Question about Intex Easy Set Pool 15x36
How many liters does it take to fill a 15 x 36 pool
    President:
  • Intex Master
  • 1,378 Answers
15' round by 36" deep? If so it would be about 13,300 L.
Posted on Jan 01, 2011
Give some example of math equation?
The following are examples of expressions:
x
3 + 7
2 × y + 5
2 + 6 × (4 - 2)
z + 3 × (8 - z)
Example:
Roland weighs 70 kilograms, and Mark weighs k kilograms. Write an expression for their combined weight. The combined weight in kilograms of these two people is the sum of their weights, which is 70 + k.
Example:
A car travels down the freeway at 55 kilometers per hour. Write an expression for the distance the car will have traveled after h hours. Distance equals rate times time, so the distance traveled is equal to 55 × h..
Example:
There are 2000 liters of water in a swimming pool. Water is filling the pool at the rate of 100 liters per minute. Write an expression for the amount of water, in liters, in the swimming pool after m minutes. The amount of water added to the pool after m minutes will be 100 liters per minute times m, or 100 × m. Since we started with 2000 liters of water in the pool, we add this to the amount of water added to the pool to get the expression 100 × m + 2000.
To evaluate an expression at some number means we replace a variable in an expression with the number, and simplify the expression.
Example:
Evaluate the expression 4 × z + 12 when z = 15.
We replace each occurrence of z with the number 15, and simplify using the usual rules: parentheses first, then exponents, multiplication and division, then addition and subtraction.
4 × z + 12 becomes
4 × 15 + 12 =
60 + 12 =
72
Example:
Evaluate the expression (1 + z) × 2 + 12 ÷ 3 - z when z = 4.
We replace each occurrence of z with the number 4, and simplify using the usual rules: parentheses first, then exponents, multiplication and division, then addition and subtraction.
(1 + z) × 2 + 12 ÷ 3 - z becomes
(1 + 4) × 2 + 12 ÷ 3 - 4 =
5 × 2 + 12 ÷ 3 - 4 =
10 + 4 - 4 =
10.
hope that help you
Jun 22, 2011 | LeapFrog Turbo Twist Math Cartridge 5th...
Hi, I have let my intex above ground pool go green over winter and with summer approaching don't know if I need to add extra salt or something else to get the pool ready for swimming. It is a 14 foot,...
You need to get liquid chlorine and add about 2 liters and let your pool filter run for a couple of days and in the mean time clean your filter twice daily. If the pool at this stage is still a little green add more chlorine and broom the bottom to stir it up. After this as once your pool is back to almost normal, clean the the filter again and add clarifya. To keep your pool in good condion over summer buy 2 pool floaters, put 2 chlorine tablets in one and blue block pool sparkle in the other and each week add 1 liter of chlorine. Hope this helps you as i have the same pool and i do this and don't have any problems. You can also add salt to your pool if you like but dissolve it in water before you add it to the pool.
Oct 25, 2010 | Intex Automatic Salt Water System for ...
How many liter is it
you need to be more descriptive or you can go to a web site with a calculator such as:
http://www.backyardcitypools.com/swimming-pools/Pool-Volume-Calculate.htm
Jun 30, 2010 | Intex Easy Set Pool 15x36
Fluid capacities and fluid specs
2000 TOYOTA TACOMA 2.7L 4-cyl Engine Code 3RZ-FE
Engine Oil Grade 1......API* All TEMPS......5W-30 Optional ..10W-30
Engine, 2WD, with filter..........5.5 liters
Engine, 4WD, with filter..........5.4 liters
Manual Transmission,......GL-5/ GL-4 All TEMPS......75W-90
Automatic Transmission,A340E......AF3 / A43D......AF3
Differential, Front/ Rear W/ ADRD......GL-5 ALL TEMPS......75W-90
Differential, Front Less ADRD......GL-5 ALL TEMPS......80W-90
Transfer Case,......GL-4/GL-5 ALL TEMPS......75W-90 Gear oil.
Capacity:
Cooling System, Initial Fill..........8.5 liters
Automatic Transmission, A340E Initial Fill..........1.6 liters
Automatic Transmission, A340F Initial Fill..........2 liters
Automatic Transmission, A43D Initial Fill..........2.4 liters
Automatic Transmission, Total Fill
4 speed A340E..........7.2 liters
4 speed A340F..........10.1 liters
4 speed A43D..........6.5 liters
Manual Transmission, ..........2.5 liters
Differential, With ADRD Front..........1.2 liters
Differential, Without ADRD Front..........1.1 liters
Differential, 2WD V6 Rear..........2.6 liters
Differential, 4WD Extra Long Rear..........2.5 liters
Differential, Short WB With LSD Rear..........2.7 liters
Differential, Short WB Without LS Rear..........2.6 liters
Transfer Case, Electronic..........1.2 liters
Transfer Case, STD..........1 liters
Feb 09, 2010 | 2000 Toyota Tacoma PreRunner
I am trying to fill the pot strainer with water so I can start the pool pump
If the pot is higher than the pool, it will never fill to the top. Just fill it to the inlet level and it should be enough.
Feb 05, 2010 | Pentair Challenger 3/4 Hp In Ground Pool...
Oil spec
1995 HONDA ACCORD 2.7L 6-cyl Engine Code C27A4 C27A1
Engine Oil Grade 1......API All TEMPS......5W-30
Manual Transmission,......SJ All TEMPS......10W-30, optional 10W-40
Automatic Transmission,MPZA......AF2
CAPACITIES:
Engine, with filter..........4.4 liters
Automatic Transmission, MPZA Initial Fill..........2.7 liters
4 speed MPZA..........6 liters
Manual Transmission, ..........1.9 liters
1995 HONDA ACCORD 2.2L 4-cyl Engine Code F22B1 VTEC
Automatic Transmission,A0YA......AF2
CAPACITIES:
Engine, with filter..........4.3 liters
Automatic Transmission, A0YA Initial Fill..........2.4 liters
Automatic Transmission, MP0A Initial Fill..........2.4 liters
4 speed A0YA..........6 liters
4 speed MP0A..........6 liters
Jan 07, 2010 | 1995 Honda Accord
How many quarts of transmission fluid does it hold
You didn't state what size engine you have.
The 2.2 engine----- 6.9 qts.
The 2.3 engine-----7.4 qts.
The 2.4 is 7.4 qts.
The 3.1 is 7.4 qts.
The 3.4 is 6.9 qts.
These are the capacities for refilling after being drained.
Nov 17, 2009 | 2001 Pontiac Grand Am SE
Trying to find out how much oil the Triton V-10 takes when I do my oil change? I cant seem to find it or anyone who knows
It should be listed in the owners manual, but because of different oil cooler setups you may have to do the change yourself and add oil until the correct level is established..... for the first oil change.
Most likely 7 liters,but start with 5,run the engine to fill the oil filter,let it sit for 5 mins and recheck and fill to full.
Note the amount needed for next time.
Nov 08, 2009 | 2000 Ford F250 Super Duty Crew Cabs
How much transmission fluid does my 2005 2.0 get.
2.0 Liter , Engine code (E)4G94Automatic Transmission, F4A4B-1 Initial Fill..........5.1 liters Automatic Transmission, Total Fill  4 speed F4A4B-1..........7.7 liters
Manual Transmission, ..........2.2 liters
2.0 Liter turbo, Engine code (D) 4G63 Turbo Manual Transmission, 6 SPD - W6MAA..........2.8 liters
Manual Transmission, 5 SPD - W5M51..........2.2 liters
Transfer Case,..........0.600000023841858 liters
Aug 18, 2009 | 2005 Mitsubishi Lancer
What are the fluid capacities for the 06 qd-2
5.7 liter V8 Engine code 2: Fluid capasity: Engine oil with filter 6.6 liter 5W-20,  Cooling system: Total fill 13.7 liter Automatic transmission total fill 13.3 liter Front differential 1.7 liter Rear differential 2.23 liter Transfercase 1.8 liter
4.7 liter Engine code N Fluid capasity: Engine oil with filter 5.7 liter 5W-30 Cooling system: Total fill 13.7 liter Automatic transmission total fill 13.3 liter Front differential 1.7 liter Rear differential 2.2 liter Transfer case 1.7 liter
3.7 liter Engine code K Fluid Capasity: Engine oil with filter 4.7 liter 5W-30 Cooling system: Total fill 10.0 liter Automatic transmission total fill 13.3 liter (W5A580 7.7 liter) Front differential 1.7 liter Rear differential 2.2 liter Transfer case 1.7 liter.
Hope this helps, and good luck.
Jul 03, 2009 | 2006 Jeep Commander
Intex Easy Set Pool 15x36 Logo
327 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Charles T Nevin
Charles T Nevin
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
