Question about Frigidaire Refrigerators
Frig (Model FRS26zph)won't make ice - everything is hooked up and should be working - any suggestions?
  • 770 Answers
Do you get water at the door dispenser?
Posted on Jul 08, 2008
My ice maker on my kenmore refrigerator is not working. a red lightg is flashing on the ice maker. everything looks ok, no ice though!
I had the same issue with my frig. I read on line where Someone open the freezer and ran a hair dryer in it. So I tried it I turned off the water draned the water side out left my door open while I had the hair dryer running for a half hour then turned the water back on and sure enough after the line unfroze and it started making ice. there was a little blurb on the freezer about how much water presure was needed. I found this information just by doing a google search on my model frig.
Nov 24, 2010 | Kenmore Refrigerators
I have a Jenn-Air side by side frig. The freezer side cools too cold, the frig side not enough. 2 weeks ago I took all the food out of freezer and noticed ice build up on back. I unplugged unit, let it...
If the freezer is staying cold it sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem.
There is a small duct between the freezer and refrigerator side if this is blocked the frig side won't cool.
Jan 09, 2010 | Jenn-Air JCD2389G Side by Side...
I have a kitchen aid refrigerator freezer. The
the supply line of the ice maker might be blocked please check it.
Aug 18, 2009 | Refrigerators
Ice maker won"t work
Give it at least 24 hours to get started. May need to turn freezer colder also.Make sure Arm on ice maker is not locked in up position. I don't know what jump means. If it has been in frig for a long period with out water but still going through the motions there could be other problems. But if it was just hooked up give it time to get going.
Jun 28, 2009 | Kenmore 53642 / 53644 Side by Side...
Frig Freezing EVERYTHING!
Your refrigerator has electronic dampers that may be only stuck. I think it would not hurt to defrost the refrigerator and lets have a look at those damper motors and see if they are responding to your control settings. Let me know, Sea Breeze
Jun 17, 2009 | Samsung 26.0 Cu. Ft. Side-by-Side...
I have a GE Frig 2 years old It make crushed ice when you press the cubed button. It's making cubed ice fine just not dispencing everything else works fine. It is model No. GSH25JSTASS and Serial NO....
could be a problem with micro switches inside the dispenser. it has small switches that when you press the button outside, you are pressing a switch inside and if they are cross wired or what ever, these things happens. if you are familiar with electrical wiring trouble shooting, then i could guide you but if not, then i suggest you call a qualified tech to help you with this kind of problem.
it is as if the wires were interchange. cube button would dispense crushed ice then the crushed ice button is not working.
tnx 4 using fixya,
drcool
Oct 07, 2008 | GE Refrigerators
Kenmore - Ice Maker Not making much ice
check water inlet valve on your frig
Nov 06, 2007 | Refrigerators
Maytag side by side MSD2735GR
well sometimes it clogs up , when i open the frig door sometimes the ice falls out since the actual cup in inside of frig is full of the crushed ice.
Sep 11, 2007 | Maytag MSD2756G Side by Side Refrigerator
Refrigerators Logo
98 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
