Question about Belkin Basic Wireless Router
I need to recover the factory IP address for the Belkin, Play, F7D4302 Wireless router. I had changed the Access point from 192.168.2.1. to 192.168.2.254
    Sergeant:
  • 171 Answers
Locate the reset button of your router. Using a paper clip or some pointed objects press the reset button for more than 30 seconds. You should now be able to recover your factory IP address. Good Luck
Posted on Jan 01, 2011
Can i setup the belkin f7d4302 as a wireless bridge
belkin does not support this. The only way you can do it is by running a cable to the router to extend your wireless signal around the house. I did a similar setup with a powerline network adapter if running a cat5 cable is not a option. just make sure you change the main ip address for the 2nd router to like 192.168.2.2 and disable dhcp since the main router will handle dhcp. also make sure the wireless settings are the same and channel is different if 1st router is channel 1 then use channel 6 or 11 for the 2nd router.
Feb 26, 2012 | Belkin Wireless Play Router (F7D4302)
Im trying to set this up as an access point. but it will not fine a ip from the router
Most router wont act as a DHCP client (Get an IP address) on their own.
You need to go into the Belkin setup and set it to an IP address in the range of your other router.
For example:
If your PC is getting (connected to the same network) an IP address of 192.168.0.3 IP and a Default Gateway address of 192.168.0.1 you can set the Belkin with any adderss between 192.168.0.10 & 192.168.0.254. Changing the last octet (set of numbers after the 3rd period) to the desired address.
Mar 02, 2011 | Belkin Wireless-N Wireless Router with...
What is the security key of a belkin wireless router model f7d402?
Wireless routers can change the type of security key such as WEP, WPA and WPA2. WEP is the weakest type of encryption, and WPA2 is the strongest. To see what kind of key you are using, log into the routers ip address (Defualt gateway address in ipconfig command) then find the area for wireless security. The type of key and the key should be displayed.
Mar 02, 2011 | Belkin Wireless Play Router (F7D4302)
Help me ! I lost my Belkin Wireless Play Router (F7D4302) SSID and passphrase that comes on a card with the router before i set up my router ?? so i can't set up and use my router please if you could give...
Check on the underside of the unit, there may be a sticker with your SSID on it. If you need to you can also reset the password back to the factory default by holding down the reset button. You can also download the instruction manual from here:
http://www.belkin.com/IWCatProductPage.process?Product_Id=509868
Would you kindly rate my answer please if this has helped resolve the problem - thanks :)
Oct 21, 2010 | Belkin Wireless Play Router (F7D4302)
On belkin surf router clicked on set as access point. then i tried to change it but my computer cant get internet from the router so i cant access the belkin homepage. can u help
the only thing you need to do is reset your router to go the IP address original 192.168.2.1
because when you setup it as a access point the router change the Ip Address.
restore the router to factory default settings, please do the following:
1. Unplug the router's power supply
2. Press and hold the reset button on theback of the router
3. Keep the reset button depressed and, at the same time, plug the power supply back in
4. Keep the reset button depressed for another 10 seconds
5. Release the reset button
do this for 3 times and you will acces your router.
Good luck
Please rate me techbelkin
Aug 02, 2010 | Belkin Wireless Surf Router (F7D2301)
Connect belkin f5d7130 to homehub 1.5
You need to connect all pc's and homehub to a switch so they can talk to one another. Then use the AP as a wireless access point to connect all wireless laptops, and connect the AP to the switch with ethernet cable, and you have a network. Just make sure that only your HH or AP supplies IP addresses or they will clash.
Oct 19, 2009 | Belkin Wireless (F5D7130) 802.11g/b...
We've just moved house and have aquired to belking routers a belkin wireless pre n and a belkin ADSL G Plus MIMO I want to use the latter as a bridge how can I?
You need to access the setup page of your Belking router and go to the wireless setup, look fro Use as Access Point, now just a reminder this will defeat the NAT IP sharing feature of the router. Configure the IP address of the router to the same subnet as the network your tying to bridge here's the more detailed procedure:
1. Enable the AP mode by selecting "Enable" in the Use Access Point only page. When you select this option you can now change the IP Settings.
2. Set your IP settings to match your network. Click "Apply Changes"
3. Connect a cable from the LAN port of the router to your existing network.
Sep 18, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Wireless access point
try hitting the restart button on the router and or unplugging it for 10 full seconds. then logging back in. Also might want to try Internet explorer (no-addons) or other web browsers.
Nov 14, 2007 | Belkin (F5D9230-4) Wireless Router...
Xbox 360 help
All devices on your network should be assigned an IP address. They need it to be identified on the network. You can try rebooting your router. The wireless on belkin routers can be a bit temperamental. Then try the 360 setup. If you are still coming up blanks, then check your router's DHCP server setting. Make sure that it is turned on. (It is the function that assigns the IP address.) My lat suggestion is to manually assign an address to the 360. Try this only if you are familiar with how IP addresses work. Hope this helps....
Aug 27, 2007 | Belkin Wireless (F5D7130) 802.11g/b...
Belkin Basic Wireless Router Logo
107 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
