Question about Polaris Cycling
My 2000 xc800 sp backfires at low rpm but runs great at full throttle. I cleaned carbs and fuel pump nothing to dirty please help
  • 4 Answers
SOURCE: Misfire and backfire at low rpm, runs rough at low rpm
You did not say whether or not this was a carburater engine but from the sound of it one of your jets may be sticking, a good cleaning of the jets will most likely fix the problem, the likely cause is a small build up or piece of debris on the jet.
Posted on Jan 02, 2009
SOURCE: backfires at half to full throttle, idle is ok, low rpm
hi how are you
Posted on May 24, 2009
  • 10865 Answers
SOURCE: Backpack only runs low RPM, especially when cold.
Your carbeurator is gummed up. Remove the old fuel and make up a new fuel mix with new gas from the gas station. Then get a can of carbeurator cleaner spray. Three short squirts in the air intake and let it run. Three more squirts every minute or so until you dissolve the partial blockage that is causing your problem.
Posted on Jul 28, 2009
  • 332 Answers
SOURCE: 2004 sportsman 600, bogs down bad at half throttle.
Check that your choke is working correctly
Your timing may be way off as well
Posted on Mar 08, 2010
  • 311 Answers
SOURCE: ltz 250 wont idle needs full choke to run.cleaned
hi,sounds to me like the air fuel ratio is all up the ***,locate the air/fuel screw on the carb(normally on the side)screw the screw right in untill it stops,then back the screw out 1.5 turns,this should get the bike to run without the choke,once you have the bike running simply turn the screw in or out untill the bike settles into a nice steady idle,should be good to go,hope this helps...cheers
Posted on Mar 27, 2010
2001 Suzuki VS 800 Intruder hesitates 50-55 MPH
Hi, Robert and the usual suspects are:
1. Installation of a different camshaft.
2. Different exhaust system or "STRAIGHT PIPES"
3. Faulty advance curve.
4. Multiple carburetors not in sync.
5. Improperly installed jet kit or wrong kit.
6. Carburetor internal malfunction.
7. Fuel mixture too rich.
8. Fuel mixture too lean.
9. Extremely dirty air filter.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
low rpm hesitation sputtering
Backfiring hesitating in 03 Intruder 800
Suzuki VS700 Service Manual
OEM parts for Suzuki
Suzuki VL800 Owner Manual
Jul 12, 2017 | 2001 Suzuki VS 800 Intruder
If a full a rpm cost backfire
If what you are saying is that when you reach maximum rpm the car backfires, first be aware that most ignition modules have two sections--one for low rpm and one for high rpm. Could be bad ignition module. Also possible that some tune up item (plug wires, dist. cap) is bad, or that the engine is running too lean at high rpms (bad fuel pump, dirty filter, etc.)
Aug 11, 2015 | Cars & Trucks
VW Cabriolet RPM decreases
to me its sounds as though you have dirt ,gunk & grime ,water, in the main inline factory fuel filter, ,it will be a steel canister type, between the feul tank and the intake manifold, change filter,( u may need a mechanic, or someone handy with a spanner, once off, tip contents into and look for laquer peel, some tanks are seal with this, and it will some times peel ( especially if tank not kept full). if that is the case, have your tank taken out & cleaned, also, check airfilter, car will run better n cheaper to run, Hope this Helps. Kipper
Oct 27, 2014 | Cars & Trucks
How to set my idle mixture screws on 2000 r1
Hi, Merlin the carburetor throttle shaft wheel has two cables the cable closest to the right side of the bike is the throttle cable and the one closest to the left side is the idle cable. Right about the middle between the two is the idle adjustment bolt it faces out towards the air filter end of the carb . The engine should be at operating temperature with the enrichener off to set the idle between 950-1050 rpm. Turn the idle adjustment bolt clockwise to increases idle speed and counterclockwise to decrease idle speed. If you have access to your air fuel mixture bolt you may adjust it as well if not there is a video below on how to gain access, make sure you start with clean or new spark plugs. Gently turn the air fuel mixture bolt clockwise until it starts to bottom out "STOP" do not over tighten as it will damage the taper on the end, now back it out 2 full turns to establish a starting point start the engine and check the idle rpm's and adjust the idle adjustment bolt accordingly for 950-1050 rpm if necessary, adjust the air fuel mixture bolt 1/4 turn at a time and let the engine settle for about 10 seconds, clockwise for a leaner mixture and counterclockwise for a richer mixture you are seeking the highest rpm your air fuel mixture bolt can acquire without going past 3 full turns from bottom then readjusting the idle adjustment bolt back down to 950-1050 rpm If you can not detect any rpm change and can not stall the engine by turning the air-fuel mixture bolt all the way in then your pilot/low-speed jet is too big. Final adjustment should be made with a clean air filter mounted to the carburetor. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
http://www.r1-forum.com/forums/4-mechanical-help/2215-my-two-cents-carb-idle-mixture-screws.html
R6 Carburetor Fuel Mixture Adjustment
2000 2001 Yamaha YZF R1 Service Manual R1 Moto Data Project
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Apr 13, 2013 | 2000 Yamaha YZF-R1
Husqvarna 128LD backfires through carb when increasing throttle.
Possibly an ignition module issue, on the advance settings. It could be sparking before the piston closes the fuel port from the carb
Apr 05, 2012 | Husqvarna Garden
2000 Yamaha V-Max Idles low then takes revs
Hi, Shaneharris5 you need to make sure you have no intake leaks by spraying some Brake Kleen, Contact Cleaner, Starting Fluid etc. around the intake manifold and seals, if the RPM's go up or down significantly then you have a leak that needs to be fixed before you can continue with the carburetor adjustment.
The engine should be at operating temperature with the enrichener off to set the idle between 950-1050 rpm. Turn the idle skrew clockwise to increase the idle speed and counterclockwise to decrease the idle speed. If you have access to your air fuel mixture skrew you may turn it as well, if not there is a video below on how to gain access, make sure you start with clean or new spark plugs. Gently turn the air fuel mixture skrew clockwise until it starts to bottom out "STOP" do not over tighten as it will damage the taper on the end, now back the skrew out 1-1/2 full turns to establish a starting point start the engine and check the idle rpm's and turn the idle skrew accordingly for 950-1050 rpm if necessary, turn the air fuel mixture skrew 1/4 turn at a time and let the engine settle for about 10 seconds, turn the skrew clockwise for a leaner mixture and counterclockwise for a richer mixture, you are seeking the highest rpm your air fuel mixture skrew can acquire without going past 3 full turns from bottom then resetting the idle skrew back down to 950-1050 rpm If you can not detect any rpm change and can not stall the engine by turning the air-fuel mixture skrew all the way in then your pilot/low-speed jet is too big and needs to be replaced with the next size smaller. Final adjustment should be made with a clean air filter mounted to the carburetor.
New VMAX owner possible carb or maybe VBOOST problem
stalling max VMaxForum net
Yamaha Vmax VMX17C 2009 Service Manual
Yamaha MAX VMX17YC Owner Manual
Aug 01, 2011 | 2000 Yamaha V-Max
1984 GL1200 Goldwing... 80k mi. ....bike will not run without choke on 1/4 to 1/2 open... when given throttle, the engine backfires and blows black soot out of exhaust... new spark plugs with gap set at...
This sounds like a fuel flow problem. I suggest removing and rebuilding and cleaning the entire system, meaning Carbs, filters and strainers in the tank. Old fuel turns to gel, and floats absorb fuel, sometimes, so inspedt everything. When finished set carbs with carb sticks, both at idle and at 2000 RPM, using hand throttle.
Oct 26, 2010 | 1984 Honda GL 1200 Aspencade Gold Wing
Backfire
is it a straight thru exhaust, or is it just a head pipe with nothing attached? If it's just a head pipe, you need to get some sort of muffler on it or you'll burn your valves out from a lean condition. The backfire is due to the vaccum fed carbs that yamaha runs. They work wonderfully, but under heavy deceleration, the vaccum still feeds the bowl, and it builds up excess fuel, which eventually burns off as a backfire. If it were fuel injected, you could have the fuel map adjusted to lean it out under deceleration.
Jun 22, 2010 | 2001 Yamaha V Star 1100 Classic
I have a 1997 Triumph Legend, with approx 2200 miles when bought it had been stood for 8 years. would run under 45000 rpm's managed to get it home carried out full service and stripped carbs found pilot...
If it is backfiring on deacceleration you have a fuel mixture problem and need to "sync" the carbs.
Sync Pro carb tuner works well. This is a precise four channel vacuum indicator designed specifically for intake synchronization of engines with multiple carburetors or throttle bodies.
Also, if you have not done so, check your plug wires for defects and resistors, if your wires have them.
Good luck, hope this helps.
Mar 08, 2009 | 2000 Triumph Legend TT
Cycling Logo
Top Polaris Cycling Experts
WTF Chuck.....
WTF Chuck.....
colinat108
Are you a Polaris Cycling Expert? Answer questions, earn points and help others
