Question about Sony Alpha DSLR-A230 Digital Camera
How to solve SD memory card when it say unable to use it?
  • 312 Answers
An SD memory card usually has a little white slider on the outside of it. I says in small letter, with a little arrow "LOCK" . Push the slider in the opposite direction of the arrow i.e. to unlock it.
If this is the case, then the camera should be able to communicate and write to the card.
There is also the possibility that the device in the camera which detects this slider is damaged. In that case the camera should be repaired. I think, though you will be OK moving the slider.
I hope this has helped you.
Happy New Year,
Best, Mark
Posted on Jan 01, 2011
  • Mark Freedman
    Mark Freedman Jan 01, 2011
    Hi Again, there is an additional problem that I didn't mention. That is the card can be corrupted.
    Open this linkhttp://www.normsoft.com/kb/idx/49/157/ar...
    Best, Mark
Unable to share file pc to mobile through sd card reader.
This happened to me too. I solved this by buying a sd card reader that reads new sd card thst are sdhc or sdxc.
Also check device manager on pc if its conflicting with some other hardware
Mar 15, 2016 | Cell Phones
I can not formate my SD memory card it shows windows was unable to formate
You will need special formatting software from the disk maker. Windows XP will not normally format a sd memory card.
Dec 21, 2013 | Electronics - Others
When i insert memory card into my canon a620,it is unable to read the card.memory card is what i see on the camera when i try to take pictures.please how do i solve this problem?
What type and size memory card? The A620 works with MMC and SD cards, 2GB or smaller. It will not work with higher-capacity SDHC cards.
May 29, 2013 | Canon PowerShot A620 Digital Camera
Camera says "unabled to format, please replace card"
Check the SD memory card R/W switch.
SD and Micro SD memory cards has a small slide switch on the edge of the card, which write protects data on the memory card or add photos to the SD card. Slide the switch from the LOCK position to the UNLOCK position, which is furthest away from the contacts.
Oct 20, 2012 | HP Photosmart M447 Digital Camera
Unable to access CD/2GB due to drivers how can i stall the driver
you do one thing to install dual o.s in your system and solve your problem
Apr 04, 2010 | Kingston 4GB Secure Digital High Capacity...
Memory card unformatted
If there are sd card error, you cannot format your sd card. you may get messages like
"No SD memory card inserted" messages appears when using digital cameras,
"A media card hard been inserted that contains errors. Do you wish to repair the Media Card now?"
You can read the files on SD memory card, but you cannot write new files or you cannot edit files on SD memory card,
"Access denied", when SD card is corrupted or broken,
you can fix sd memory card errors first and them format you sd card.
Nov 05, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
Im unable to read a 4gb SD memory card on my card
The card reader was not designed to read the SDHC type cards. You will need to buy a new card reader that accepts SDHC
Aug 09, 2009 | Cameras
Unable to use card
Firstly, what size memory hard do you have? Is it an SDHC? Secondly, have you checked that the memory card isn't locked (there is a switch on the side of it). Has it worked with other memory cards?
May 07, 2009 | Konica Minolta DiMAGE Z6 Digital Camera
8 gig micro sd unable to format
you should download memory retriever it fixes your memory card and retrieves your data. i had the same memory card and i thought it was from the memory card acting up so i got a new one. but it was kind of from both the phone and memory card but i downloaded the program and = ] my new memory card wasn't formatted so now am all good! both of them working because my san disk memory card wasn't working and it deleted all my data. so now it retrieved and now is working! give it a try! and tell me what happens
Mar 21, 2009 | Electronics - Others
V3x unable to read memory
i think u must buy max 512mb micro sd card for U fon,bcos U fon will not support 1GB micro sd card,try to soft U problem,hope can help U,reply me when U soft the problem,rose89my@yahooo.co.uk,thk!
Nov 20, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Sony Alpha DSLR-A230 Digital Camera Logo
133 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
