Question about Panasonic PT-47WX49 47" Rear Projection Television
Can i use any type of mirror for my tv or do i need to get a type i should get
    Brigadier General:
  • 8,909 Answers
If you are refering to the internal mirror, only a Panasonic one will fit correctly.
Posted on Jan 01, 2011
Need to mirror phone to t.v.
Hello, you need an mhl cable, just do a search with your phone model on eBay or Google and it shouldn't be to hard to find.Good luck
Aug 06, 2014 | Blue BLU Studio 5.5 D610A JB 4.2 Android...
Magnavox 42
You should remove the back of the TV where the mirror is located to get access to the front screen.
If you could give the model number of your TV to see if I can find a service manual.
May 26, 2008 | Televison & Video
I need a mirror for this TV any advice?
you can have one cut at most diy place's its just a stander mirror. can even use the plastic type to replace them you can get them from hobby shop's cut cut to size glue or double sided fixing tape to hold back in place.
Oct 22, 2013 | Televison & Video
My picture is foggy is there coolant that needs to be replaced in a toshiba 44nhm84
This type of TV doesn't use coolant. I would suggest to clean the mirror that reflects the image from the optical engine to the screen before replacing the lamp.
Let me know if you need further assistance.
Jan 01, 2010 | Toshiba 44NHM84 44" TV
Electrochromic rear view mirror does not dim when turned on
These mirrors are all made by one company, no matter the car maker, they all have the same problems, they are very unreliable, if u have power to the mirror which I am 100% sure u do the mirror will need to be replaced, they are not repairable they are about $250-300
Apr 11, 2009 | 2001 Jaguar S-Type
Cleaning the bulbs and mirror on my Mitsubishi 55" WS-55313 TV.
You should re-consider having a tech do that for you. The access is by removing the screen assmbly which are somewhat fragile. If you want to give it a try, pull the speaker grill off, it comes off just from pulling it, there should be five screws across the bottom of the screen assy, remove those, there is also an access door on the front of the set with four screws, that has to be removed to unplug the cable that goes to the screen sensors. The screen assy has to be lifted straight up an inch or two and then you can pull it forward away from the set.
As far as cleaning the mirror and lenses, you can't get to the face of the tubes so it's the top of the lenses that you clean, just use a soft lint free cloth (cloth baby diaper) and wipe the dust off the lenses, you can slightly dampen the cloth with water if necessary, same type of cloth on the mirror and you can use a glass cleaner on it just don't press too hard on the mirror.
Jan 31, 2009 | Mitsubishi WS-55513 55" Rear Projection...
How do i clean the mirrors on a big screen tv
In most cases you can remove the back of the TV and get up inside the cabinet to clean the mirror. Windex works great on any glass mirror, but if it is mylar, a less harsh cleaner is better. If you have a newer digital type projection, you will likely have to go in through the screen to get to the mirror and it is much more difficult. I can instruct more depending on type and model of tv.
Dec 06, 2008 | JVC Televison & Video
MY JVC HD56G786 TV
If the Mirror broke while the TV was sitting upright, the pieces of glass got down inside the light engine and the cooling fans. I don't think you took the light engine apart to clean out all of the glass so the main cooling fan is probably not running and causing the warning. There is no sensor for the mirror. Did you remove the chassis to clean the glass? You cna remove it again and try powering it up out of the cabinet. There are four fans that need to be running. If the light engine is filled with glass the fan at the bottom of the air exhaust will not turn.
I am fairly certain that since the TV was discarded there is more wrong with it than a broken mirror.
Jan 22, 2008 | JVC HD-52G786 52" Rear Projection HDTV
I need to replace the mirror, it broke during transport
Take the back bezel off. It should have many screws around it. then once open you should see the back of the mirror. Carefully take the screws out of the mirror, you may have to do some modifing with the new mirror if it does not come prefabed.
Aug 24, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Broken Mirror
you need to see if the lens where the light comes out is scratched..
if it is then the picture will never be right until you replace it..as for a cheap replacement mirror the picture might be watchable if it is a good quality mirror
Aug 01, 2007 | Samsung HL-S6187W 61 in. HDTV
Panasonic PT-47WX49 47" Rear Projection Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
