Question about U-Line 15WC Wine Cooler
No longer cools, although the light comes on. Have tried unplugging and replugging to no avail
  • dcmosspt Jan 02, 2011
    the fan does not run, but the light does come on. this unit is only 4 years old and gets light use. Is there a reset somewhere? I have tried unplugging and plugging back in with the unit on and off.
    President:
  • 2,047 Answers
Usually when coolers freezers and refrigerators stop cooling it usually is as a result of a couple of issues mainly all of these issues affect the gas in the unit compressor.
Usually if the unit is just moved around it requires some time to settle down. In other cases the gas in the compressor might have leaked out of the unit and therefore the unit will refuse to cool.
If the unit lights up and every other thing seems to function fine all you have to do is get a repair technician to help fill up the gas in the unit.
Also tell them to ensure to check for holes and block them otherwise the unit will start misbehaving again in a short while.
Hope this solution has been helpful?
Posted on Jan 02, 2011
  • 22,156 Answers
I have one like this as well its works the fan runs but it doesnt cool unless i put a frozen bottle of water in ,could be a thermostat or the compressor motor ,could even have just lost the gas through a solder joint somewhere ,you will have to take it apart first to determine the cause and then if its economicaly viable to have it repaired ,check the thermostat is working first thouigh if anything more bin it as these are not expensive to replace ,90 euros for a small one and just under 200 for a bigger one ,but the best ones that run for ever and a day are the ex coca cola or pepsi ones if you can find a second hand one from the companys that supply and maintain these machines for the drinks companies .
Posted on Jan 01, 2011
Proscan LED TV Will power up the red standby light & standby on amber when turned on but does not show picture or sound unless I unplug and replug over
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Feb 14, 2016 | Proscan Televison & Video
Electronic controls at 0
Did it quit cooling also? Where is the humming coming from?
Nov 24, 2011 | Amana ARB2217CSR Bottom Freezer...
Computer mouse wire loose at mouse - wire connection
Although I severely doubt the mouse will give you an electrical shock I would suggest a new one as they are cheaper than a repair would be.
Sep 12, 2009 | Computers & Internet
Frig stopped cooling, unplugged & replugging worked - now what?
hi try out the following settings....
Check your temperature setting.
- Check if no ice present in the evaporator, try the defrosting
- Check vents if air is present if no then check your blower if running or icing evaporator.
- Check your vents if not obstructed with stocks, or the unit is not overloaded with stocks.
- Check if compressor is running continues, if not then you need a qualified technician.
i think after checking this it will work out for u.!!!
thank u
rate me!!
Apr 10, 2009 | Kenmore Refrigerators
Marantz SR6001 AV Surround Receiver - Blinking Standy Light
I have exactly the same problem! Sometimes when I turn the input dial it comes back on but this time it is out for good. I have tried re-wiring and unplugging etc. nothing seems to work.
Jan 21, 2009 | Marantz SR6001
Chinese refrigerator stopped working.
Appers to have lost refrigerant, yup you need to call in the repair man.
Nov 11, 2008 | Refrigerators
Panasonic ag-dv2500 dv-tape recorder
check the "remote" switch on the front panel; make sure it is in the "off" position. if it is in any other position, the function buttons are disabled.
Jun 23, 2008 | Panasonic Proline AG-DV2500
Monitor Display
Try using a different monitor, although it doesn't seem like that's the issue. If the new monitor gives you the same problem it could be your video card.
May 01, 2008 | Computers & Internet
U-Line 15WC Wine Cooler Logo
296 people viewed this question
Top U-Line Furniture Experts
John Tripp
John Tripp
Sal DeAngelo
Dan Webster
Dan Webster
Are you an U-Line Furniture Expert? Answer questions, earn points and help others
