Question about Mitsubishi Televison & Video
Cracked screen on mitsubishi wd60737 tv. remove/replace?
3 Suggested Answers
MikeMaierTV
  • 206 Answers
SOURCE: Mitsubishi VS-6043 - 60 inch
These are fairly simple, remove the speaker cover and then remove the screws at the bottom of the screen, then the whole thing lifts up and off, be sure to unplug the front panel controls, this plug can usaly be found just behind the cover behind the speaker grill
Posted on Feb 07, 2008
  • 395 Answers
SOURCE: need to replace a cracked screen
WD-57731 & WD-65731 Front Disassembly
57” & 65” Models Screen Frame
Removal
1) Pull off the Speaker Grill.
2) Remove all the screws (b) from the
upper rear cover (except one at an
upper corner to support the frame).
3) Remove 10 screws (a) from the
front of the screen frame.
4) Remove the remaining ***** (b)
(supporting the frame). Carefully
pull the Screen Frame from the TV
and disconnect the ES and LE
connectors.
57” & 65” Models Screens Removal from Frame
1) From the rear of the Screen Frame remove 20 screws (a) from the top and bottom rails
2) Remove 6 screws (b) from each side rail.
3) Carefully lift the Screen assembly from the Frame.
MODEL: WD-52631 / WD-57731 / WD-65731
Screen Replacement
CAUTION: Wear gloves when handling the Lenticular Screen and Fresnel Lens.
This prevents cuts and finger prints. Do not place Fresnel Lens in the sun.
This may cause fire and heat related injuries.
Lenticular Screen and Fresnel Lens Replacement
1) Apply LENS-TAPE along the rear top edge of the Lenticular Screen.
2) Place the Fresnel Lens on top of the Lenticular Screen, and apply pressure along the top edge.
3) Place the screens in the screen frame and reinstall the cushions, top, bottom and side rails.
NOTE: The Lenticular Screen label must face the front and the Fresnel Lens label face the rear.
4) Reverse the Screen Removal Procedure and insert the screens in the Bezel.
Lenticular Screen and Fresnel Lens Removal
1) Remove the top, bottom and side HOLDER-SCREEN rails and their cushions from the Screen Frame.
2) Lift the screens as a single unit from the frame.
2. Separate the Lenticular Screen and Fresnel Lens.
Note: When separating the Lenticular Screen from the Fresnel Lens, use caution
while prying the Screen and Lens apart. Use a slot type ***** driver, and
remove the pressure sensitive double sided tape.
Posted on Mar 11, 2008
What is the correct part# for a DLP: Mitsubishi WD60737 60", Serial#139599 Made June 2009?
If your set worked well (no lines, maybe only white or black scattered pixels) before you replaced the DLP chip, then your problem could be that the DLP chip did not get seated properly or the cam screws were not tightened enough after replacing the chip. The DLP chip must be seated properly in its socket or else line and column lines will be seen. There is also the possibility that the DLP chip is defective or suffered static damage while being handled during the installation. Hope this helps.
Jul 11, 2016 | Mitsubishi WD Televison & Video
HELLO i HAVE THE mITSUBISHI wd60737 AND IT WILL NOT TURN ON. IT BLINKS THREE GREEN LIGHTS LIKE IT GOING TO TURN ON BUT THEN IT BLINKS RED ONCE AND TURNS OF. i TRIED THE HOLD FOR TEN SECONDS RESET THIN
First make sure the filters and vents are clean and the filter cover(s) are properly installed.
Try once more (DO NOT RESET). As soon as the TV shuts down, press the ACTIVITY/ENTER button and the CH Down button on the TV (not the remote control) and hold them for 5 seconds. The Status LED will start blinking an error code. The "normal" code is 12, which would be one blink, pause, then two blinks and a pause. The code is repeated five times. Post your results in the comments; I can look up the code for you.
Jan 03, 2015 | Mitsubishi Televison & Video
Wd60737 mitsubishi 60"
how long has it been since you replaced the Lamp in the unit
Oct 20, 2014 | Mitsubishi Televison & Video
Broken screen on model WS-55311 MITSUBISHI
If its the outer protective screen that u need I have one. I didn't like the glare it provided me with so I took it off. Email me remarkable14u at yahoo dot com.
Dec 25, 2013 | Mitsubishi WS-65809 65" Rear Projection...
Screen cracked
Unfortunately replacing a cracked screen is very expensive, I would recommend replacing your TV with a newer TV.
May 09, 2013 | Mitsubishi WD-60737 TV
I have a Mitsubishi WD60737 TV! TV powers on and then powes off! Red light is blinking! HELP PLEASE!
Try to check the lamp if already faulty replace same type of lamp and be sure to reset lamp hour meter after replacing lamp good day and best regards.
Sep 04, 2011 | Mitsubishi Televison & Video
Cracked front glass
U out of luck,not worth to replaced the screen,the screen it same as the new tv.The tv compannies sell out tv screen as a new tv.The tv 95% worth is in the screen.
Dec 23, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi wd60737. It will turn on. Remote does work. Sound does work. But, the video won't show. It just stays black. There is a solid red light when it is off. Tried to reset it and it still did the...
make sure u set ur output to AV u will find this on ur remote control or on front of ur tv set
in regards ur tv will not show a picture since ur last adjustment try to go to menu and follow instruction how to set the tv back to factory setting......this may give u ur picture back......if not call mitsubishi service centre and tell them about ur problem u have......i am sure they will help u
Nov 28, 2009 | Mitsubishi WD-60737 60 in. HDTV
Mitsubishi Model # is WD-62531 cracked screen!
HI, there are no replacement screens available for this model unfortunately. Sorry for the bad news there...
Apr 20, 2009 | Mitsubishi WD-62531 Projection Television
Televison & Video Logo
194 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
