I have a problem for my msi laptop.all application for camera are shows black screen.i used windows 7 operating system.before same this happen.i used camera firmware its working.but now i use again,but shows no need to update.i also try all camera software came from msi but still not working.my laptop is msi cr420,intel core i3,memory:DDRIII 2gb,HDD is 320 gb.please help me.thank you very much..
    Sergeant:
  • 134 Answers
Hi kwitibo930
  • first a fall un-install the web camera software from your laptop...
  • Then check the whole system as virus security
  • Then resart it
  • Then install msi web camera software itself...
  • Then check it working or not..
  • If it not means go to www.msi.com
  • And enter your model name
  • Enter what you want the cam driver...
  • then install it and resart your system immediately
  • Then it worked clearly try it..
  • Thank you...
Posted on Jan 01, 2011
Msi laptop password hack
Which Password? Bios Password? Hard Drive Password? Windows Welcome Screen User Logon Password?
Which Operating System? Windows XP? Windows Vista? Windows 7?
OK, if you are running Windows 7, Microsoft tightenedsecurity on it so you've got to have a password reset disk which 99% of thepeople who own laptops with windows 7 fail to do. It should be one of thefirst things you do when you buy the laptop. Otherwise, you're faced withreinstalling the Operating System or possibly doing a System Recovery.
If you're on Windows XP or Vista try this:
Turn off the computer, then hit the power button to turn it back on andimmediately start hitting the F8 key repeatedly until you see the Safe Modeoption. Select SAFE MODE and let the computer boot up. When it getsto the User Login screen it will show the Administrator userid and the useridfor which you forgot the password. Sign in as the Administrator (hopefullyyou didn't put a password on it and forgot it too). Once the desktopappears it will look different, the screen will be darker and the icons bigger,but this is normal for safe mode.
Click Start/Control Panel/User Accounts
When the User Accounts screen opens, click on the userid for which you forgotthe password. Select the option to REMOVE PASSWORD.
Reboot your machine.
May 07, 2012 | MSI L1350D-1672US Netbook
Download free drivers msi cr420 webcam driver
i have a msi cr420 laptop and i am having problem with my laptop's web camera . .whenever i want to use my camera the computer prompts me the message "NO CAMERA FOUND" what should i do?? i am running a windows 7 ultimate 32bit operating system . .please do help me . .
Mar 25, 2011 | MSI U130416US Netbook
Can this camera be compatible with windows 7?
Not compatible or not working well with windows 7?
(make your program/application run with windows 7)
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:))
Nov 04, 2010 | Panasonic PV-GS36 MiniDV Digital Camcorder
Drivers d'installation compatible avec Windows 7
(making a program work with windows 7)
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:)) julyallan01_52.jpg
Oct 19, 2010 | Samsung Digimax S600 / Kenox S600 / Cyber...
Tengo una laptop msi vr601 la cual viene de fabrica con windows vista, cambie el windows vista por windows 7 y la camara que trae incorporada no funciona. que debo hacer para que la camara sea compatible...
Jun 23, 2010 | Umax AstraPix PC100 Webcam
My sony digital video camera Model DCR-TRV19E is not compatible for Windows 7. What shall i do?
Jan 20, 2010 | Sony Handycam DCR-TRV19 Mini DV Digital...
Toshiba satellite with windows xp will only show black sreen and wont let windows xp repair
Your description of the symptom shows that your operating system installation has been corrupted. Fastest and easiest way to resolve the Issue using the "Recovery and application disk" (it comes with laptop) to perform full system recovery. I would like to remind you full system recovery will erase everything saved on Hard drive. You can check possible option on http://support.toshiba.com
If you dont have recovery and application disk you get one. You can call Toshiba @ 1-800-457-7777
Please post if you need further assitance
Good Luck
Jan 15, 2008 | Toshiba Satellite A100-S8111TD Notebook
Computers & Internet Logo
197 people viewed this question
David Payne
David Payne
