We bought a field and stream 32 gun combination lock safe, but the manual was locked inside the safe, he have the combination, but we dont know the specifics on how to turn the combination lock and how to turn the 3 spoke wheel, help please.
SOURCE: I purchased a new Sentry
(1) sounds like the interior lock activation screw is still installed. it's the long screw on the inside of the door with the yellow tag; (2) when entering the code, make sure the key is turned to the right; (3) after entering the code, make sure you next press the program button. enter the code wrong three times and it locks up for two minutes.
Posted on Sep 13, 2010
Obertelli
  • 3006 Answers
SOURCE: Thought I knew the 4
Without wishing to state the obvious, I feel that I must do so. A safe is called a safe for a very good reason. If it was easy to get inside without the correct key or combination then by definition it would be unsafe.
If you have lost the combination and the key doesn't work then you can either try every combination until you get lucky or you must consider calling out a locksmith who will usually open the safe destructively (often by drilling out the lock) or even by using an angle grinder on the hinges.
Posted on Sep 17, 2010
SOURCE: Sentury Fire Proof Safe 1250
Is there any way to crack the safe by feel, ive seen it done before and have some experience in opening locks with pin tumblers, but not wheel tumblers. i can find the notch in the third wheel at around 10-15 but i dont know where to go from there. I would not be using this information for any illegal use, i just need to open my safe on my own, and soon, thank you.
Posted on Sep 21, 2008
  • 3 Answers
SOURCE: bunker hill safe
i had the same problem this is what i did. i took the lil leg off the bottem it held on by a srew take a cloths hanger put it in the hole and now u can hit the lil button that is for makin a new code it is on the hing side of the door the yellow light will come on and stay on now put ur new code in then hit a or b i used 1111a then changed it once i got in o by the way ''the factory code is 159a try this first" and the cloths hanger i shoved a ear plug on the end of it so that way it could grip the button hope this helps somebody
Posted on Nov 29, 2008
SOURCE: know combination, but cannot open sentry safe 1250
If you know the combination:
1) Turn the dial to the left a few complete rounds, then stop on 1st number.
2) Turning the dial to the right, pass up the 2nd number once, then stop on it on the next round.
3) Turn the dial to the left directly to the 3rd number then stop.
The handle should open now.
Posted on Mar 18, 2009
How do I change the battery in my lock
Check user's manual. If don't have contact site where you bought you not well specified safe to get proper instrucions
Jul 13, 2015 | Resolute Digital 32-Gun Fire Water Rated...
How to change combination on field& stream 10 gun safe
Guaranteed to work.....
Load Gun
Place tip of gun barrel on lock
Look away....
Pull trigger....
I'll bet the combination has changed!
Sorry... I have a sick sense of humour!
Jul 22, 2014 | Field & Stream Sportsman 10 Gun Fire Safe
Manual for stramm digital electronic safe manual
The Stramm safe we have is a small one that we use to store keys for our drivers. To change the combination, open the safe with the current combination. Sorry, can't help you if you don't know that. Inside the door is a plastic panel covering the batteries. Pinch the plastic catch at the top and open the panel. There is a small red button which you can press to change the combination. When you press it, you will hear a double beep. Enter your desired new combination. The trick is that the last digit must be either an "A" or a "B" which signals the end of your combination. For example, if you want your new combination to be 123456, you can't do that. The closest you can come is 123456A or 123456B. Hope this helps. Steve, Mbeya, Tanzania
Apr 06, 2013 | Safe International Digital Electronic Safe...
I have a sentrey key pad safe and forgot combination dont feel like paying to have a locksmith come open it any suggestions
There should be a factory code, printed on the instruction manual. Otherwise, the factory might be able to help, for a nominal charge. The reason a locksmith charges for this service is they know (at least they should know) how to do it without damaging the safe. If you can take it to the locksmith, you'd avoid the trip charge. Obviously, I can't post a detailed solution here.
Aug 03, 2011 | Safe International Digital Electronic Safe...
Locked out of my cs2 safe
If you registered your safe with the manufacturer they will normally let you know your combination if you have registered the safe.
If not you will need the serial number on the side of the safe and you will need a notary stamped paper explaining you are the rightful owner of the safe.
Costs will apply to the Notary and possibly from the manufacturer.
Aug 23, 2009 | Safe International Digital Electronic Safe...
1,742 people viewed this question
jasbo
jasbo
