of signals on channels 7-13 but actually perform less well receiving those channels. If you obtain one of these antennas, be sure it provides good reception of all the VHF channels as well as the UHF channels.
    • To check for the DTV signals that are available at your location, use the DTV Reception Maps available at www.fcc.gov/mb/engineering/maps.
    Check Your Connections
    • Check that your digital-to-analog converter box or digital television is connected properly. Make sure your antenna is connected to the antenna input of your digital-to-analog converter box or digital television. If using a digital-to-analog converter box, also ensure that the antenna output of your converter box is connected to the antenna input of your analog TV. Refer to the owner’s manuals of your components if you are unsure of the proper connections.
    • Ensure that your components are plugged in and have their power turned on.
    • If you have a digital-to-analog converter box, tune your analog TV to channel 3. You should see a set-up menu or picture displayed on your TV screen. If you do not see a set-up menu or picture, tune your TV to channel 4. If you still do not see a set-up menu or picture, recheck your connections.
    Perform a Channel Scan
    • Digital-to-analog converter boxes and digital televisions have a button, usually on the remote control, that is labeled “set-up” or “menu” or some similar term. Press that button to access the set-up menu. Using the directional arrow buttons on your remote, scroll to the option that allows you to perform a “channel scan.” The channel scan will automatically search for digital broadcast channels that are available in your area. Consult the owner’s manual of your digital-to-analog converter box or digital television for detailed instructions on how to perform a channel scan for your device.
    • Once the channel scan is complete, you will be able to tune to the digital channels received by your antenna. You should perform a channel scan periodically to check whether additional digital channels have become available.
    Adjust Your Antenna
    • Small adjustments to your antenna can make a big difference in the number of digital channels you can receive. If you have an indoor antenna, try elevating it and moving it closer to an exterior wall of your home. After adjusting your antenna, perform another channel scan to see if your reception is improved.
    • While adjusting your antenna, it may be helpful to access the “signal strength meter” on your digital-to-analog converter box or digital television to determine whether your adjustments are improving the signals’ strength. The signal strength meter is usually accessed through the menu feature on your remote control. Refer to the owner’s manual of your device for detailed instructions on how to access its signal strength meter. Remember to do another channel scan after you have adjusted your antenna.
    • Television stations broadcasting in digital use both the VHF band (channels 2-13) and UHF band (channels 14-51). Many indoor antennas use “rabbit ears” for the VHF band and a “loop” or “bow-tie” antenna for the UHF band. Make sure you are using an antenna that covers both the VHF and UHF bands and have connected it properly.
    If You are Still Having Difficulty:
    • Until June 12, 2009, some stations will be operating at reduced power levels. If you are not receiving certain digital TV stations, this does not necessarily mean there is a problem with your antenna or digital-to-analog converter box or digital television. Check with the TV station to find out whether they are planning changes that will improve reception.
    • When an analog TV signal is weak or receives interference, static, snow, and distortion will often appear on the screen. Digital broadcasting will provide a clear picture; however, if the signal falls below a certain minimum strength, the picture can disappear. This “cliff effect” means that if you watch analog TV stations that have static and distortion, you may have to adjust or upgrade your antenna system.
    • Simple indoor antennas provide minimal performance that may not be suitable for your location. If you are unable to obtain satisfactory DTV reception with your current indoor antenna, you may wish to obtain an indoor antenna that includes features for better reception of UHF signals, as well as VHF, and/or an amplifier to boost the received signal (often referred to as an active indoor antenna).
    • Generally, an outdoor antenna will get better reception than an indoor antenna. However, the performance of outdoor antennas can degrade over time due to exposure to the weather. If you are having problems, check for loose or corroded wiring, broken antenna elements and that the antenna is pointed in the right direction.
    • Try to keep the length of wire between your antenna and digital-to-analog converter box or digital television as short as possible for best reception.
    • “Splitters” that are used to connect a single antenna to multiple digital-to-analog converter boxes or digital televisions reduce the amount of signal available to each device. If you are having problems, check whether reception is improved without the splitter. In some cases an “active” splitter that includes an amplifier can solve the problem.
    • If you are near a station’s broadcast tower, reception of that station, as well as other stations, can be impeded by strong signal “overload.” Consider using an “attenuator” or removing amplifiers to improve your reception.
    • If you decide to replace or upgrade your indoor or outdoor antenna, many types are available from electronics retail stores at a variety of prices. Websites such as www.antennaweb.org provide information on the locations of broadcast towers and the types of outdoor antennas appropriate for the stations you wish to receive. If you need assistance with upgrading your antenna system, check with a local antenna retailer or antenna installer.
    Hope it may helps:
    Regards:
    VOTIT
    Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
    Poor antenna reception
    That's a problem with the digital broadcasting. Signal strength is critical, and the frequencies used are more directional. Some people are finding they get no reception at all. Your antenna may not need to be higher, but aimed in a different direction. Did you have a rotator installed as well? An outside antenna really should be pointed toward the station. You might also be able to add an amplifier to the antenna to boost the signal. But get a mast-mounted version that mounts right at the antenna, not the kind that goes at the TV set.
    Apr 09, 2009 | Televison & Video
    Roady gone wild
    Called service and they asked if I had a remote close to the unit, I did and they suggested that the battery was low on the remote possibly. I took the batt out of the remote and several hours now with no channel changes or shutting off. the second thing was to make sure that the power adapter was giving steady current.
    Dec 05, 2007 | Delphi Roady XT XM Radio Receiver
    GPS Logo
    22 people viewed this question
    Top GPS Experts
    Will Halftowaite
    Are you a GPS Expert? Answer questions, earn points and help others
