Need new plug where can i get one - Washing Machines
  • 784 Answers
you can get a new plug at your local Home Depo,Lowes or hardware store.
c...
Posted on Jan 01, 2011
On my 97 Saturn sc2 I changed plug wires and #3 spark plug. Had trouble getting plug to seat correctly and now it runs really rough. What could be wrong?
There may be something wrong with the new plug so I would first try a new plug other than the first new plug that you tried. Baring that you may have bad or damaged threads in the head so in that case the head may need pulled and put in a shop that a professional can fix.
Oct 02, 2016 | Saturn Cars & Trucks
How do I change the spark plugs
if you follow the spark plug wires they should lead you to the spark plug. when you remove the spark plug wire you may want to give it a little twist just to break it loose from the spark plug than pull the wire off. than you just use the right size spark plug socket to take the old plug out and to put the new plugs in once the new spark plug are in just push the spark plug wire back on. make sure you gap the spark plugs right if you don't you could end up with a misfire in that cylinder also be careful not to crack the new plugs if you do you will need to get another new spark plug.
Jul 02, 2015 | 2005 Hyundai Tucson GL
How to change the spark plug
1 Spark Plug Spanner 1 New Spark Plug
Pull H.T Lead off the top of Spark Plug, You need Spark Plug spanner to do the job. Untighten Anti Clockwise, Check Gap is correct on the New Plug ! Hand Turn the New Plug into hole, carefull as threaded. Tighten up , till tight , do not over tighten or you might strip thread, Put cap back onto Plug . FINISHED
Mar 14, 2015 | Garden
Need to find location for a 1972 mercedes 280 sel
I think the Bosch W230T30 were stock. new Bosch # is W5d1.
If you've updated the original plug wires to a non-resistor type, you may need a resistor type plug instead of the stock plug.
Oct 22, 2014 | Core New Core One Bullet Spark Plug...
Steps to change a spark plug
easy job replace one spark plug at a time.you need buy new set of spark plug wires and spark plugs.reason need new wires possible old ones will break from inside plug boot when you remove plug wires.you need basic 3/8 ratchet wrench.you need long short extensions.need spark plug socket.need spark plug gap gauge.need a universal joint connect to the extensions to reach sharp angles.make sure engine cold when replacing spark plugs could damage heads.use a 12 inch piece vacuum hose to help aid in installing sparks in hard reach spaces with out damaging crosss threading plugs threads and cylinder head threads to plug.
Apr 25, 2013 | 1998 Pontiac Grand Prix
I have oil on tip of plug wire on only 1 of my spark plugs,all others have a little oil on spark plug itself.I just had the timing belt done ,water pump all sealas and head gasket,new wires do i need to...
You need a new Valve Cover Gasket. The rubber seals around the spark plug holes on the Valve Cover are leaking. A new Valve Cover Gasket will come with the round gaskets that seal the spark plug hole.
Jul 30, 2011 | 1995 Honda Accord
Freeze plug broke what do i need to fix it
You will need a screwdriver to pry the old one out a new rubber freeze plug and a wrench and socket and ratchet to tighten the rubber freeze plug.Also you will need anti freeze to refill the cooling system.
May 10, 2011 | 1998 GMC Jimmy
What does a major tune up for a 2004 chevy impala consist of? What should be done and needs to be done?
New spark plugs, oil and oil filter, transmission flush and fill, fuel filter, air filter, coolant flush and fill, clean throttle body plate and bore, clean the MAF sensor, replace any loose or cracked vacuum lines, PCV valve, new air filter, new battery.
99% of the time all you should ever need for a tune up is new spark plugs, and a clean air filter and throttle body. But since your inquiry indicated "major" I gave it more critical thought.
Feb 18, 2011 | Chevrolet Impala Cars & Trucks
How to change spark plugs
This is a pretty straight forward job though I cant recall if you need to do anything special to reach some of the plugs.
You may need a tool to pull the boot off of the plugs. Now is a good time to go ahead and change the plug wires. If the plug wires stick to the plugs hard enough they could break during removal.
You will need various length of extensions and a special socket for the plugs to help prevent breaking them. Experienced mechanics often do it with a regular deep socket but better safe then sorry.
unplug the wires from the spark plugs makeing sure to keep them in a logical order because they have to go back in the same spot they came out from. If you are worried about messing up here then just do one at a time.
Unhook the spark plug wire from the plug. remove the plug. check the gap(these days I notice that most of the new plugs are already gapped to the right spec. but it doesnt hurt to double check) on the new plug. Carefully thread the new plug in and tighten it up. plug the spark plug wire onto the new plug. Move to the next plug, rinse and repeat.
Mar 13, 2010 | 1993 Ford Explorer Limited
Replace spark plugs and wires
ive found easiest access is to lower inner fender walls and change plugs from there
Nov 07, 2009 | 2000 GMC Yukon XL
Washing Machines Logo
Top Washing Machines Experts
