Question about Imation Apollo (27223) 250 GB USB Hard Drive
My external hard disk does not work.I dropped it.When i connect it to the computer, it makes a sound.It does not work.What to do?
  • 44 Answers
Fix by an expert required such as www.SaveMyUSB.com
1. Faulty USB port on PC: Try a different computer or laptop
2. Faulty USB cable: Try a different Cable
3. Corrupt memory: Fix by an expert required such as www.SaveMyUSB.com
4. Faulty connections on main circuit inside the hard drive: Physical Fix by an expert required such as www.SaveMyUSB.com
5. Faulty controller chip (worst case scenario) : Direct flash memory read required by an expert required such as www.SaveMyUSB.com
Hope this helps and that it is 1 or 2 as 3, 4 and 5 will cost you money.
Good luck
Posted on Jan 01, 2011
The light is on but the hard drive is not being recognized on the computer or the tv, it was dropped only once. there is a humming sound but no response. no more pictures or movies. is this possible to...
Good Day Daniellevion!
Have you seen a hard disk inside your computer? That is exactly what is inside in an external drive.
You mentioned that you dropped the external drive once, and that could be the reason why your computer was unable to recognized it as external drive.
Danielle! The connectors of the hard disk inside the Samsung External Drive (or other term is hard disk enclosure) might be loosened.
If you can open the enclosure and expose the two connectors, disconnect them and reseat properly.
That might fix it!
Jun 12, 2011 | Samsung G3 Station Desktop External Drive...
Tip
How to detect if your hard-drive is working or not/hard disk maintenance.
Some times you don't know if your hard drive is working or not. Your external hard disk might drop on the ground, or your desktop/laptop hard drive might not be booting. Which ever the case maybe, here is how to find out the condition of your hard disk:
Put your ear close to your hard disk, if you hear your hard disk make a crackling noise, be prepared to buy another hard disk because such hard disk is damaged and cannot be fixed. Also note that it is difficult to recover files from such hard drive.
But if you don't hear a crackling sound, use your hand(s) to feel the drive, if it vibrates, it means the hard disk is in good condition.
What damages external hard drive most times is if you don't eject (safely remove) it from your computer, when it drops on the ground or hits any hard object etc
If your external hard disk stops working, firstly, check if the hard disk inside the case is in good condition by checking for crackling sounds and vibration. Once you observe that the hard disk is in good condition, this means the hard drive case is defective/the cause of the problem. Get another drive case and your drive will work again without loosing any file/data on it.
For desktop/laptop hard drive maintenance, make sure you always shut down your computer properly, don't remove the CPU's power cord while the computer is turned on. To be on a safer side, always use UPS (uninterrupted power supply) for your desktop computer.
Also, when using your laptop, makes sure its fixed at a position. Avoid any shake as the hard disk might shift from its normal position in the process.
Good luck.
on Oct 21, 2010 | Computers & Internet
I have a Samsung 3g 2tb harddisk and it makes strange noises. sometimes it doesnt work and a my pc freezed.
Here is what you need to know about hard drives.......
I hope this is helpful..........
Good luck.
Mar 07, 2011 | Samsung G3 Station Desktop External Drive...
Wd my book flashing blue light. sill no power up
Good luck.
Jan 22, 2011 | Western Digital My Book Essential 1TB...
Hard disk tiking when power up.
Good luck.
Jan 11, 2011 | Hitachi HTS542520K9SA00 200 GB SATA Hard...
I dropped my wd external hard drive on a carpet floor it still lights up but makes a funny noise for some seconds then stops it connects after while but still i cant view my files
If it still has a valid warranty, exercise the warranty to get a free replacement.
Otherwise, open the enclosure, and separate the disk-drive from the USB-to-disk-drive adapter, and connect the disk-drive as a 'slave' disk-drive in a desktop computer, to see if the adapter was the problem.
Oct 24, 2010 | Western Digital My Book Essential 320GB...
I dropped my external hard drive - a Verbetim terrabyte hard drive. Now, when I turn it on, it makes mechanical noises and won't connect to my computer (USB). I'm not too concerned about trying to fix the...
If your drive is making whining and clicking sounds, then you have a mechanically damaged drive which had what we called a 'head crash' due to the drop!
If you can read/access the disk partitions/drives, I strongly suggest that you perform a full disk backup (with track error skipping) to another device. Also try a file by file copy to another drive (slow but you know exactly what is accessible).
You may want to try to use 'Spinrite' (Google and read about it first) to attempt to repair some of the issues but unfortunately, a disk 'head crash' is usually fatal physical condition and data recovery requires specialized equipment and is VERY expensive!
Hope it helps: let me know ho you go!
Dec 29, 2009 | Verbatim External, USB 2.0, 750GB...
Cannot get external hard drive to work
- Make sure that the hard drive (HD) is properly connected to the computer.
- Try connecting it to a different computer to make sure that the HD is the problem.
- Check the Disk Management in your computer to see if the HD could still be detected. Once detected, reformat the HD and it should work again.
To check the Disk Management:
NOTE: Make sure that the external HD is connected and turned ON.
1. Right-click "My Computer" (XP) or "Computer" icon (Vista)
2. Select Manage and click on "Disk Management".
3. From the Disk Management, you will see a drive letters
4. Write down all the drive letters and then disconnect the Maxtor HD from the computer.
5. If there's a drive letter that disappears, then that is your Maxtor HD.
6. Reconnect the Maxtor HD and reformat it. You may right-click the drive letter and there's an option to format the HD.
If you're hearing a clicking sound while the HD is turned on, mostly, it's already defective.
Have a great day!
Oct 17, 2009 | Maxtor Hard Drive
My hard drive was knocked of the table and landed on carpet
Computers do not like being dropped especially when it is powered up and running. It can do a heaps of damage.
If the hard drive in the computer makes a clicking sound and it won't boot up and/or an error message says it cannot find the hard disk or operating system, then the hard disk is damaged beyound repair.
With luck if the hard disk is only damaged then you can replace the hard drive and install Windows on the new hard drive with the device drivers and your programs. Your data on the old hard drive is gone unless you backed up your data onto CD, flash drive etc.
Sep 29, 2009 | Maxtor Fusion 500GB External Ethernet...
I have LaCie 500 GB Exernal Hard Drive. I was transferring some data from my computer into the hard drive. The hard drive fell off and stopped working. When i connect it to power, the power light doesn't...
Sounds like the power supply in the external case has gone bad (or going bad)...
If you have another external case, AND the drive itself is not damaged, you can move the drive to an external case.. Alternately, depending on the connection (IDE/SATA) you can move the drive internally to your computer.
Jul 20, 2009 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Imation Apollo (27223) 250 GB USB Hard Drive Logo
215 people viewed this question
Top Imation Computers & Internet Experts
Raj Patel
Jax Planet
Jax Planet
carey w mason
carey w mason
Are you an Imation Computer and Internet Expert? Answer questions, earn points and help others
