Question about Nikon COOLPIX S630 Digital Camera
My nikon coolpix s630 won't turn on. I thought the battery had died, so I charged it but it still hasn't turned on. Can you guys help?
SOURCE: Nikon Coolpix 2100/3100/3200 battery compartment door latch broken (again)
I just purchased a new battery door for $15 with shipping from nikon. They sent a simple assembly diagram and I was able to replace the door in 30 minutes. I used a dremel to cut the old door off, but you dont have to do that. I got a little impatient.
Just buy the plastic piece and u can reuse the metal parts for your old battery door.
Posted on Mar 26, 2008
jackboy
  • 2985 Answers
SOURCE: Replacing the battery door on a Nikon CoolPix 4600
Tape it. Replacements not likely Check out Nikon support to be sure.
Posted on Sep 22, 2007
  • 11967 Answers
SOURCE: coolpix nikon s710 "lens error"
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Dec 28, 2009
  • 102366 Answers
SOURCE: Can I charge Coolpix S210 via USB cable and wall outlet?
No. In order to keep down the size and weight, the camera does not include the circuitry needed to charge the battery.
Posted on Jan 05, 2010
  • 6771 Answers
SOURCE: My Nikon Coolpix S3000 says
The rechargeable battery probably needs to be replaced, I would take it to a camera shop let him have a quick look to make sure the charge light is coming on and try a new battery.
Posted on Jan 14, 2011
Camera is dead , battery is fine , nothing turns on
Nikon Coolpix S8200 Troubleshooting - iFixit
https://www.ifixit.com/Wiki/Nikon_Coolpix_s8200_Troubleshooting
iFixitThe Nikon Coolpix S8200 model was released in August of 2011 with a ... Flash won't work, but light bulb is fine; Flash is enabled but still won't go off. Camera won't turn onĀ¶. You have tried turning on your camera and nothing is happening. ... Once a green light turns on, it is telling you that your battery is fully charged.
Coolpix S4000 won't turn on? - ePHOTOzine
https://www.ephotozine.com/.../coolpix-s4000-won-t-turn-on--97474
Jun 4, 2012 - Still won't power up mine so I am giving Nikon a call in the morning to see if they can figure out .... started up with both batteries all fine & dandy
Problem with Nikon Coolpix P510: Nikon Coolpix Talk F
Jan 08, 2016 | Nikon Coolpix S6700 20.1 Megapixel Compact...
My Nikon Coolpix s550 won't turn on despite having charged the battery. I went out and bought a new battery from Best Buy today and tried to get information on what might help but, surprise, the guy...
refurbished items sure have hidden defects/problems that later contributes to malfunction. i think, one of its internal chips(techy things inside) has worn out... probably needs replacement.. i suggest look for a technician.. if you're living in the philippines,it's easy to find someone. you can save your lovely camera and lil money of course.
Jun 19, 2011 | Cameras
Hi! My Nikon S570 model won't turn on. I haven't dropped it or anything and I charged the battery and it was complete. I've had this camera since February 2010. What should I do?? -Monica
i have a nikon s570 that is about 18 months old. (not under warantee anymore) it won't turn on, so we bought a brand new battery, charged it and it still won't turn on. Nothing. no motor noise, no lights, nothing. any ideas? nikon wants us to send it to them for evaluation and fixing....any thoughts?
Jan 15, 2011 | Nikon COOLPIX S570 Digital Camera
Hi, I have a Nikon coolpix S630 camera - 8 mnths old. Whenever I switch on the camera it says 'Battery Exhausted' and when I try to recharge the same, but it is not charging. Please help. /Suresh
if the camera still under warranty, i suggest to bring it to the center to have it checked both the battery and the cable and also the camera for possible problem. i have a nikon cam before and experienced the same problem, after sending it to the service center, they replaced the battery with a new one and the camera is now ok.
Jan 12, 2011 | Nikon COOLPIX S630 Digital Camera
My camera wont turn on l continues to say "battery exhausted" how do I get it to work again
my camera don`t work since i charge to the computer & it used to said battery exhausted but now it don`t even turn on what is wrong i need help now
Sep 05, 2010 | Nikon Battery(609529694082) for ENEL12...
My nikon coolpix makes ticking sounds when i turn
You could have dirt or a malfunction of the optical system. Get it to a local electronist to get it cleaned.
Mar 19, 2010 | Nikon COOLPIX S630 Digital Camera
Nikon COOLPIX S630 Digital Camera Logo
861 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
