Question about Infinity Modulus System
My subwoofer sometimes turns on and sometimes it don't. I've noticed that when i disconnect the power cord from the wall and connect it back the light/volume doesn't turn on. Also when i turn the amp too high the speaker shuts down...what's the problem????
    President:
  • 2,047 Answers
Subwoofers produce very high levels of vibration due to the intensity of their job. But the problem you are facing is a problem with the power pack. The power pack on the woofer is not supplying properly therefore the light/volume not coming on when the unit is unplugged and replugged. This also affects the woofer when you turn the amp to high because as a result of the power coming from the amp not being properly distributed instead of the power which flows into the woofer from the amp is not distributed accordingly it could blow the woofer so before it gets to that stage the unit shuts down.
All you have to do is get an expert to help you get and replace the power pack.
Hope this solution has been helpful?
Posted on Jan 01, 2011
3 Suggested Answers
  • 5 Answers
SOURCE: loud humming buzzing sound coming from subwoofer
make sure you have the speaker connection right if you do then it is a ground problem try plugging it in a different outlet
Posted on Dec 16, 2008
SOURCE: when i plug in my subwoofer it has a constant hum
Check to see where you are plugging it in. Plug all equipment into the outlet strips powered by the same AC outlet. Or use a direct box. Check your cords also. And lastly, return the product if you are under warranty and get yourself a new one. If the problem is still occuring, it probably has to be on your part, not the product. So try one of those examples before you return it.
Posted on Oct 15, 2009
How do I eliminate the humming on my Vizio VHT-510 system
see this instruction and fix it. God bless you
    • 1
      Disconnect the coaxial cable at the back of the satellite receiver or cable box by unscrewing the coupler on the cable end.
    • 2
      Attach the cable to the RF IN jack on a surge protector and tighten the coupler clockwise.
    • Sponsored Links
    • 3
      Connect a second coaxial cable from the RF OUT jack on the surge protector to the input on the cable box or satellite receiver. If this stops the hum, congratulations: You're done.
    • 4
      Unplug the subwoofer's electrical cord from the power strip or wall outlet if it is connected to the same circuit as the AV receiver. The amp in the AV receiver and the amp in the subwoofer are in conflict over the grounding of the electrical circuit.
    • 5
      Plug the subwoofer into its own surge protector and connect the surge protector to a different wall outlet than the AV receiver uses.
    • 6
      Disconnect the subwoofer cable from the back of the sub and the AV receiver if all other measures fail to stop the humming. Reverse the plug connections so the plug that had been connected to the receiver is now connected to the subwoofer. Turning the cable around may solve a problem known as ground-loop hum by reversing the shielding wire inside the cable.
Read more: http://www.ehow.com/how_6979184_eliminate-sound-home-theater-subwoofer.html#ixzz2ZdzrgBSa
Jul 20, 2013 | Vizio Vht210 2.1 Home Theater Soundbar...
Reset factory settings
Hi Harold,
Here is how to reset the HP Photosmart 8250:
Performing a full reset
1. Press the Power button ( ) to turn on the product.
2. With the product turned on, disconnect the power cord from back of the product.
3. Disconnect the power cord from the wall outlet.
4. Wait at least 15 seconds.
5. Connect the power cord into wall outlet.
6. Connect the power cord to the back of the product.
If the product does not turn on by itself, press Power button ( ) to turn it on.
Try to print.
Regards,
Sean
May 28, 2013 | HP - HP Photosmart 8250 printer
Buzzing sound when sub is on even without turning my amp on, if you can call me on my phone 909 938 9219 it be better for me thanks, i am little slow with my computer, please help
Buzzing is usally AC line noise leaking into an un-shielded cable somewhere or a floating ground. If the AC plug is reversible, try that. Sometimes the buzz is from an attached device. Make sure all audio cables are plugged in tightly at each end and routed away from or at right angles to any power cords and away from other sources of strong magnetic fields like TV's.
Disconnect the input(s) and see if it hums in the absence of an audio source. A bad audio cable shield or unwisely-routed audio cables will allow entrance of unwanted signals from external power sources, magnetic fields, even dimmer-controlled track lights.
I've also seen variable track lights induce noise but it's usually minor.
Try rotating the power cord in the wall outlet.
If it still buzzes with no cables or anything external attached there's an internal problem.
Apr 30, 2011 | KEF Audio PSW 2150 Speaker
LOST A CORD TO MY COMPUTER SPEAKER SYSTEM MICROMEDIA SYSTEM. SERIAL NUMBER IS PN7000596, EJ 0192668 O THE SUBWOOFER. TWO SMALL SPEAKERS CONNECT INTO SUBWOOFER. LOST ONE CORD. CAN I GET A...
They usually use pretty standard audio cords, you can probably just get a replacement at your local Radio Shack. The only one I would be worried about is if you lost the power cord....if that's the case you need to be sure if you buy a different one that the voltage is the same as required.
Mar 08, 2011 | Boston Acoustics MicroMedia Computer...
What does usb device not recognized ?
The best you can do is,
Turn off the PC/Laptop
Disconnect the USB cable from Camera to pc/laptop
Disconnect the power cord connecting the pc/laptop and the wall jack or surge protector
Disconnect the power cord connecting the camera to wall jack or surge protector
wait for 5-10 mins
Connect the power cord of PC/laptop and turn on the pc/laptop and login to your PC
Connect the power cord of Camera to wall jack or surge protector
Connect the usb cable or camera to PC/laptop
It should get recognised and work fine.
Regards,
Shawn
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Jan 20, 2011 | HP Photosmart R847 Digital Camera
Hp deskjet 5650 - error states "close cover" -- cover appears to have closed
I'd suggest a power reset. Sometimes the device is unable to recover itself.
From HP's website:
  • Press the Power button (c01602202.gif ) to turn on the product.
  • Disconnect the power cord from the back of the product.
  • Unplug the power cord from the wall outlet.
  • Wait 15 seconds.
  • Plug the power cord back into the wall outlet.
  • Reconnect the power cord to the back of the product.
  • Sep 25, 2010 | Computers & Internet
    I have an Infinity Modulus system. My MSW-1 subwoofer will not power up. I have checked the fuse, power cord and power switch, all are good. It seems like a farly common issue but I haven't found a fix....
    Mmmhh! An i tought i was the only one with this same problem. My speaker sometimes i could get it to work, sometimes i would disconnect the power cord from the wall, few minutes later i will reconnect and it work.
    Lately i can't get it to power up.
    Hopefully some one knows about this problem.
    Sep 19, 2010 | Infinity Modulus System
    Carver d12 subwoofer making humming sound
    check your rca ground on the woof or the receiver you have a bad ground on one
    Oct 09, 2009 | Electronics - Others
    Carriage jam message
    SolutionStep one: Perform a power reset and connect the printer directly into the electrical outlet Remove all the paper loaded in the main input tray.
    Make sure that the product is turned off.
    Disconnect the USB cable from the back of the product.
    Disconnect the power cord from the product.
    Disconnect the power cord from the electrical outlet and wait 10 seconds.
    Reconnect the power cord directly into the electrical outlet and check for the following.
    Make sure that the power cord used is the one provided with the product.
    If a computer is connected to the product, make sure that the computer is connected to a grounded (three-prong) wall outlet.
    Make sure that the power cord is firmly connected to both the product and the power supply.
    Press the power button ( ) to turn on the product.
    Reconnect the USB cable to the back of the product.
    If the issue is resolved, proceed to Step six: Print a self-test page.
    If the issue continues, proceed to the next step.
    for more information please go to below link>>
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458822&cc=us&lc=en&dlc=en
    Thanks for using FixYa.
    Nov 07, 2008 | HP 2175 All-In-One InkJet Printer
    Xbox 360 won't turn on
    he should first switch his xbox 360 before his uncle check the electricity power source in the house.
    Dec 24, 2007 | Microsoft Xbox 360 Console
    Infinity Modulus System Logo
    205 people viewed this question
    Top Infinity Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Jerry Greenberg
    Jerry Greenberg
    Matthew Spark
    Matthew Spark
    Are you an Infinity Audio Player and Recorder Expert? Answer questions, earn points and help others
