Question about Nokia 6030 Cellular Phone
Programming password for voicemail on a Nokia 6030
How do I program a "pause" in the voicemail preprogrammed number so that I can program the password and not have to type it in everytime I check my messages? Thanks in advance for your help......
  • 488 Answers
Use the hash key in between numbers..#
Posted on Oct 30, 2008
I don't have voice mail - where do record my message? If I want to my phone after the fourth ring.
many phones are preprogrammed with voicemail on speed dial #1. so hold down 1 as if you were dialing a number and see if that connects you to voicemail, then follow the prompts. if it asks for a password, most likely it is 1234 or 12345
Mar 16, 2016 | Lands Phones
How do I access my voicemail box from outside of the office?
There are 3 ways to access your voicemail:
1. Call into the main office and have the receptionist transfer you to your mailbox.
2. Call into the main office and if you hear an Auto Attendant, select #. Then, enter your mailbox number and password.
3. If you know what number your voicemail is tied to, then you just call the number, select #, and then enter your mailbox number and password.
If none of these options work, then whomever programmed it may have turned it off and you may need to contact the tech.
Sep 18, 2014 | Comdial Impact Telephone
Turn off voicemail 6408D+
Turning off voicemail is usually done by the voicemail administrator, they can reset passwords and add or delete a mailbox on an extension. The number of rings before going to voicemail is usually system wide, and that program is changed by whoever programs your phone system.
Apr 21, 2014 | Avaya Definity PBX Phone 6424D+ Gray
Dont know how to set voicemail and directory
1.Press the "Menu/Select" button.
2.Use the up or down arrows to navigate to the "Voicemail Setup" option and press "Menu/Select."
3 .Navigate to the "Access Number" option and press "Menu/Select."
4 .Use the number pad to enter your voice mail access telephone number provided by your telephone company. Use the "Mute/Remove" button to delete any numbers entered by mistake.
5.Press "Menu/Select" to hear the confirmation code.
6 .Program the "Password," "Play," "Erase," and "Skip" options following the above steps, substituting the "Access Number" option in step three with the option you desire to program.
7 .Dial your voice mail by using the "Voicemail" button on the telephone.
8 .Listen and follow the prompts provided by your telephone company to set up your voice mail's greeting.
9 .Use the "Voicemail" button any time you wish to dial into the system to listen to voice mail. Use the programmed "Play," "Skip," and "Erase" options to navigate through your messages.
Apr 15, 2011 | Vtech Lands Phones
Employee forgot his password and need to change the voicemail for new employee. Is there a way to reset the phone. Phone model is a Superset 4025. My phone number to the phone is (563) 690-3230 or email...
Each mailbox password is held in the system programming of the voicemail system. You need the system admin password for voicemail. Dial the access code for voicemail, if from a phone with voicemail then press * to get to the main greeting. At the main greeting dial * then the system admin mailbox number which is 99 for 2 digit ext numbers or 999 for 3 digit ext numbers or 9999 for 4 digit ext numbers then you will be prompted for the system admin passcode(default 1234). Press 2 for add/edit/delete (Never press 1 for new installation or you could delete all current voicemail programming and messages). Press 2 to edit mailbox, you will be prompted for the mailbox to edit, enter the mailbox number. Press # to skip to the passcode reset, enter the new passcode or press * to reset to default(999) then press # for each of the remaining parameters until you are returned to the mailbox menu which prompts for press 1 to add mailbox, 2 to edit mailbox, and 3 to delete mailbox, then hangup.
Dec 07, 2010 | Mitel Superset 4025 Corded Phone...
My imei no is 352272014489628 what will be the personal license key no
Here's a handy dandy set of instructions on how to unlock that Nokia 6030 phone you have lying around.
We'll be using the NokiaFREE Unlock Codes Calculator program for the unlock.
First download The Nokia Unlock Codes Calculator v3.10.
http://rapidshare.com/files/172046699/Nokia_FREE_Unlock_Codes_Calculator_v3.10_free-gsm-unlock.blogspot.com.rar
click the above link to download it.
Save it, open it up, and run setup. Install wherever!
Load up the Nokia Unlock Codes Calculator program.
The first thing you need to do is go to options! Go to options and check off the "Expert Mode" box located in the second box. This will open up some more options for you.
Now let's get started with the fun stuff. Type in *#06# on your 6030 (or look under the battery) to get your IMEI and enter it in the correct box.
Enter U.S.A. for the next box, and then CINGULAR - Pacific Bell Wireless in the box after that.
MCC+MNC should read 31017000.
Make sure the box under MCC+MNC reads ASIC 2, and change the V2 option to ONE.
Double check your numbers and click calculate!
You should have a series of unlock codes for the Nokia 6030 in the right hand box. They look like this:
#pw+xxx xxx xxx xxx xxx+x# (note: x = some number)
Enter this on your 6030 using the # and * keys where necessary. For the p's, the w's, and the +'s press the * key.
After you hit the final # key your Nokia 6030 should say "Phone Restriction Off" and you're done! Congrats!
Sep 07, 2010 | Nokia 6600
I need personel licence key my device serial no is 352274011090433
Here's a handy dandy set of instructions on how to unlock that Nokia 6030 phone you have lying around. We'll be using the NokiaFREE Unlock Codes Calculator program for the unlock.
First download The Nokia Unlock Codes Calculator v3.10. Save it, open it up, and run setup. Install wherever! Load up the Nokia Unlock Codes Calculator program. The first thing you need to do is go to options! Go to options and check off the "Expert Mode" box located in the second box. This will open up some more options for you. Now let's get started with the fun stuff. Type in *#06# on your 6030 (or look under the battery) to get your IMEI and enter it in the correct box. Enter U.S.A. for the next box, and then CINGULAR - Pacific Bell Wireless in the box after that. MCC+MNC should read 31017000. Make sure the box under MCC+MNC reads ASIC 2, and change the V2 option to ONE. Double check your numbers and click calculate! You should have a series of unlock codes for the Nokia 6030 in the right hand box. They look like this: #pw+xxx xxx xxx xxx xxx+x# (note: x = some number) Enter this on your 6030 using the # and * keys where necessary. For the p's, the w's, and the +'s press the * key. After you hit the final # key your Nokia 6030 should say "Phone Restriction Off" and you're done! Congrats!
Sep 24, 2009 | Nokia N-Gage QD Console
Nokia modem driver
There are now lots of mini-USB data cables forNokia 6030 and they work very well. You just need a program like MobileMedia Browser or Oxygen Phone Manager or MobTime Cell Phone Manager -they all work with 6030, at least newer versions. Needless to say thatyou can of course easily edit ringtones, themes, logos, aplications,also phonebook etc.
there are many websites where u can customize nokia 6030...i give links to u guys for downloads:
http://gallery.mobile9.com/c/n...?folder_id=7
http://www.imserba.com/downloa...s.php?cat=94
Jul 03, 2008 | Nokia 6030 Cellular Phone
Nokia 6030 screen fading
only slightly damaged lcd screens can take affect once there is a litle crack heat builds up on the screen and you have to repair it
Apr 02, 2008 | Nokia 6030 Cellular Phone
Nokia 6030 Cellular Phone Logo
85 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
