Question about GE Profile 25.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel
Ice mker does not make ice - GE Profile 25.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel
  • 312 Answers
There are several causes of this.
Here is a list to check. Some of this may seem silly, but follow it through.
1 Water supply to back of fridge is shut off.
2 Tube that supplies water is pinched or kinked closed. Similar to a Kinked garden hose.
3 Solenoid valve (electric valve that opens and closes that supplies water to ice maker tray has failed)
4 Solenoid valve does not seal completely allowing water to seep past it. If this is the case the tube inside the freezer compartment will have a solid piece of ice in it which prevents water from going into the ice make. (very common cause of failure) Take very close look at the tube. Usually it can be removed and reinserted fairly easily. You may possibly have to remove the Ice maker. That involves more work, but not a great deal. Let me know if you need to remove it and I'll write you a procedure.
5 Ice maker feeler arm up (crescent shaped cube style of ice maker) which shuts the ice maker off.
6 Switch inside Ice Maker that controls fill valve failed. Or other parts in it failed. Replace ice maker. (usually costs less that getting it repaired)
7 County did not pay water bill to the state, and they shut off your water to collect.
(Rare)
I hope this helps. As it happens to be new years eve. Don't let this ruin it in any way. Get a bag
of Ice at the local store and have a HAPPY NEW YEAR
Best, Mark
Posted on Jan 01, 2011
Have an Invensys N86 on my refrigerator, it is pumping water into the water dispenser, but is not getting any water to the icemaker. I imagine my installer may have made a mistake, but I do not know much...
if this is new install . it may be installer's problem but if not its a bad water valve . and needs to be replaced .. mm the valve is a dual valve one side for ice and the other for water . .. also the ice maker tube may be frozen and the water cannot get to the ice mker .. so ck the tube inside the freezer to the ice mker . it may need to be de iced .. mm hope this helped feed back pls ..
Feb 26, 2011 | Refrigerators
The Ice maker just stopped working. It is getting water because I can see lines in the plastic tubes in the back. There are no ice cubes stuck in the trey. Any suggestions?
ther may be water in the lines but it has to move . if the valve is bad it will not open when the ice mker calls for water . ( very common problem ) the ice mker may have failed / and the tempt in the freezer must be 15deg or lower . . ck the coils and the fans . this could cause poor referg. and higher thempts . .. hope this helps mm
Jan 19, 2011 | Maytag MFD2560HES Bottom Freezer French...
My ice machine in my side by side is not working It makes the ice but it does not spit them out. The ice "pusher" tries to push it but I think it fills it too much
if its making ice and when you state that it doesn't spit them out . is it that they don't come out of ice mold or do they not dispense through the door . so #1 if they donot come out of ice mker mold then the thermo or the heater in the icemker is bad .#2 if they will not dispense via the door the ice cubes may be too large or water is getting in to storage bucket causing ice jamb . you can adjust mker to make smaller cubes . hope this hepled mm and thanks for usnig fix ya . feed back pls ..
Oct 22, 2010 | Amana ARS266ZBS Side by Side Refrigerator
Ice cubes won't eject
if they will not eject . then i would think the mold & or heater have failed . it works like this . it fills / it freezes/ ( the freezer must be 15 deg or lower for ice mker to cycle . ( cck the tempt ) and if ok then the thermo cycles the ice mker . during the harvest cycle the mold heater comes on and warms the mold and releases the ice. the hands move the ice out . .. so if cold enough the ice mker is bad. cheaper to repl ice mker than repair it . in most cases . mm hope this helped feed back pls ..
Oct 21, 2010 | Maytag PTB19BBGR Top Freezer Refrigerator
My SXS-22 makes ice but will not kick the ice out into the ice bin.
mold heater in ice mker has failed . and ice will not release . . best to repl the ice mker . / do ck freezer tempt . as it should be 15 deg or lower . .. mm
Sep 23, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
How to turn on ice and water to refrigerator.
if water s hooked to unit and power is on the ice mker and water is auto . make sure the arm on the side of ice mker is down . . mm hope this help mm
Sep 02, 2010 | Samsung Refrigerators
Have a kenmore refigerator #106-56572400. How do you remove ice maker from unit?
this unit has the ice mker up front / there is on the bottom side a scres 1/4 remove it . the on the l & r there is two plastic tabs pust them in and pull ise mker out of slides . the cord is short and will have to un plug to remove completly .. ,, take your time . this one is not easy . but get easy er the second time .. mm
Aug 18, 2010 | Kenmore 21.9 cu. ft. Side-By-Side...
Icemaker for a Whirlpool GS6HAXB00 is not working however, the water dispenser is still working.
this unit uses a dual valve one side for the foutain and the other for ice mker . it could be the valve . if not it's possible the ice mker itself . . ck the freezer tempt it must be 15 deg or lower for ice mker to work .. mm
Dec 07, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kitchen Aid ice maker is making a pumping noise. The noise is itermitten. It still makes ice. Freezer is at 5 degree and fridge is at 34 degree. Aquasensor filter is at 44 percent left. Thanks...JA
noise from ice mker can only be the ice maker unit... turn of icemker for a while and see if tn=he noise comes on during that period . if not replace ice mker head . mm
Dec 07, 2009 | Dishwashers
Not getting water to icemaker but have water in door dispenser
no water to ice mker / look at the water valve in the back it is a two sol. valve one side for water and other for ice .. also the tube in back of freezer that fill the ice mker may be frozen .. ( hot water up the tube will open it .. mm
Nov 30, 2009 | Dryers
GE Profile 25.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel Logo
120 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
