Question about Brother LX3125 Sewing Machine
My knob that lifts my needle up and down won't turn and I'm afraid to force it there is no thread tangled up in it.
    Genius:
  • 1,788 Answers
One thing I would try is, take a screw driver (short stubby straight) and open the throat plate under the presser foot, you may be surprised that a lot of lint is there, resembling a piece of felt, sort of, that should not be there. Clean it out and lube your machine as per your manual. Change your needle and rethread. Another thought is that the belt for your machine is disengaged, then you have to take the cover off and check that. Good luck to you, I hope that I helped. Happy New Year
Posted on Jan 01, 2011
My needle arm is stuck down
The needle may be tangled with thread in the bobbin case. Can you remove or lift up on the feed plate? I have had a tangled thread web hold mine down before. I used tweezers and small scissors to cut the thread up and pull it out.
Jul 14, 2014 | Sewing Machines
Sewing machine
The top thread is probably breaking due to the bobbin thread tangling.
First-off fit a new needle .... do that anyway ! And if you haven't recently cleaned your machine (and you should do it every week as a minimum), clean-out under the stitch plate, remove the hook, clean the hook race and give it a small drop of oil, even if you're using the lightweight plastic hook/shuttle. Check that you have adequate bobbin tension ... when you pull the thread out of the bobbin case there should be a bit of resistance --- technically, this should be set-up using the correct tool and a set of weights, but if there is no, or very little resistance, you need to increase the bobbin tension a little bit at a time using the small screw that holds the tension spring down onto the bobbin case. This is a very fine adjustment, so you may find you only need to turn the screw less than a quarter turn to get it right. Ensure that, when you thread the top thread up, you do-so with the foot lifted so that the thread goes down properly between the top tension discs.If you're still not getting anywhere, check the basic timing/needle depth by looking at some of my other posts on the subject.
Nov 26, 2011 | Bernina Activa 140
I am sewing scout badges on a uniform and when I sew there is a bunch of needle thread bunched up on the bottom (the top looks fine). And the needle thread gets all caught up around the bobbin.
Clean out the bobbin area if there are any thread tangles there.
Refer to the maintenance section of the manual - see the configuration of the bobbin case and shuttle race? The bobbin case as an extending arm and the race a notch. When inserting the bobbin case into the shuttle, turn the handwheel so the needle is at it's highest position. Then lift the lever on the back of the bobbin case and insert the cast into the shuttle, arm pointing straight up toward the bed of the sewing machine.
Now thread the machine with the presser foot up - always - and see if the tangling stops.
When you forget to lift the presser foot before threading the machine, the tension control does not open to capture the thread. Then when you begin to sew, the top thread has no tension, and the bobbin thread, which does have tension, pulls the top thread to the bottom in messy loops.
Jun 25, 2011 | Kenmore Sewing Machines
Just started to tangle up and jam up not letting needle to go down making a metal noise followed by jaming noise
Sounds very like a bent needle or jammed bobbin case. have you cleared any broken threads or replaced needle? Lift the needle plate and check under that too.
Nov 26, 2010 | Brother CE5000 Computerized Sewing Machine
After taking only a few stitches, the bobbin thread becomes tangled and knotted. I've cleaned and oiled the shuttle and cover and adjusted the tension, but it still happens. Advice?
have you tryed changing the needle?
have you tryed changing the thread on top & bobbin area?
some thread & needle are not compatable--here's a tip I learned from a sewing expert
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
hope this helps
Oct 12, 2010 | Husqvarna Husky 145
Needle's thread gets tangled in bobbin
First, open the needle plate and make sure the bobbin area is clean and free of lint and thread.
Check the needle to make sure it is not bent and is properly inserted into the holder - usually with the flat side facing to the back of the machine.
Refer to your manual for bobbin insertion to be sure the thread is feeding from the bobbin in the correct direction and through the proper guides.
Always thread a sewing machine with the presser foot up. This opens the tension control and allows the thread to properly enter.
When the foot is down, the tension control closes to the sewing setting and if the thread is not in place, there is no tension on the thread and it gets loopy.
After threading, lower and raise the needle while holding onto the thread tail. This will pull the bobbin thread up through the needle plate. Take hold of both threads and take them under the presser foot and to the back of the machine.
Hand walk the first stitch when sewing and this should keep the top and bottom thread from tangling.
When stopping to change the position of the fabric (turning a corner, sewing a curved seam for example), do so with the needle down into the fabric. This not only anchors the fabric so it does not slip, but prevents mis-stitching.
If you are doing everything according to the manual and are still having a problem, the machine may need to be professionally serviced.
Feb 23, 2010 | Elna 1010
Its like it is getting tangled in bobbin casing
loopy on bottom means upper threading or tension is wrong
Aug 10, 2009 | Brother XL-3510 Mechanical Sewing Machine
Janome mylock 634D overlocker
this very same thing happened to my flat machine turned out to be a piec of material jammed in the workings also wrong oil used or it might be thread jammed try and see
Feb 25, 2009 | Janome MyLock 634D Mechanical Sewing...
Thread breaks
Hi!
Check to see if the lower thread be tangled. Also, the bobbin could be threaded improperly in the shuttle hook. Rethread the bobbin in the shuttle hook.
How to detangle a thread---
  • When a machine stops operation due to tangled thread, do not turn the pulley by force.
    If the pulley is turned by force then, lower thread might not be picked up correctly and stitches might not be formed correctly.
  • If threads get tangled, remove a needle plate and cut the tangled threads by scissors or cutter.
  • Do rate the solution if you find it helpful & useful.
    Thanks
    Rylee
    Jan 30, 2009 | Husqvarna Viking 1
    Jammed
    ROLL THE MANUAL LEVER BACK AND FORTH WITH CONTROLLED FORCE till the needle comes out! the jamming is caused by threads tangled inside the bobbin area. rolled it with a controlled force back and forth. when the needle comes out flip your machine to where you could open the bottom part and remove/clean the threads tangled on the bobbin!
    place some OIL.
    Nov 19, 2007 | Singer 1116 Mechanical Sewing Machine
    Brother LX3125 Sewing Machine Logo
    52 people viewed this question
    Top Brother Sewing Machines Experts
    Tally Girl
    Tally Girl
    Irene Tulloch
    Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
