Question about Zanussi 24 in. DA6141 Built-in Dishwasher
Buit in dishwasher
A cure for a leak right hand bottom corner of door
  • Zanussi Master
  • 43,501 Answers
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
Posted on Sep 29, 2010
Just installed the dishwasher and it is leaking from the the two front corners of the door
I dont know what brand your dishwasher is, but if it is leaking from the two bottom corners it is not level. If the back is higher than the front, the water will drip out of the bottom corners of the door. Raise the front feet up so that the edge of the door is flush with the cabinet doors from the top to the bottom.
Nov 20, 2010 | Dishwashers
Model # FDB1100RHB2 Dishwasher The dishwasher, since the installation just one month ago, has leaked continually (requiring a drip pan be placed beneath the door) from the lower left hand corner of the...
The door bottom is actually NOT sealed. Look into the levelness of the unit, and that you are using the correct soap. Both can cause water to leak by the door.
Look closely at the door alignment and make sure is did not get damaged along the way..
Nov 08, 2010 | Frigidaire Dishwashers
Hi, I have a small leak at the bottom right hand corner of the door. If you push in on the door while it's running it stops and the noise level goes down. Is there an adjustment for the door or would it...
No adjustment. Try cleanig door gasket. If still leaks hinge probably got bent from leaning on door. Or door got bent. Needs to be taken apart to find cause for problem.
Sep 27, 2010 | Bosch 24 in. SHE44C05UC Stainless Steel...
Leaking door gasket.
The followng link can give you some advice on how to diagnose your leaking dishwasher problem:
In most cases, the door gasket is worn and requires replacement. The steps to replace one are included.
Replacement parts (if required) can be purchased at any of the following websites:
Prices vary between sites, so shop and compare. The first three sites also have helpful exploded view diagrams to assist you in locating and properly identifying the parts you may need.
If you have any questions, please post back with your MODEL NUMBER and let me know. I hope this helps you.
Mar 05, 2010 | Dishwashers
I have a Magtag dishwaher that is leaking out of the bottom right hand corner somewhere. It is at least 10 years old, works great otherwise. What should I do ? Is it an easy fix? Is it worth it to fix it...
I will assume the leak is at the front on one of the corners of the door. We had this problem and it appeared to be caused by someone mistakenly placing too much weigh on the door when it was open. Our solution was to bend the door back in the opposite direction to get it "re-aligned". Hope it works for you too.
Regretfully ours just died after 10 years of service. Hoping to find a repair manual online.
Dec 29, 2009 | Maytag MDB7100AWB Dishwasher
LG LDS 5811 has started leaking at the bottom of the door left hand corner.
Could be 1 of 2 things.
1: Open door and look for any" Obstruction" Between the Door Seal and the Dishwasher.
2: the Seal is Warped from General useage or, twisted.
hope that helps
Please Rate Me
Apr 30, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
Fisher and paykel 913T soft touch dishwasher leaking
They do not have bottom seal, problem possibly is door cabinet seal or loose dispenser leaking, just had that problem woth one of those the other day
Aug 31, 2007 | Dishwashers
Zanussi 24 in. DA6141 Built-in Dishwasher Logo
267 people viewed this question
Top Zanussi Dishwashers Experts
Owen Barnes
Paul Carew
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
