Question about LG Heating & Cooling
Lg multi type airconditioner cassette type ceiling airconditioner red light flashing at the same time the green light is flashing the remote turns the aircondioner on then the flats close after a few minutes and the airconditioner wont work
  • 2,133 Answers
Drain motor get locked. call repairman to disassemble your indoor for drain pan cleaning and reset. Unit will work o.k.. Helpful?
Posted on Jan 01, 2011
How to fix lg code ch51
What is the model of your air conditioner. With out that information i cant help you with your ac repair problem.
Check us out online at AC Service Delray Beach Fl
Apr 23, 2016 | LG Inverter Flex Multi Indoor - 4 Way...
My indoor lg mini split unit the cool light flashes 4 time what's wrong
Indoor unit faults = CH04 or C4
Fascia LED's
- RED = None
- GREEN = 4 Flash
Contents = Drain Pump / Float Switch
Case of Error = Float Switch Open Circuit (High Level Water Alarm)
Indoor Status = Off
clean your condensate drain line you can do this with a shop vac,
Read more: http://dgoma.es/multisplit_lg/lg-multi-split-units-error-code/#ixzz34dr3Cu00
Follow us: dgoma on Facebook
May 26, 2014 | LG LMN127HVT LMN127HVT 12 000 BTU Ductless...
Error code for LG underceiling airconditioner
check error codes again LED 1 and LED 2. there is no 64 error code.
May 12, 2014 | LG Heating & Cooling
LG 32LC56
that problem is usually cause of faulty T-con board..
Aug 25, 2012 | LG Televison & Video
Wiring instructions are terrible. Ceiling wires = Red, Black, White, Copper. Fan wires = Black, White, Copper. Remote wires = Neutral in(Black), Live In(Black), Light out(White), Fan out(White),...
That is dificult to follow .. here is the usual wiring plan for ceiling fans .. green to green or bare and mounting bracket ... ceiling black and red are live from the switches, fan and light.with a remote you really only need one of these , so cap off the red and use the black as your input to the remote .. the neutral to the remote should be the white .. there are only 3 wires from the fan so I am assuming that there is no light , or the light will be activated from the remote .. the black for the fan and the black for the lights connect to marked wires on the remote. .. lights out, fan out
or looking at your description .. ((Remote wires = Neutral in(Black) white ceiling wire, Live In(Black) blaxck ceiling wire, Light out(White) blue Fan/Light wire, Fan out(White) black fan/light wire, Common(White) white ceiling and white fan/light wires.
May 21, 2010 | Hunter 27148 Remote Control
Pioneer PDP435PG inadvertently reprogrammed by Casablanca remote.
Some ceiling fans have jumpers that can be moved to select a different frequency but you have to be sure both the remote and the fan receiver are set the same. Other than that, you may have to use some creative control. For example, I can turn on my TV by pointing the remote at the wall opposite the TV
Mar 29, 2017 | Pioneer PDP-4350HD 43 in. Plasma...
I want to find the Sky remote code for this Tv.
Just got an LG 42LH2000 and code 0206 works
May 16, 2009 | LG Televison & Video
Stand by light flashes red on powering up with remote and the green light flashes approx 15 or times before the screen illuminates.
thats pretty normal, it takes a good second or two to warm up and the display to turn on(at least0, you get the green flashes as you hold for on, 1 sec is a long time at times, lol, be patient, no problem with your tv!
Apr 22, 2009 | Televison & Video
Samsung aircon cuts off. lights green/yellow flashing
lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
Feb 11, 2009 | Heating & Cooling
TURNED OFF AND 5 WAY LIGHTS ON AIRCONDITIONER FLASHING, WON'T TURN ON
1.check selector switch.
2.wiring.
3. check cirkit board of aircondition
Jan 29, 2008 | Heating & Cooling
Heating & Cooling Logo
543 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
